Falcon Box
Next Generation Mobile Tool
iNNOVATED BY MIRACLE TEAM
FREE FIRE HTC PACK
Version 1.1 (7th May 2016)
Thanks for Using Miracle Team Product “Falcon Box & Falcon Miracle Key Edition”
To make the Better Mobile Repair Solution for you, We bring to the Updates regularly.
Every Update of our software include improvements for new functions and better service
and reliability.
HTC FIRE PACK v1.0 Highlights
# Generic Read Codes / Direct Unlock for HTC MTK Devices.
# Read Simlock Status.
# HTC MTK CID Changer.
# HTC FRP Unlock* Beta.
# Added 111 Different Themes (Right Click on top to change).
[The Information Section] 1.0 Revision
(Possible to get all software and hardware information like)
# OTA.
# Factory Build.
# CPU Specification.
# Default.
# Nand IC.
# Original Equipment Manufacturer.
# Kernel.
# System.
# Can show similar devices and hard reset guides.
# Can Detect Model automatically.
[S-OFF Section]
# Ability to Disable H-boot Security (S-OFF) for this models: (only in normal mode)
(Radio lock not change).
[And Super CID for]
# HTC One s (S4 series).
[Root Tool]
# Temporarily and Permanent Root by 6 Different Method in Normal Mode.
[GoldCard Section]
# Ability to create Goldcard (New and Old HTC Phone) and write it and store
it on computer (stand alone – so you can flash any device without need s-off) (World’s First).
# Ability Direct Gold-card writing
on SD Card for PC.
[Easy Update & Recovery Section]
# Downgrade and Upgrade Original ROM available by one click (no need to select files for
supported models) (for who users installed Full Setup) (World’s First).
# Custom Recovery Installation with one click (no need to select the files under supported models)
# Custom ROM Installation with support for all languages with one click (no need to select the
files under supported models)(for who users
# Custom Kernel Installation with one click (no need to select the files under
supported models)(for who users installed Full Setup) (World’s First).
[Manual Flash & Dump,Erase]
# Manual Flash, files can be Boot – Recovery – System – Userdata – H-boot.
# Manual Flash in normal mode, files can be Misc – Recovery (World’s First).
# Dump possible from the system partition and display the operating system map (World’s First).
# Auto Flash ZIP/OTA Package in Recovery mode (World’s First).
# Partition dumping for All partitions and All Android devices in Normal&Recovery mode (HTC,Samsung,LG,Motorola,ZTE).
[Advance Function Section]
# Change CID – MID – Serial (in-state S-OFF).
# Possible to boot the phone with the desired file.
# Erase all the possible partitions (World’s First).
# Change main versions with manual method just one click (for downgrade – no need S-OFF) (World’s First)
# Change main versions with auto method just one click (for downgrade – no need S-OFF) (World’s First).
# Ability to fix USB Brick (World’s First).
[Application Section]
# Ability to install APK software (Mass Installation) and display file info with ability to the
install on external memory.
# Uninstall application (apk) on the operating system.
[Misc Section]
# Google Account Bypassing just with one click (Normal and Custom Recovery) (World’s First).
# Ability to change phone mode automatically (HBoot – Recovery – Fastboot – Ruu mode).
# Possible activation App2SD WITHOUT ROOT (for installing software on the External
Storage – version 2.1 and up) (World’s First).
# Wipe off the System – Cache – UserData.
# Possibility of temporarily and permanently activate the USB Debug (for HTC mobile phones ) (World’s First).
# Ability to remove Password – Pin – Pattern without losing user data(all brands) (World’s First).
# The ability to Easy and Fast unlock the boot loader for HTC.
# The ability to Easy and Fast unlock the boot loader for Motorola.
# The ability to Easy and Fast unlock the boot loader for Google.
# The ability to Easy and Fast unlock the boot loader for Sony.
# The ability to Easy and Fast unlock the boot loader for Sony Ericsson.
[MTK HTC Devices Supported]
# Added Write Scatter.
# Added Factory Flash Support for old Scatters Type.
# Added Partition Dumping for Following MTK Chip sets.
# Added Format and Erase for MTK Devices.
# Added Scatter (old and new type) creator on DA Mode (Boot Mode) for MTK Devices.
# Added CPU Auto Detection for MTK devices.
# MT6572 # MT6573 # MT6577 # MT6582
# MT6589 # MT6592 # MT6595 # MT6732
# MT6735 # MT6752 # MT6753 # MT6795
Lets Talk about Miracle Falcon Fire HTC Pack 1.1 Link..
Br [SV] Miracle Team...
