Octoplus/Octopus Box LG Software v.2.4.8 Release Notes:🐙 Added support for the following models:
- K100TR - added world's first Direct Unlock, Read Codes, Repair IMEI, Reset FRP, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
- K100 - added Direct Unlock, Read Codes, Repair IMEI, Reset FRP, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
- K100DS - added Direct Unlock, Read Codes, Repair IMEI (A/B), Reset FRP, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
- K100E - added Direct Unlock, Read Codes, Repair IMEI, Reset FRP, Read/Write EEPROM, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address, Read Info
- K550 - added Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Write Security, Reset FRP, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address
- K550BN - added Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Write Security, Reset FRP, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address
- K550BNGO1 - added Repair IMEI, Read/Write QCN, Read/Write NVM, Read/Write Security, Reset FRP, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address
- K600 - added world's first Direct Unlock, Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address
- K600Y - added world's first Direct Unlock, Repair IMEI (A/B), Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address
- K330 - added Reset FRP
- MS330 - added Reset FRP (thanks to Mr. ..::MR99::..)
- MS550 - added Reset FRP (thanks to Mr. Moody69)
- D850 - improved Reset Kill Switch
- D850PR - improved Reset Kill Switch
🐙 Added Reset Security operation for the following models:
- D850, D850PR
- D851, D851TN, D851WH
- D852, D852G
- D855, D855AR, D855K, D855P, D855TR, D855V
- D856, D857
- D858, D858HK
- D859
🐙 Added ability to write original LG versions of firmware («*.tot», «*.kdz») for most Qualcomm-based devices, without converting into *.oct format (new and old firmware types are supported):
- LG G5 (H840x, H845x, H850x, H860x)
- LG X Style (K200x)
- LG X View (K500x, F650x)
- LG K10 (K420x, F670x)
- LG K7 (K332, K371, K373)
- LG K4 (K120, K121)
- LG Stylus 2 (K520x, F720x, K540)
- LG Stylus 2 Plus (K530x, K535x)
- LG V10 (H960x, H961x, H962x, F600x)
- LG G4 (H810x, H815x H818x, F500x)
- LG G4 Stylus (H630x, H634, H635x)
- LG G4s (H731x, H734x, H735x, H736x)
- LG G4c (H525x, F570s)
- LG G Flex 2 (H950x, H955x, F510x)
- LG Joy (H220x, H221x, H222x)
- LG Leon (H340x, H342x)
- LG Spirit (H440x, H442x)
- LG G2 (D800x, D801x, D802x, D803, D805, D806, F320x)
- LG G2 Mini (D610x, D620x, D618)
- LG G Flex (D950x, D951, F340x)
- LG G3 (D850x, D851x. D852x, D855x, D856, D857, D858x, D859, VS985, F400x)
- LG G3 Vista (D631)
- LG G pro 2 (D830, D838, F350x)
- LG G3 Stylus (F430x)
- LG G3 Beat (D722x, D723x, D724x, D725x, F470x)
- LG L Fino (D290x, D295x)
- LG L90 (D400x, D405x, D410x, D415x)
- LG L80 (D380, D385)
- LG L70 (D320x, D321, D325x)
- LG L65 (D285x)
- LG L40 (D160x, D165x, D170, D175x)
- LG L35 (D150x, D157)
- LG F70 (D315x, F370x)
- LG F60 (D390x, D392x)
🐙 Improved Reset FRP for devices with new versions of firmware (tested on G5 series).
This solution should also work with other devices with new versions of firmware, we will be grateful for your tests and reports.
🐙 All supported operations described in details in the manual ("Cable & Manual" button in the software)More info and discussion are HERE
_______________________________________________
WBR,
Octoplus Box Team
