Octoplus/Octopus Box LG Software v.2.0.7 Release Notes:🐙 Added support for the following models:
- H520 - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- H520F - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- H520G - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- H520Y - added world's first Direct Unlock, Repair IMEI, Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- H522 - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- H522F - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- H522Y - added world's first Direct Unlock, Repair IMEI (A/B), Read Codes, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair EEPROM, Read Full Flash, Reset Screen Lock, Read Info
- F510K - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
- F510L - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
- F510S - added world's first Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write QCN, Read/Write NVM, Read Security, Write Security Backup, Read Full Flash (Dump NAND), Reset Screen Lock
🐙 All supported operations described in details in the manual ("Cable & Manual" button in Software)More info and discussion are HERE
_______________________________________
WBR,
Octoplus Box Team
