Kết quả 1 tới 3 của 3
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định added free,standalone,no testpoint v0.914029
    v0.914029
    - added free,standalone,no testpoint, no additional expensive "tp cables"
    alternative bypass method for following chipsets:
    db201x cid52, db2020 cid52/cid53, pnx5230 cid52/cid53
    all you need - is cheap TEST SIM CARD (or OPERATOR card)
    please, see all details about that method in THAT FAQ post.
    - fixed gdfs write problem in db201x brown phones
    - added support for loader inside phone
    (for QUICK patch/etc operations using new alternative bypass method)
    for that, run "executor" in phone (menu->games), then check in settings
    "use preloader security bypass" and then do desired operation.
    - misc other bugfixes, maybe some bugs, check and report.
    RapidShare link for v0.914029
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
    Dec 2006
    q:
    How to service db2010/db2020/pnx5230 cid52/cid53 using new setool2 (>=v0.914029) alternative bypass method ?
    what problems i can meet and how to resolved them ?
    what precautions should i follow ?
    a:
    terms:
    phone should work fine.
    red blink, white blink, etc phones are NOT supported.
    you can only use alternative bypass if your phone has supported firmware (you have BOTH rest file and bypass package)
    if yours firmware not supported, either flash supported firmware (only main part in enough) or post request on forum.
    BEFORE using new alternative bypass method you SHOULD turn phone on and install CSCA(MODEM) drivers.
    i STRONGLY recommending to browse that FAQ and READ article about com-ports growth - there is EXTREMLY helpful file,which
    prevents discovering of same phone models as new devices.
    if you are capable user, you can edit .inf files of CSCA(MODEM) drivers - we only need to install
    Sony Ericsson Device XXX bus driver and Sony Ericsson Device xxx USB WMC Modem - all other devices is not needed.
    that will help you to save comport numbers.
    important! if your phone had unsupported firmware and you flashed main part (all parts) of supported - you MUST power on phone, so phone will update new firmware info.
    because of way new alternative bypass method works, you need
    TEST SIM card (mcc/mnc 00101) or OPERATOR SIM card. (you must be able browse phone menu,etc)
    supported following models:
    db2012 cid52 - normal CID52 phones (w200,w300), abnormal CID52 phones (k310,k510,w810,z550)
    db2020 cid52/cid53 phones
    pnx5230 cid52/cid53 phones
    supported operations:
    unlock via patch, all additional things that setool2 can provide.
    YOU AGAIN NEED REST FILES !!!! FOR ALL MODELS, WHICH ARE SUPPORTED FOR ALTBYPASS !!!
    GET THEM FROM SUPPORT SITE OR DO IT YOURSELF
    Procedure of new alternative security bypass :
    1. select correct phone model
    2. go to settings tab,
    3. check BOTH "signed mode (using server)", "enable alternative security bypass", that is required
    4. optionally, check "unlock after flash", "patch otp<>gdfs check in firmware"+"allow to change IMEI when unlocking" (read precautions)
    5. optionally, check "complete phone after flash" (i recommend use custpacks)
    6. go back to semc tab
    7. if you need, add main+fsimage+custpack (script)
    8. press desired operation
    9. when asked, disconnect phone, insert TEST SIM, power on phone fully and connect it.
    10. HOLD "C" (or "2" for w880/simular) BUTTON ALL THE TIME UNTIL PHONE REBOOTS.
    11. when asked, disconnect phone, remove battery, insert battery, then connect phone while holding corresponding button ('C' or '2' for w880). In 99% cases phone will reboot and connects automatically.
    approximate time for unlock by patch using new alternative bypass method is 160-180 seconds on one phone.
    after unlock in phone will be application called "executor"
    (menu->games->executor)
    it is leftover from unlock procedure, you should delete it ... or....
    if you run it - it will install preloader in phone and then you able to do any setool2 function without all that long steps...
