Kết quả 1 tới 3 của 3
    Thành viên chính thức nguyenlaluong's Avatar
    Mặc định xin giúp lumia 520 error unable to find a bootable option. press any key to shut down
    em chạy phân mềm nó báo như này :Windows Phone 8/8.1 Flashing Started
    Loading Flash Files Please Wait...
    Windows Phone 8/8.1 Lumia Flasher
    If the Phone is ALIVE
    1. Power On the Phone and Connect it to the USB Port
    If the Phone is DEAD
    1. Connect Phone to the USB Port
    2. Press and Hold the VOLUME DOWN and POWER Buttons
    3. Wait until the Phone Vibrates Shortly...
    4. Stop Pressing the Buttons...
    Nokia Phone Info Mode Initiated...
    Please wait upto 15 Seconds for SW Reset
    1. Press and Hold the VOLUME DOWN and POWER
    2. Wait until the Phone Reboots...
    3. Wait until you see BIG "NOKIA" Logo
    IMEI: 358106050540270
    Version: 1.1.1.3
    Product Code: 059S357
    Module Code: 0205435
    Continuing Previous Boot...
    Please wait upto 30 Seconds for Boot Re-entry
    Boot Flash Mode Successful...
    Buffers Flushed OK...
    Phone Info Query Start...
    Blocks Returned: 0x07 Blocks
    Block ID 0x01 : 00241000
    Block ID 0x02 : 00240000
    Block ID 0x03 : 00E90000
    Block ID 0x05 : Nokia.MSM8227.P6036.1.2
    Block ID 0x0D : 0001
    Block ID 0x0F : 0301010100000101FF
    Block ID 0x10 : 0100130000
    Checking SD Card Size...
    Card Size: 0x00000000
    Checking Platform Security Status...
    Platform Secure Boot Status: Active
    Secure FFU EFUSE Status: Active
    Debug Status: Active
    RDC Status: Not Active
    Authentication Status: Not Active
    UEFI Secure Boot Status: Active
    Checking Secure FFU Mode...
    Secure FFU Mode :
    Query Flash App Information...
    Flash App Information: 02010F011C00
    UEFI App: FLASH APP
    Flash App Protocol Version: 1.15
    Flash App Implementation Version: 1.28
    Query ROOT KEY HASH...
    ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD
    Sending Image Signatures...
    ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000)
    This Flash File is NOT COMPATIBLE with this Phone.
    ERROR: Flashing Failed!
    Thành viên chính thức duclongmobile82's Avatar
    Feb 2014
    hà nội việt nam
    Trích Được post bởi nguyenlaluong Xem bài viết
    Version: 1.1.1.3
    Secure FFU Mode :
    UEFI App: FLASH APP
    ale vứt thôi bác .hôm nọ nhận 2 em 1 520.1 620 repair boot big boot các kiểu ko đc nói chung hiện lên dòng chữ này trả về cho nhanh đỡ mất việc
    381 cổ nhuế từ liêm hà nội
    tel:0163.886.8866
    Jul 2013
    Nghệ An
    bạn nên kiểm tra lại file đi nha. khả năng sai file là cao. file không hợp với máy hoặc nạp boot bị lỗi RM gây nên không hợp với file cần chạy.
    Chưa có gì để cả.
