Trang 1 của 8 1 2 3 4 5 6 7 8 CuốiCuối
Kết quả 1 tới 10 của 77
    Super Moderator namnhatrang's Avatar
    Jan 2007
    Mặc định AVENGER box update new
    Avengers Box v1.4 Update Released - FRP Unlock All New Samsung & SPD 10-11-2015
    [​IMG]
    Samsung- All New ModelsFRP (Factory Reset Protection)
    Lock Remove - One Click - Safe - No Root - No ADB - No special Cable - etc..
    Samsung SPD
    SM-G110B- Direct Unlock Including Hard Locked Phones.
    SM-G110H- Direct Unlock Including Hard Locked Phones.
    SM-G110M- Direct Unlock Including Hard Locked Phones.
    SM-G130E- Direct Unlock Including Hard Locked Phones.
    SM-G130H- Direct Unlock Including Hard Locked Phones.
    SM-G130HN- Direct Unlock Including Hard Locked Phones.
    SM-G130M- Direct Unlock Including Hard Locked Phones.
    SM-G318H- Direct Unlock Including Hard Locked Phones.
    SM-G355H- Direct Unlock Including Hard Locked Phones.
    SM-G355HN- Direct Unlock Including Hard Locked Phones.
    SM-G355M- Direct Unlock Including Hard Locked Phones.
    What is FRP?
    Android Factory Reset Protection (FRP) is a new feature to protect your device which has been added to several Samsung devices that are running Android OS 5.1 or higher.
    This feature allows you to set up your device to prevent other people from using it if it's been reset to factory settings without your permission. For example, if your device is lost, stolen, flashed, or wiped, only someone with your Google account or screen lock information can perform a factory data reset and use the device.
    When a device is factory reset, the device will not be able to be setup without the user entering the Google Account associated with the device (for hard reset) or screen lock information (for reset in Settings menu).
    Important! You must set up a Google account in order to utilize the FRP feature. It is highly recommended that you set a secure screen lock on your device.
    How do i know if my device have FRP LOCK Feature?
    The availability of the FRP feature is dependent on your carrier and device model. To see if you have the FRP feature, follow these steps:
    From the Home screen, touch Apps -> Settings -> Lock screen and security. Note: If you have a Galaxy S6, touch Apps -> Settings -> Lock screen and security -> Find My Mobile.
    If the Reactivation Lock feature is not shown, then you have the FRP feature.
    Download From:
    Avengers Box/DownloadArea
    OFFICIAL WEBSITE
    AVENGERS BOX
    __________________
    BR
    NCK Team
    Powered By Fast Unlocking Ltd.
    Jan 2007
    Avengers Box Android MTK Module v0.2.4 Update [20/12/2015]
    Added:
    Huawei Ascend G715-U10- Unlock/IMEI/Flashing/Format/etc..
    Alcatel OT-9005X- Unlock/Flashing/Format/etc..
    Coolpad 7295c- Unlock/IMEI/Flashing/Format/etc..
    Avvio 777- Unlock/IMEI/Flashing/Format/etc..
    AZUMI A55T- Unlock/IMEI/Flashing/Format/etc..
    Bmobile Ax570- Unlock/IMEI/Flashing/Format/etc..
    Bitel B8409- Unlock/IMEI/Flashing/Format/etc..
    Bitel B8408- Unlock/IMEI/Flashing/Format/etc..
    Blu STUDIO 5.0K- Unlock/IMEI/Flashing/Format/etc..
    BLU STUDIO 5.0 II D532u- Unlock/IMEI/Flashing/Format/etc..
    BLU LIFE PLAY 2- Unlock/IMEI/Flashing/Format/etc..
    Verykool S4006- Unlock/IMEI/Flashing/Format/etc..
    Lanix S670- Unlock/IMEI/Flashing/Format/etc..
    Q-Mobile A300- Unlock/IMEI/Flashing/Format/etc..
    Q Mobile Noir x6- Unlock/IMEI/Flashing/Format/etc..
    ZTE V769M- Unlock/IMEI/Flashing/Format/etc..
    ZTE Meo Smart A75- Unlock/IMEI/Flashing/Format/etc..
    Avengers DownloadArea
    Official website:
    AVENGERS BOX
    NO THNX POSTS OR SPAM POSTS PLEASE, ONLY DISCUSSION REGARDS THIS UPDATE OR TEST LOGS WITH RELATED MODELS.
