Added world’s first support for LG G Pad 7.0 LTE, V20 Dual SIM (H990DS), support for V20 (One SIM) series, LG X Power and more.
Octoplus/Octopus Box LG Software v.2.5.1 Release Notes:🐙 Added support for the following models:- UK410 - added world’s first Direct Unlock, Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write Security, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address (thanks to mr. Naplyon).
- H990DS - added world’s first Direct Unlock, Repair IMEI (A/B), Write Firmware, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash.
- K210 - added Direct Unlock, Repair IMEI, Reset FRP, Read/Write QCN, Read/Write NVM, Read/Write/Reset Security, Read Full Flash, Repair BT Address, Repair Wi-Fi MAC Address.
- H990 - added Direct Unlock, Repair IMEI (A/B), Write Firmware, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash.
- F800L - added Direct Unlock, Repair IMEI (A/B), Write Firmware, Read/Write QCN, Read/Write NVM, Read/Reset Security, Read Full Flash.
🐙 Improved "Write Firmware" operation for firmwares with signatures in "*.kdz" format.🐙 All supported operations described in details in software manual ("Cable & Manual" button in the software).Note: Write security backup function doesn't work for LG G5 and V20 models with latest firmware versions (firmwares with signatures). If you'll encounter any problem during Unlock or IMEI Repair operations - you won't be able to restore the phone to it's initial state, so proceed at your own risk. We're working on this issue and will release a solution as soon as we can.
More info and discussion are HERE
_______________________________________________
WBR,
Octoplus Box Team