    (just check "use preloader security bypass)
    precautions:
    please take care that there is NO (at least, i can't get) cid52 firmwares for following db2010 phones: k310,k510,w810,z530,z550
    luckily, k310,k510 can be flashed with w200 firmware, so we can always return them to original state.
    but it is NOT related to w810,z530,z550 phones.
    cause there is no firmwares, we can't recover them in case of error.
    because of that, one mistake with that phones - and you get deadweight.
    you have been warned.
    under mistake i mean:
    - terminated flash or anything,which prevents phone from starting up
    - changed IMEI of phone, which prevents phone from using new alternative bypass method.
    will repeat again:
    DO NOT WRITE FOREIGN IMEI IF YOU NOT HAVE BACKUP IN DB2010 CID50/51/52/53 , DB2020 CID49/51/52/53, PNX5230 CID49/CID51/CID52/CID53 PHONE
    THINK 10 TIMES BEFORE CHANGE IMEI IN W810/Z530/Z550 CID 52 PHONES
    DO NOT EVEN THINK TO MESS UP FIRMWARE IN W810/Z530/Z550 CID52 PHONES
    possible problems:
    in case of terminated flash/etc you can always return phone to life by flashing any original firmwares into them -
    and then it ready for execution again
    short info of firmwares we have and have not:
    db2012 k310 (via w200),k510 (via w200) ,w200,w300 - CID52 firmwares available.
    db201x abnormal CID52 phones Z530,Z550,W810 - NO CID52 firmwares.
    db2020 - supported CID52/CID53 firmwares available
    pnx5230 - supported CID52/CID53 firmwares available
    on "step 11" phone not connecting, but simple turning on
    due delicate bypass process such thing is possible, but that happens VERY-VERY rare.
    nothing weird happens in that case - you have 4 choices what do :
    1. terminate process (press stop) and retry from beginning.
    2. as phone powered on now, go to menu->games and run program called "executor". phone should "turn off",sometimes with white screen,sometimes not. Continue procedure then (step 11)
    3. if you run "executor",but pressed stop - go to settings, check "enable preloader security bypass" - now you can do any operation with phone, like unlock/etc.
    4. reflash phone in "signed mode" and start from step 1. (idiotic, isn't it ? )
    on step 11 setool2 stucks in loop with message "PHONE NOT READY YET", but phone is turned on okay
    well, better ask semc programmers why that happens... anyway - to solve that -
    just press "STOP" ONCE - setool2 will continue procedure.
    on step 11 i got message "CAN'T START EXECUTOR,RETRYING..."
    it is okay to have that message if phone not in "normal mode" or starting up. just switch phone to normal mode and wait.
    following firmwares are supported:
    W880
    R1JC002_CXC1250640_GENERIC_AI
    R1KC001_CXC1250640_GENERIC_AI
    R1KG001_CXC1250640_GENERIC_AI
    R6BC002_CXC1250640_GENERIC_AI