    OFFICIAL SUCCESS STORIES:
    Huawei G730-U10 MT6582 Protected Loader IMEI Changed in Flash Mode With Avenger Box
    Very Hot Exclusive World's First Dead Preloader Repairing Done Using Simple Usb
    Dangerous Phone Of Pakistan Qmobile A290 Os 4.2.2 To 4.4.2 Upgrade Successfully Done
    Post Here successful reports with Avengers Box
    Lava iris x8 No Service is repaired after IMEI Repair with ADB Mode Exclusive with AB
    Samsung J2 ( SM-J200 ) FRP Lock Removed With Avenger Box
    Qmobile A900i CoMplete DEad ALive Suiccess
    World,s 1st Serious Cases Of Smart phones after reflash or format solution Avengerbox
    __________________
    BR
    NCK Team
    NCK Dongle - NCK Box - Cellular Codes - New Soon..
    Jan 2007
    [​IMG]
    FRP Tool
    Reset FRP MediaTek Generic [Fastboot Mode]
    Reset FRP Huawei Spreadtrum [Fastboot Mode]
    Reset FRP Motorola Qualcomm [ADB Mode]
    Reset FRP Qualcomm Generic [Fastboot Mode]
    Unlock Bootloader
    Mediatek Generic [Fastboot Mode]
    Huawei Speadtrum [Fastboot Mode]
    Qualcom Generic [Fastboot Mode]
    Spreadtrum Android (SPD)
    Repair IMEI - [DIAG Mode] - NO ROOT NO ADB
    Repair Wifi - [DIAG Mode] - NO ROOT NO ADB
    Repair BT - [DIAG Mode] - NO ROOT NO ADB
    Factory Reset - [DIAG Mode] - NO ROOT NO ADB
    Malware tools
    * Application manager for Android phones.
    This function allow to manage installed phone applications.
    Disable[freeze], enable, uninstall[not work for system packages], clear application data.
    * Added possibility to add application directly in virus database.
    For this application not need root.
    Need root only to freeze system applications.
    * Malware database manager.
    Allow to add, or delete malware entries.
    * Malware Remove.
    Malware remove read malware list from Malware DataBase and perform cleaning[deleting]
    For this function need root and busybox installed.
    Without busybox will fail on removing some malware files.
    ZTE - Unlimited Unlock Code Calculator via IMEI
    Code:
    Blade C2
    Blade L2
    V809
    Blade GLux
    Blade GPRO
    Blade Q
    Blade Q MAXI
    Blade Q MINI
    Blade X
    VTELCA - Unlimited Unlock Code Calculator via IMEI
    Code:
    N720
    F310
    V8200
    NX501
    NX402
    NX406E
    V865M
    TELEPATRIA
    CARIBE 3 FI
    TELEPATRIA 2
    Huawei Mobile - Unlimited Unlock Code Calculator
    Code:
    G7220
    Ascend Y220
    Ascend Y221
    G2800S
    Ascend G500
    Ascend 8836D
    Ascend Y600
    G3511
    G3512
    G3610
    G3620
    Ascend Y520
    Ascend Y320
    Ascend Y321
    G20
    G6005
    G6605
    G6800
    G6608
    G6210
    G6620
    G7210
    Panama
    VM720
    G5726
    G7510
    G6622
    G6151
    G3501S.America
    U2805
    G6006
    U5130-05
    G3621
    G3621L
    G3622
    F316
    Ascend Y511
    G5520
    G5521
    Ascend Y360-U23
    ORANGE - Unlimited Unlock Code Calculator
    Code:
    Orange ZILO
    ORANGE REYO
    Huawei Modems - Unlimited Unlock Code Calculator
    Code:
    E160,E156,E155,E1550,E1552,E156G,E160,E160,GE161,E 166,E169,
    E169G,E170,E172,E176,E1762,E180,E182E,E196,E226,E2 70,E271,
    E272,E510,E612,E618,E620,E630,E630+,E660,E660A,E80 0,
    E870,E880,EG162,E880,EG162,EG162G,EG602,EG602G,Vod afone K2540,
    Vodafone K3515,Vodafone K3520,Vodafone K3565,Vodafone K3520,
    Vodafone K3565,
    B260a, E122, E153, E1551, E1553, E155X, E156B, E156C, E1609,
    E160E, E160X, E1612, E1615, E1616, E1630, E1632, E166G, E1690, E1692,
