Kết quả 1 tới 4 của 4
    Thành viên tích cực thao9x.ht's Avatar
    Nov 2013
    hương khê_hà tĩnh
    Mặc định x2_01 không bộ được
    log em nó đây
    Number of Image Files: 3
    Processing Image File :
    rm709__08.71.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 504
    Entry Point: 0x01F2
    Page Format : -1
    MAX PAGE : 0x0000E000
    rm709__08.71.ppm_mh1
    CMT Type : BB5
    Number of Blocks : 120
    Entry Point: 0x0113
    Page Format : -1
    rm709__08.71.image_mh1_059D7F8
    CMT Type : BB5
    Number of Blocks : 438
    Entry Point: 0x0147
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned
    Number of Sub Blocks 6 (0x06)
    1 SYSTEM_ASIC_ID 01
    Block Length : 17 (11)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000000
    ID DWORD 1 : 00000000
    ID DWORD 2 : 22000509
    ID DWORD 3 : 200C0000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00005361
    3 PUBLIC_ID 12
    Block Length : 21 (15)
    ID DWORD 1 : 00E63DFD
    ID DWORD 2 : A98D250B
    ID DWORD 3 : 6808CA79
    ID DWORD 4 : FD911363
    4 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    5 ROOT_KEY_HASH 14
    Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
    6 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : DE56D582
    CRC 1 : BDDE7A3A
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0010 ->
    Device ID : 0011 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0431
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg .fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 353683050122114
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI : 353683050122114
    PRODUCT CODE : 059C2X8
    BLUETOOTH ID : F8:5F:2A:BF0:67
    PUBLIC_ID : 0000000000E63DFDA98D250B6808CA79FD911363
    PAPUB_KEYS_HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\353683050122114\3536830501221 14_10043 A.rpl
    PA PUBLIC KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    Reading : ISA-USER... OK!
    PHONE FIRMWARE VERSION:
    V 08.70 29-07-11 RM-709 (c) Nokia
    ImagePath: E:\rm_709\
    ImageFilename: rm709__08.71.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 00020000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02A00000
    Partition 3
    Start Address : 07540000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x90 (144)
    ERASE Blocks : 0x03 (3)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x2B (43)
    Device Index : 0x00
    0 : 00000000-0001FFFF
    1 : 00020000-000203FF
    2 : 00060000-012FFFFF
    3 : 01300000-01DFFFFF
    4 : 02600000-029FFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
    Successfully Erased...
    Total blocks to write : 504
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS [37955B6FC432998EF0DB240E332228384D19ED09]
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    ImageFilename: rm709__08.71.ppm_mh1
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01E00000-025FFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
    Total blocks to write : 120
    ImageFilename: rm709__08.71.image_mh1_059D7F8
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Device Index : 0x00
    0 : 02A00000-0753FFFF
    Device Index : 0x00
    Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4
    FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
    Total blocks to write : 438
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000006
    Additional Bad : 00000006
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 2
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:09
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    máy vẫn không lên nguồn.flash bằng usb .box atf
    Thành viên tích cực TÍNH-NGHI_MOBILE's Avatar
    Feb 2011
    báo done mà..đễ thêm 5-6p nó đồng bộ bạn rút cáp ra sớm quá
    01:24:33 : Total blocks to write : 728
    01:24:42 : ContinueFlash_DCT5 Complete
    01:24:42 : Continue Flash Complete : : No Error - 0 (0x00)
    01:24:42 : STATUS_REQUEST_BB5...
    01:24:43 : 1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    01:24:43 : Block Length : 0F
    01:24:43 : BB ASIC Index : 00
    01:24:43 : Device Type : 03
    01:24:43 : Device Type : 00
    01:24:43 : Num Bad Blocks : 00000000
    01:24:43 : Additional Bad : 00000000
    01:24:43 : Correctable ECC : 00000000
    01:24:43 : FlashInfo.RestartMode : 2
    01:24:43 :
    01:24:43 : Flashing Done...
    01:24:43 : Total Flashing Time (Erase + Flashing) : 00:00:15
    01:24:43 : (Booting time is NOT Included)
    01:24:43 :
    01:24:43 : Waiting for Phone to Start-Up..(Max 150 seconds)
    01:24:43 :
    rút cáp sớm nè(nhưng máy vẫn ok)
    lyvant@yahoo.com.vn 0934030540
    Nov 2013
    hương khê_hà tĩnh
    chờ hơn thế mà vẫn không lên nguồn bác ah
    Thành viên chính thức ducmobilegsm's Avatar
    Jan 2015
    ban đầu nó bị sao a ơi ít thông tin quá