    R8BA024_CXC1250640_GENERIC_AI
    R8BC004_CXC1250640_GENERIC_AI
    R8BE001_CXC1250640_GENERIC_AI
    Z310
    R1JC002_CXC1250594_GENERIC_AL
    R1KF001_CXC1250594_GENERIC_AL
    R6BC002_CXC1250594_GENERIC_AL
    R8BA024_CXC1250594_GENERIC_AL
    R8BA024_CXC1250790_VODAFONE_AL
    W710
    R1EE001_CXC1250433_GENERIC_CH
    R1GB001_CXC1250433_GENERIC_CH
    R1JC002_CXC1250433_GENERIC_CH
    Z710
    R1EF001_CXC1250434_GENERIC_CN
    R1JC002_CXC1250434_GENERIC_CN
    K510
    R4EA031_CXC1250231_GENERIC_CO
    R4GC010_CXC1250231_GENERIC_CO
    W850
    R1ED001_CXC1250200_GENERIC_CY
    R1GB001_CXC1250200_GENERIC_CY
    R1JC002_CXC1250200_GENERIC_CY
    R1JG001_CXC1250200_GENERIC_CY
    R1KC001_CXC1250200_GENERIC_CY
    R1KG001_CXC1250200_GENERIC_CY
    K310
    R4DA044_CXC1250466_GENERIC_DO
    R4EA031_CXC1250466_GENERIC_DO
    R4GC010_CXC1250466_GENERIC_DO
    r4da044_CXC1250472_ORANGE_DO
    W830
    R1JC002_CXC1250705_GENERIC_EA
    R1JC002_CXC1250713_CMCC_EA
    R1KG001_CXC1250705_GENERIC_EA
    R1KG001_CXC1250710_CHINA_EA
    K790
    R1CC003_CXC1250477_DEV_EV
    R1EG001_CXC1250477_GENERIC_EV
    R1GB001_CXC1250477_GENERIC_EV
    R1JC002_CXC1250477_GENERIC_EV
    R1JG001_CXC1250477_GENERIC_EV
    R1KC001_CXC1250477_GENERIC_EV
    R1KG001_CXC1250477_GENERIC_EV
    R8BC004_CXC1250477_GENERIC_EV
    R8BF003_CXC1250477_GENERIC_EV
    W660
    R6AD001_CXC1250446_GENERIC_FY
    R6BC002_CXC1250446_GENERIC_FY
    R8BB001_CXC1250446_GENERIC_FY
    R8BE001_CXC1250446_GENERIC_FY
    W810
    R4CE012_CXC1250316_GENERIC_HN
    R4CK003_CXC1250316_GENERIC_HN
    R4EA031_CXC1250316_GENERIC_HN
    R4GC010_CXC1250316_GENERIC_HN
    r4db005_CXC1250316_GENERIC_HN
    W300
    R4EA031_CXC1123260_GENERIC_JE
    R4GG001_CXC1123260_GENERIC_JE
    R9A031_CXC1123260_GENERIC_JE
    R9A035_CXC1123260_GENERIC_JE
    R9A036_CXC1123260_GENERIC_JE
    W350
    R10BA015_1204-3117_GENERIC_JH
    W580
    R6BC002_CXC1123362_GENERIC_LA
    R8BA024_CXC1123362_GENERIC_LA
    R8BE001_CXC1123362_GENERIC_LA
    W380
    R10BA015_1201-4421_GENERIC_LE
    R9BA023_1201-4421_GENERIC_LE
    R9BB001_1201-4421_GENERIC_LE
    K550
    R1JD001_CXC1250669_GENERIC_LI
    R1KC001_CXC1250669_GENERIC_LI
    R1KG001_CXC1250669_GENERIC_LI
    R6BC002_CXC1250669_GENERIC_LI
    R8BA024_CXC1250669_GENERIC_LI
    S500
    R6AC003_CXC1123326_GENERIC_LY
    R6BC002_CXC1123326_GENERIC_LY
    R6BC002_CXC1123460_CHINA_LY
    R8BA024_CXC1123326_GENERIC_LY
    R8BE001_CXC1123326_GENERIC_LY
    W200
    R4GB001_CXC1250719_GENERIC_ME
    R4GC012_CXC1250719_GENERIC_ME
    R4GH001_CXC1250719_GENERIC_ME
    R4HA014_CXC1250719_GENERIC_ME
    R4JA011_CXC1250719_GENERIC_ME
    Z555
    R9BB001_1202-6764_GENERIC_MG
    R10BA015_1202-6764_GENERIC_MG
    R9BA023_1202-6764_GENERIC_MG
    Z550
    R6BA033_CXC1250583_GENERIC_ML
    R6CA009_CXC1250583_GENERIC_ML
    R6GA004_CXC1250583_GENERIC_ML