    E170G, E171, E172G, E173, E1750, E1750C, E1752, E1756, E176G, E1803,
    E180G, E180S, E181, E182, E1820, E216, E219, E230, EM770,
    S4011, UMG1691, UMG181, UMG1831,E160
    E353Ws,E353Ws-2,E398,E1732,E173,
    E352,E353,E357,E362,E367,E372,E368,E398,E1732,E392 ,E1815,E1731,
    Vodafone K4510,Vodafone K4511,Vodafone K4605,Vodafone K5005,E1756,E586,E583c,
    E5332,E5332s-2,E5332s-2,E583,E3256,E585u-82,E585v2,E586e,E3131,E5331,B260,
    B260A,E5331s-2,E5832,E5776,E5776s,E3276,E589,B153 WebCube,B260,B260A,B960,
    B970,E122,E153,B153 WebCube,E155,E1550,
    E1551,E1552,E1553,E155X,E156,
    E156B,E156C,E156G,E156X,E158,E159,E159G,
    E160,E1609,E160E,E160G,E160X,E161,E1612,
    E1615,E1616,E161E,E162G,E1630,E1632,E166,
    E166G,E169,E1690,E1692,E169G,E170,E170G,
    E171,E172,E172G,E173,E173u-1,E1731,E1732,
    E1750,E1750C,E1752,E1756,E176,E1762,E176G,
    E177,E180,E1800,E1803,E180G,E180S,E181,
    E1815,E182,E1820,E182E,E1823,E1831,E188,
    E196,E216,E2010,E219,E220,E226,E22X,
    E230,E270,E271,E272,E303,E3131,E3231,
    E3256,E3272,E3276,E352,E353,E353WS,E353WS-2,
    E355,E357,E3351s-2,E3531,E5372T,E3531,E362,
    E367,E368,E369,E372,E392,E397,E398,
    E4011,E510,E5330,E5330As-2,E5330Bs-2,E5330Bs-6,E5331,
    E5331s,E5331Ws-1,E5332,E5332s-2,E5336,E5336Bs-2,E5336Bs-6,
    E5336s-2,E5372s-22,E5372s-32,E5373,E5776,E5776s,E583,
    E5830,E5832,E5838,E583c,E585u-82,E585v2,E586,
    E586e,E589,E589U,E58XX,E612,E618,E620,
    E630,E630+,E660,E660A,E800,E870,E880,
    E960,E968,E970,EG162,EG162G,EG602,EG602G,
    K2540,K3515,K3517,K3520,K3562,K3565,K3710,
    K4510,K4511,K4605,K5005,UMG181,HiLink,
    Huawei 823F,MTC 824FT,MTC 423S,Megafon M21-4,Megafon MR100-3 Russia,
    MTC 823F,E5330,E8231,R201,R206,R207,R205,R208,
    B183,UMG 587,E3276-920,Russia MegaFon E3272s,F615,F615-U20,
    EC5377u-872,E560,B593u-12,E5372Ts-601,EC5377u-872,
    Megafon M150-1,Megafon M100,MTC 822F,MTC 822FT
    Alcatel
    Alcatel Android Provider Database Updated.
    Official Support Website:
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    Success Stories By Avengers Box
    Samsung NAND6572 G850f clone Done - GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    Post Here successful reports with Avengers Box - GSM-Forum
    GSM-Forum
    GSM-Forum
    Once Again Samsung G361H FRP Lock Removed Done - GSM-Forum
    GSM-Forum
    Samsung G531h FRP Lock Removed Done - GSM-Forum
    GSM-Forum
    Jan 2007
    [​IMG]
    FRP Tool
    Unlock Bootloader
    Malware tools
    * Malware Remove.
    Code:
    Blade C2
    Blade L2
    V809
    Blade GLux
    Blade GPRO
    Blade Q
    Blade Q MAXI
    Blade Q MINI
    Blade X
    Code:
    N720
    F310
    V8200
    NX501
    NX402
    NX406E
    V865M
    TELEPATRIA
    CARIBE 3 FI
    TELEPATRIA 2
    Code:
    G7220
    Ascend Y220
    Ascend Y221
    G2800S
    Ascend G500
    Ascend 8836D
    Ascend Y600
    G3511
    G3512
    G3610
    G3620
    Ascend Y520
    Ascend Y320
    Ascend Y321
    G20
    G6005
    G6605
    G6800
    G6608
    G6210
    G6620
    G7210
    Panama
    VM720
    G5726
    G7510
    G6622
    G6151
    G3501S.America
    U2805
    G6006
    U5130-05
    G3621
    G3621L
    G3622
    F316
    Ascend Y511
    G5520
    G5521
    Ascend Y360-U23
    Code:
    Orange ZILO
    ORANGE REYO
    Code:
    Vodafone K3565,
    Alcatel
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    GSM-Forum
    Jan 2007
    Avengers Box Android MTK v0.2.6 Update Released - [08/03/2016]
    Added:
    - Improved saving info on firmware backup.
