Release Date: January 30, 2015
Firmware Version Required : 11.0.10
ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit)
ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit)
[New ATF Box Firmware]
LogiCore 11.0.10
* Added FIRST-IN-THE-WORLD eMMC Test Point Finder/Locator Engine
* Improved eMMC Read/Write Speeds
* Added more VCCIO Level Adjustments options
[ATF Plus]
* Added Find eMMC TP - eMMC Test Point Finder 1.0
* Absolutely FIRST-IN-THE-WORLD Feature which allows you to Locate the eMMC
Programming Test Points WITH-OUT Removing the eMMC Chip from the PCB.
* Supports Qualcomm, Marvell PXA and Broadcom CPU for CMD and CLK Detection
* Supports Exynos for CLK Test Point Detection
* Other CPUs will be supported soon
For More Information, Check here:
===>>> ATF eMMC Test Point Finder Tutorial <<<===
[GENERAL UPDATES]
--> Added all variants of Microsoft Lumia 330 in Nokia.ini
ATF JTAG 1.0.13 Build 5935
Firmware Version Required : LogiCore 11.0.10
Change Log
--> Uses new ATF Firmware LogiCore 11.0.10
--> Adjusted eMMC Read/Write Timeouts
			 ATF EMMC Pin Finder v11.90 Update!! 30 JAN 2015!!