    Z530
    R6DA001_CXC1250454_GENERIC_MU
    r6ac001_CXC1250454_GENERIC_MU
    r6ba030_CXC1250454_GENERIC_MU
    V630/K618
    R1JC002_CXC1250556_VODAFONE_MW
    R1JE001_CXC1250556_VODAFONE_MW
    Z610
    R1ED001_CXC1250546_GENERIC_MY
    R1EJ001_CXC1250546_GENERIC_MY
    R1GB001_CXC1250546_GENERIC_MY
    R1JC002_CXC1250546_GENERIC_MY
    R1JG001_CXC1250546_GENERIC_MY
    R1KH001_CXC1250546_GENERIC_MY
    W610
    R1JD001_CXC1250747_GENERIC_NA
    R1JE001_CXC1250747_GENERIC_NA
    R1KC001_CXC1250747_GENERIC_NA
    R1KG001_CXC1250747_GENERIC_NA
    R6BC002_CXC1250747_GENERIC_NA
    R8BA024_CXC1250747_GENERIC_NA
    K530
    R6BC002_CXC1250912_GENERIC_NC
    R8BB001_CXC1250912_GENERIC_NC
    R8BE001_CXC1250912_GENERIC_NC
    K810
    R1KC001_CXC1250811_GENERIC_SM
    R1KG001_CXC1250811_GENERIC_SM
    R6BC002_CXC1250811_GENERIC_SM
    R8BA024_CXC1250811_GENERIC_SM
    R8BE001_CXC1250811_GENERIC_SM
    R8BF003_CXC1250811_GENERIC_SM
    T650
    R8BB001_1200-2562_GENERIC_SN
    R8BC004_1200-2562_GENERIC_SN
    R8BE001_1200-2562_GENERIC_SN
    K610
    R1ED001_CXC1250374_GENERIC_TH
    R1GB001_CXC1250374_GENERIC_TH
    R1JC002_CXC1250374_GENERIC_TH
    R1JG001_CXC1250374_GENERIC_TH
    R1KC001_CXC1250374_GENERIC_TH
    R1KG001_CXC1250374_GENERIC_TH
    R8BA024_CXC1250374_GENERIC_TH
    K770
    R8BA024_1201-7587_GENERIC_VI
    R8BC004_1201-7587_GENERIC_VI
    R8BE001_1201-7587_GENERIC_VI
    K800
    R1ED001_CXC1250210_GENERIC_WI
    R1GB001_CXC1250214_CHINA_WI
    R1JC002_CXC1250210_GENERIC_WI
    R1JG001_CXC1250210_GENERIC_WI
    R1KC001_CXC1250210_GENERIC_WI
    R1KG001_CXC1250210_GENERIC_WI
    R8BA024_CXC1250210_GENERIC_WI
    R8BC004_CXC1250210_GENERIC_WI
    R8BF003_CXC1250210_GENERIC_WI
    Technical hungphongmobile™'s Avatar
    Mar 2007
    www.hungphongmobile.vn
    v0.914030
    - "complete after flash" was broken when using new
    "alternative security bypass" mode. fixed
    - "use preloader bypass mode" not allowed
    "unlock" operations. fixed
    - memory overrun was present, which sometimes
    prevents phones from booting. fixed.
    DD HÙNG PHONG 35 BẠCH ĐẰNG THỊ XÃ BÀ RỊA TỈNH
    BÀ RỊA VÙNG TÀU :MỞ MẠNG .CHUYỂN HỆ .SỦA CHỬA
    064717676:0918885353
  1. Cyclone Box FREE and STANDALONE Broadcom Hash Read
    By thanhtunggialai™ in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 08-12-2011, 13:40
  2. Cyclone Box FREE and STANDALONE Broadcom Hash Read
    By livemobi in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 08-12-2011, 00:13
  3. MXKEY SL3 FREE, UNLIMITED and STANDALONE for all OLD USERS
    By tuanwawezx in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 09-01-2011, 16:45
  4. CycloneBox FREE and STANDALONE SL3 Unlock RELEASED!!!
    By HoangThong_hotrokythuat5 in forum Cyclonebox
    Bài viết cuối: 25-12-2010, 10:11
  5. Trả lời: 0
    Bài viết cuối: 23-08-2007, 10:10
