Octoplus/Octopus Box LG Software v.2.0.4 Release Notes:
🐙 Added support for the following models:
- AS323 - added world's first Direct Unlock, Repair IMEI, Read/Write NVM, Read Security, Write Security backup, Read/Write QCN, Repair BT Address, Repair Wi-Fi,
- AS323 - Write Firmware (in Test Mode), Read Full Flash (Dump NAND), Reset Screen Lock (thanks to Mr. Ariel Sellanes).
- LS751 - added world's first Repair MEID, Repair AKEY / SSD_A / SSD_B / OTKSL / SPC, Read/Write/Repair NVM, Read/Repair Security, Write Security backup,
- LS751 - Read/Write QCN, Read/Write PRL, Repair BT Address, Repair Wi-Fi, Write Firmware (in Test Mode), Read Full Flash (Dump NAND).
- D625 - added Direct Unlock (without root, Test Mode), Repair IMEI (without root), Read Full Flash, Reset Screen Lock.
- D410 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D410H - added Direct Unlock and Repair IMEI (A/B) without Root.
- D410HN - added Direct Unlock and Repair IMEI (A/B) without Root.
- D618 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D724 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D728 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D729 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D856 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D857 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D858 - added Direct Unlock and Repair IMEI (A/B) without Root.
- D858HK - added Direct Unlock and Repair IMEI (A/B) without Root.
- D859 - added Direct Unlock and Repair IMEI (A/B) without Root.
🐙 Added Write Firmware (now is possible to convert for flashing KDZ, DZ and TOT files) for the listed below devices:
- H815, H815AR, H815K, H815L, H815P, H815T, H815TR,
- H630, H630D, H630I,
- H634,
- H635, H635A, H635AR, H635C,
- H636.
🐙 All supported operations are described in details in the manual ("Cable & Manual" button in Software)
More info and discussion are HERE
___________________________________
WBR,
Octoplus Box Team
