Octoplus/Octopus Box LG Software v.2.0.6 Release Notes:🐙 Added support for the following models:
- H815 - added Direct Unlock, Repair IMEI (no need to root the device)
- H815AR - added Direct Unlock, Repair IMEI (no need to root the device)
- H815K - added Direct Unlock, Repair IMEI (no need to root the device)
- H815L - added Direct Unlock, Repair IMEI (no need to root the device)
- H815P - added Direct Unlock, Repair IMEI (no need to root the device)
- H815T - added Direct Unlock, Repair IMEI (no need to root the device)
- H815TR - added Direct Unlock, Repair IMEI (no need to root the device)
- H818 - added world's first Direct Unlock, Repair IMEI (A/B), Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
Read/Write/Repair NVM, Read/Repair Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock (no need to root the device)
- H818N - added world's first Direct Unlock, Repair IMEI (A/B), Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
- H818P - added world's first Direct Unlock, Repair IMEI (A/B), Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
- F570S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write/Repair NVM,
- F500K - added (in Test Mode) world's first Direct Unlock, Repair IMEI, Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock (no need to root the device)
- F500L - added (in Test Mode) world's first Direct Unlock, Repair IMEI, Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
- F500S - added (in Test Mode) world's first Direct Unlock, Repair IMEI, Write Firmware, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN,
🐙 New QCN files were uploaded into the Support Area🐙 All supported operations are described in details in the manual ("Cable & Manual" button in Software)More info and discussion are HERE
____________________________________
WBR,
Octoplus Box Team