    Now will be saved all info like preloader info, NVRAM IMEI and otp IMEI if phone have.
    Also android info like phone model, Android version and other info.
    - Fixed extracting info from phones what use Custpack.
    - Changed Dumping for bootimg, recovery, UBoot.
    Exe will check file integrity and will not save if partition is corrupted.
    - Fixed security backup, now will be saved both preloaders Raw and flashable preloader.
    Will be saved also NVRAM partition.
    - Added saving OTP IMEI info and phone.
    - Added saving CID info for HTC Huawei Phones
    - Changed entering in meta mode for old CPU like MT6573, MT6577
    - Changed boot info, now will Auto detect if phone have OTP or IMEI is stored in nvram.
    Also will auto parse Alcatel Pro info and will display info about model.
    Download From:
    http://www.avengersbox.com/support/A...tup_v0.2.6.exe
    Full Truely & Fast Speedy Power Inside Avengers box Qmobile X25 Back To Life Again
    Samsung Galaxy J7 SM-J700H FRP LOCK Just Click Removed Done By Avengers Box
    Qmobile A115 Hang On Logo Done
    Spd 8810/6820 most wantted phone gfive shark 2 pattren,google lock removed
    Dialog K235MT6572 4.2.2 Network Unlock Done With Avengers Single Click
    Micromax A37B Virus Remove Done With Avenger Box Beta {{ No Data Lost }}
    More And More Magical Power In Avengers Box Spd 8810 Imei Fast Just In 2 Seconds
    Motorola DROID Turbo XT1254 Verizon FRP Lock Remove By Avenger Box Beta
    Xtouch Model X405 Slow Working Solved By Avengers Box Full Detail Inside
    Qmobile Z6 Unfortunatily error on some apps solved by avengersbox
    Samsung J1 Ace Network Lock Remove Done Just One Click { No Need Any Root Or Other }
    Huawei Y511-U30 Dead Recover Done By Flashing Scatter file With Avengers Box
    Many Many More to list...
    __________________
    BR
    NCK Team
    NCK Dongle - NCK Box - Cellular Codes - New Soon...
    Jan 2007
    Avengers Box Main Module v1.9 Update Released - [27/03/2016]
    Avengers Tool v1.9
    Added:
    Unlock Code Calculators
    ZTE
    Code:
    Blade X7 - Unlimited Unlock Code Calculation Via IMEI
    Blade A465 - Unlimited Unlock Code Calculation Via IMEI
    Alcatel
    Code:
    OT1016G - Unlimited Unlock Code Calculation Via IMEI
    OT1017G - Unlimited Unlock Code Calculation Via IMEI
    OT2040G - Unlimited Unlock Code Calculation Via IMEI
    OT2050G - Unlimited Unlock Code Calculation Via IMEI
    OT1060X - Unlimited Unlock Code Calculation Via IMEI
    OT1060G - Unlimited Unlock Code Calculation Via IMEI
    OT1063 - Unlimited Unlock Code Calculation Via IMEI
    VM575 - Unlimited Unlock Code Calculation Via IMEI
    Orange
    Code:
    ORANGE RIGA - Unlimited Unlock Code Calculation Via IMEI
    Beeline
    Code:
    Beeline Smart 3 - Unlimited Unlock Code Calculation Via IMEI
    Beeline Pro 3 - Unlimited Unlock Code Calculation Via IMEI
    Direct Unlock/Read Codes
    Alcatel
    Code:
    OT-6014X - Read Unlock code/Direct Unlock already supported.
    OT-6016 - Read Unlock code/Direct Unlock already supported.
    OT-6016A - Read Unlock code/Direct Unlock already supported.
    OT-6016X - Read Unlock code/Direct Unlock already supported.
    OT-6016D - Read Unlock code/Direct Unlock already supported.
    OT-6016E - Read Unlock code/Direct Unlock already supported.
    One Touch IDOL 2 MINI - Read Unlock code/Direct Unlock already supported.
