ddasdasdas
    Nov 2010
    Mặc định Octoplus/Octopus Box LG Software v.2.1.1 - LG LS991, LG LS996 and many more! 🐙
    Octoplus/Octopus Box LG Software v.2.1.1 Release Notes:
    🐙 Added support for the following models:
    - LS991 - added world's first Direct Unlock (tested on ZV5 firmware), Repair IMEI,
    Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Repair 3G/4G, Read/Write QCN, Repair MEID, Repair AKEY / SSD_A / SSD_B / OTKSL / SPC,
    Repair MCC / MNC / MIN1 / MIN2 / Home SID / Home NID / Mobile Number, Read / Write PRL, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - LS996 - added world's first Direct Unlock (tested on ZV4 firmware), Repair IMEI,
    - F540K - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN,
    - F540L - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN,
    - F540S - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN,
    - H811 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - H631 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - MS631 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write/Repair NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - H345 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - MS345 - added Repair IMEI, Repair BT Address, Repair Wi-Fi Address, Read/Write NVM, Read/Write QCN, Read Security, Write Security Backup, Read Full Flash (dump NAND), Write Firmware, Reset Screen/FRP Lock
    - H810 - added Write Firmware
    - H812 - added Write Firmware
    🐙 New QCN files were uploaded into the Support Area
    🐙 All supported operations described in details in the manual ("Cable & Manual" button in Software)
    More info and discussion are HERE
    _______________________________________________
    WBR,
    Octoplus Box Team
  2. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Tuấn Kiệt (14-11-2015)
