    Thành viên chính thức minhquang09's Avatar
    Mặc định asha 200 trắng màn hình
    lâu không làm loại này hôm nay em update lên 11.95 cho khách nó trắng màn hình. giờ em đã chạy lại nhiều Pm khác vẫn trắng, để một lúc mở khóa thì lên được màn hình rồi lại sọc , các bác xem dùm em cái
    card found: A1B5CCE8
    registered to: CycloneBox
    Connect phone on selected interface...
    Core : v1.51 , FlashEngine : v1.8
    Selected FlashSettings : Manual
    Check FlashFiles, Please, wait...
    Files Set for Flashing :
    MCU : 3DA508C0_rm761__11.95.mcusw
    PPM : B5363C05_rm761__11.95.ppm_bg
    PPM2 : B5363C05_rm761__11.95.ppm_bg
    CNT : 9489921B_rm761__11.95.image_bg_059N5N8
    Flashing phone now...
    Check files done...
    -> SWversion check skipped : Dead mode selected
    Dead Mode is Selected
    Waiting for USB device...
    -> If Windows say "Unrecognized device" - just reinsert battery
    -> If flashing freeze - reinsert cable and try again
    --- Press phone's power button or insert charger! ---
    Connection opened successfully
    DBG : F00A1FB300020303010100FF
    CPUID : XGOLD 213
    2nd boot Ok, 01
    2nd ready, AA
    Sending Algo
    Algo sent Ok
    BL : Quantum_Bootloader_10.46_M1S1
    Speed accepted, use 6.500.000
    FLASHID : 89008289
    FLIC conf set, RST set
    Boot done!
    Backup enabled, will read all certificates
    Reading CCC
    Reading HWC
    Reading NPC
    IMEI 1 : 359345044408801
    IMEI 2 : 359345044408819
    PCcode : 059K957
    NPC Certificate saved...
    CCC Certificate saved...
    HWC Certificate saved...
    RPL saved : E:\Tai Lieu Sua Chua\Nokia\Ket Noi\Beks\Backup\Cert\359345044408801_3593450444088 19_2nd_XG213_CRT.rpl
    ===Flashing [MCU]===
    File : 3DA508C0_rm761__11.95.mcusw
    Image : rm761__11.95.mcusw_ebl_psi.fls
    Cert block found, sending....
    Cert sent
    Found 5 region(s)
    Processing Region 1/5
    Erase , Start : 0x40000000 , Len : 0x00020000
    Erasing, wait ...
    Erase done, time : 00:00:00
    Write , Start : 0x40000000 , Len : 0x00020000
    Flashing , wait ...
    Region flash done, time : 00:00:00
    Processing Region 2/5
    Erase , Start : 0x40040000 , Len : 0x00020000
    Erasing, wait ...
    Write , Start : 0x40040000 , Len : 0x00020000
    Flashing , wait ...
    Processing Region 3/5
    Erase , Start : 0x40060000 , Len : 0x00100000
    Erasing, wait ...
    Erase done, time : 00:00:07
    Write , Start : 0x40060000 , Len : 0x00100000
    Flashing , wait ...
    Region flash done, time : 00:00:01
    Processing Region 4/5
    Erase , Start : 0x40280000 , Len : 0x01800000
    Erasing, wait ...
    Erase done, time : 00:01:56
    Write , Start : 0x40280000 , Len : 0x01800000
    Flashing , wait ...
    Region flash done, time : 00:00:33
    Processing Region 5/5
    Erase , Start : 0x43E20000 , Len : 0x00040000
    Erasing, wait ...
    No write data, skip
    ===Flashing [PPM]===
    File : B5363C05_rm761__11.95.ppm_bg
    Image : package_bg.ppm_ebl_psi.fls
    Cert sent
    Found 1 region(s)
    Processing Region 1/1
    Erase , Start : 0x41A80000 , Len : 0x00740000
    Erasing, wait ...
    Erase done, time : 00:00:24
    Write , Start : 0x41A80000 , Len : 0x005FE538
    Flashing , wait ...
    Region flash done, time : 00:00:07
    ===Flashing [CNT]===
    File : 9489921B_rm761__11.95.image_bg_059N5N8
    Image : package_bg_059N5N8.image.fls
    Cert sent
    Found 2 region(s)
    Processing Region 1/2
    Erase , Start : 0x421C0000 , Len : 0x01C60000
    Erasing, wait ...
    Erase done, time : 00:01:35
    Write , Start : 0x421C0000 , Len : 0x00F60000
    Flashing , wait ...
    Region flash done, time : 00:00:20
    Processing Region 2/2
    Erase , Start : 0x43E60000 , Len : 0x000E0000
    Erasing, wait ...
    Erase done, time : 00:00:06
    No write data, skip
    Flashing done!
    Total flash time : 00:05:16
    Reboot phone now...
    Reading Phone Info....
    Connected phone - Nokia 200
    Software Info: V 11.95 19-12-12 RM-761 (c) Nokia
    IMEI: 359345044408801
    PPM version : V 11.95 19-12-12 RM-761 (c) Nokia BG
    Product code: 059J5S9
    Checking...
    SimLock status : SimLock is Ok
    Security status : Security is Ok
    Read Info Done!
    Settings After Flash Defaults...
    ProductTuneSet...OK!
    SwUpgradeSet...OK!
    Resetting LifeTimer
    Reset Done!
    Checking User Certificates...
    Total - 43 certs
    Data exist, skip certificate repair...
    Battery voltage is enough for start
    Set phone to Normal mode...
    AfterFlash operations done ;D
    Done!
    Elapsed: 00:05:57
    Thành viên tích cực Tùng Nguyễn GSM's Avatar
    Aug 2013
    thay màn chưa a trai
    Liên hệ :0963761362 - Bé Tùng Xe Ôm Vip 24t
    https://www.facebook.com/tungvannguyen.construction
    máy đang sài bình thường , lâu lâu mất sóng khởi động lại sóng gió bình thường. up xong thế. giờ để một lúc mở thì hiển thị mờ mờ được 1 phút thì trắng lại. Đang nghĩ là PM n ên nhờ anh em xem giúp
    May 2010
    Thủ Đức - TP HCM
    cái dòng 200 này bệnh truyền kíp là lổi cặp. con này k khác j đâu. tìm cách trả máy cho đở mất thời jan. gặp rất nhìu rồi toàn trả vì lổi cặp.
    Còn anh em nào có giải pháp không bác ơi giờ chỉ có thể trả máy khác thôi! Như thế thiệt hại lắm
    May 2010
    Thủ Đức - TP HCM
    vậy có nhớ fw ban đầu của máy k. dùng ATF dowgrang nó về fw cũ thử dc k.