    OT-7040T - Read Unlock code/Direct Unlock already supported.
    OT-7040N - Read Unlock code/Direct Unlock already supported.
    One Touch IDOL 2 MINI L - Read Unlock code/Direct Unlock already supported.
    OT-6036Y - Read Unlock code/Direct Unlock already supported.
    One Touch IDOL 2 Mini S - Read Unlock code/Direct Unlock already supported.
    OT-6037Y - Read Unlock code/Direct Unlock already supported.
    One Touch IDOL 2 - Read Unlock code/Direct Unlock already supported.
    Vodafone Smart Tab 4g - Read Unlock code/Direct Unlock already supported.
    OT-5050X - Read Unlock code/Direct Unlock already supported.
    OT-5050Y - Read Unlock code/Direct Unlock already supported.
    OT-5050S - Read Unlock code/Direct Unlock already supported.
    One Touch POP S3 - Read Unlock code/Direct Unlock already supported.
    OT-6035R - Read Unlock code/Direct Unlock already supported.
    OT-978X - Read Unlock code/Direct Unlock already supported.
    OT-6034R - Read Unlock code/Direct Unlock already supported.
    OT-6034Y - Read Unlock code/Direct Unlock already supported.
    OT-6034M - Read Unlock code/Direct Unlock already supported.
    OT-6050Y - Read Unlock code/Direct Unlock already supported.
    OT-6050A - Read Unlock code/Direct Unlock already supported.
    OT-7050Y - Read Unlock code/Direct Unlock already supported.
    OT-J736 - Read Unlock code/Direct Unlock already supported.
    OT-J738M - Read Unlock code/Direct Unlock already supported.
    OT-J730U - Read Unlock code/Direct Unlock already supported.
    OT-J736L - Read Unlock code/Direct Unlock already supported.
    OT-J929L - Read Unlock code/Direct Unlock already supported.
    OT-M812C - Read Unlock code/Direct Unlock already supported.
    OT-M812F - Read Unlock code/Direct Unlock already supported.
    OT-P330X - Read Unlock code/Direct Unlock already supported.
    OT-P350X - Read Unlock code/Direct Unlock already supported.
    OT-P353X - Read Unlock code/Direct Unlock already supported.
    OT-7043Y - Read Unlock code/Direct Unlock already supported.
    OT-7043A - Read Unlock code/Direct Unlock already supported.
    OT-7043K - Read Unlock code/Direct Unlock already supported.
    OT-7055A - Read Unlock code/Direct Unlock already supported.
    OT-7055W - Read Unlock code/Direct Unlock already supported.
    OT-9020A - Read Unlock code/Direct Unlock already supported.
    OT-P688L - Read Unlock code/Direct Unlock already supported.
    OT-5042X - Read Unlock code/Direct Unlock already supported.
    OT-5042A - Read Unlock code/Direct Unlock already supported.
    Vodafone Smart prime 6 - Read Unlock code/Direct Unlock already supported.
    Alcatel One Touch POP 2 - Read Unlock code/Direct Unlock already supported.
    Orange Nura - Read Unlock code/Direct Unlock already supported.
    Orange Roya - Read Unlock code/Direct Unlock already supported.
    Samsung
    Code:
    GT-S5611 - Direct unlock/ IMEI Repair
    Spreadtrum CPU
    Code:
    SC6530 - Dump Phone full/Restore Phone full/Flashing Factory pac file.
    SC6531 - Dump Phone full/Restore Phone full/Flashing Factory pac file.
    Samsung Android Phones Flasher
    Allow to perform firmware flashing For All Samsung Android Phones (list is too huge to list here)[​IMG]
    Allow to choose what files will be flashed from firmware package. (it's useful when need to flash only recovery or sboot or system only).
    WriteSBOOT for unlock FRP[protected files]
    Added in server the Following SBOOT Files
    Code:
    SM-A310F
    SM-A710F
    SM-A800F
    SM-G550FY
    SM-G600FY
    SM-G920T
    SM-J120F
    SM-J200G
    SM-J500F
    SM-J700F
    SM-N920C
    SM-N920G
    Files have read_me.txt inside, please read before perform flashing.
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    Samsung ORG SM-G361H FRP Unlock Done
    Hot plus hot ,one more samsung J7 Frp reset done very easy by avenger box
    Samsung Galaxy S2 GT-i9100 Hang Logo Flash Done By Avenger Beta Test Report
    ..::Samsung SM-A800I FRP Done Avengers Box::..
