Kết quả 1 tới 3 của 3
    Thành viên tích cực mobile_tri's Avatar
    Jun 2014
    Mặc định 311 flash báo lỗi
    Number of Image Files: 3
    Processing Image File :
    rm714__07.36.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 326
    Entry Point: 0x02D0
    Page Format : -1
    MAX PAGE : 0x00020000
    rm714__07.36.ppm_v
    CMT Type : BB5
    Number of Blocks : 106
    Entry Point: 0x0158
    Page Format : -1
    rm714__07.36.image_v_059F7Q0
    CMT Type : BB5
    Number of Blocks : 728
    Entry Point: 0x0189
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000003
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010007
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 03032108
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00001051
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00001060
    4 PUBLIC_ID 12
    ID DWORD 0 : E85E0000
    ID DWORD 1 : FFFB3C40
    ID DWORD 2 : C7E1CB82
    ID DWORD 3 : 18A83C0A
    ID DWORD 4 : 24822DE1
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 2CAC45E2
    CRC 1 : 3BC33C8B
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0020 ->
    Device ID : 0040 -> Type not in database
    Revision ID : 0131
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Revision ID : 0131
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 355193056068525
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI : 355193056068525
    PRODUCT CODE : 059F7M4
    WLAN ID : B0:35:8D:A3:6F:04
    BLUETOOTH ID : B0:35:8D:A22:C4
    PUBLIC_ID : E85E0000FFFB3C40C7E1CB8218A83C0A24822DE1
    PAPUB_KEYS_HASH: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\355193056068525\3551930560685 25_85714.rpl
    PA PUBLIC KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    Reading : ISA-USER... OK!
    PHONE FIRMWARE VERSION:
    V 07.36 16-05-13 RM-714 (c) Nokia
    Flash File Version:
    Your Flash Files are OLD. You need firmware version
    or NEWER. Please Download NEW FIRMWARE VERSION!!!
    FlashInfo.RestartMode : Test Mode
    Flashing Failed....
    Booting/Flashing Failed...
    Please Try Again...
    Cần ae giúp
    May 2014
    thái bình-hải dương
    bác kiếm file chuẩn nhé.file bằng ver hoặc cao hơn nếu file thấp ver hơn khi flash nó sẽ báo lỗi.
    thaibinhgsm@yahoo.com
    call 0976650774
    Jun 2014
    tks bác . Reset lại máy tính chạy ok
