mở nguồn lên logo rồi treo logo rồi lên dòng chử phone start-upfailed.contact the retailer đã flash bằng mxbox mà không đc đây là log của nó ae giúp
MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C0814693
Using device: USB ROM and HTI, FW ver: 00.50, SN: 01014181
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.117
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Processing MCU file: rm745_102.002_prd.core.fpsx
[BB5,XSR 1.6] size: 97.04 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 0260010B7FDE0344DD1C85B3C94F846E369465C9
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 22D759CB
FUR: Adding Asic CMT as client OK.
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35168505503011_CE RT.rpl).
CMT PAPUBKEYS HASH: 5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 207.56 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0D3BFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 5F18D62F [] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 16.813 s
Processing PPM file: rm745_102.002_01.01_Euro1_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 46 MB
Erase size: 65 MB
CMT FLASH,MuxOneNAND area [07C40000-0BD3FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 7.828 s
Processing PPM file: rm745_102.002_312.01_CV_CH_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 54.91 KB
Erase size: 22.50 MB
CMT FLASH,MuxOneNAND area [0BD40000-0D3BFFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.062 s
Processing CNT file: rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx
[BB5,XSR 1.6] size: 2.25 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
CMT SOS*ENO block sent
Programming completed in 0.406 s
Processing CNT file: rm745_102.002_U001.000_prd.uda.fpsx
[BB5,XSR 1.6] size: 8.92 MB
Erase size: 285.50 MB
CMT FLASH,MuxOneNAND area [0D3C0000-1F13FFFF]
Programming completed in 4.484 s
Total time for flashing process(boot+erase+write) was 47.828 s
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
			 c5-00.2 treo logo
 c5-00.2 treo logo