    World,s first Media Pad7 Virus Cleaning Done Easy By Avenger New Beta Test Report
    __________________
    BR
    NCK Team
    Jan 2007
    Avengers Box Main Module v2.0 Update Released - [10/04/2016]
    [​IMG]
    Added:
    Spreadtrum
    SC6530- Read Phone Password/Read Guard Lock/Read/Repair phone IMEI/Reset phone EFS/Remove Simlock .(work only with phones what have Simlock in EFS.
    SC6531- Read Phone Password/Read Guard Lock/Read/Repair phone IMEI/Reset phone EFS/Remove Simlock .(work only with phones what have Simlock in EFS.
    ZTE
    Blade V580- Unlimited Unlock Codes Calculation Via IMEI
    Oysters
    Arctic 450- Unlimited Unlock Codes Calculation Via IMEI
    Megafon
    Login 2[tablet]- Unlimited Unlock Codes Calculation Via IMEI
    MT3A [Tablet]- Unlimited Unlock Codes Calculation Via IMEI
    Megafon Optima- Unlimited Unlock Codes Calculation Via IMEI
    MS3B- Unlimited Unlock Codes Calculation Via IMEI
    Alcatel- More than 1000 PIDs Updated - Provider ID list up to date for unlimited Unlock Codes Calculation
    OT-4013M
    OT-4013D
    OT-4013D
    OT-4013X
    OT-5015A
    OT-5015D
    OT-5015D
    OT-5015X
    OT-5017W
    OT-5017O
    OT-5017A
    OT-5017E
    OT-5017D
    OT-5017X
    OT-5016A
    OT-5016J
    OT-5025E
    OT-5025G
    OT-5025D
    OT-7041D
    OT-7040A
    OT-8008X
    OT-8008D
    OT-8008W
    OT-8030Y
    OT-8030B
    OT-9002X
    OT-9005X
    OT-I215X
    OT-V685
    OT-V695
    OT-V785
    OT-V795
    OT-4018M
    OT-8020D
    OT-8020X
    OT-8020A
    PS.>
    Avengers Box Comes without Activation - monthly or yearly.
    Avengers Box Comes without Any PAID PACKS.
    Avengers Box Comes without server based all features.
    Avengers Box has no credits system.
    Avengers Box Has Unlimited Updates.
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    s7582 logo hang slove
    Samsung Galaxy Ace GT-S5830i ORG Hang Logo Flash Done By Avenger Beta Test Report
    Huawei Y336-U01 SC7731 Factory Reset Done With Avenger { Fully Safe } { Easy }
    Q Mobile new Modek E440i Spd 6531 REad File Don Ony 48 Second Beta test Avengersbox
    Jazz JS500 RE alive with Avenger BOX
    __________________
    BR
    NCK Team
    Jan 2007
    Avengers Box Android MTK Module v0.2.7 Update Released - [13/04/2016]
    ZTE
    ZTE Meo Smart A40*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE MEO Smart A30*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE Blade V580*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE Blade A452*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE Blade A465*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE Blade A475*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE Blade L3 Lite*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    ZTE Blade L5*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Alcatel
    OT-5022E- Unlocking/Flashing/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    OT-5022X- Unlocking/Flashing/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    OT-5022D- Unlocking/Flashing/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Other Models added
    Orbis- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Haier G31- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    BQ Aquaris 5 HD- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    4Good S540M 4G- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    NOS FIVE- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    SKY 5.0LM*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    BLU LIFE XL*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    BLU STUDIO G PLUS*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    AVVIO SEN-S23*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Ipro Mini Elite*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Maxwest Orbit 330G*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    BMobile AX710*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Sendtel Rocket*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Movic W4*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    GFIVE LOGIC X1*- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Coolpad Note 3 (CP8676_I02)*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Lenovo A2010*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Lenovo A2010a*- Unlocking/Flashing/Firmware Backup/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    AVVIO 779- Unlocking/Flashing/Firmware Backup/IMEI Change (Repair)/Boot Info/Format/Backup & Restore Security/FRP if Supported.
    Uploaded over50 Alcatel firmwaresin support(different models)
    - Added posibility to perform firmware backup forMT67XXsupported phones.
    Now will backup complete firmware including preloader.
    - Solved problem with restoring security inMT67XXsupported phones.
    - FixedMT6735Mbug what make exe to crash.
    - Solved problem with saving files > 2gb.
    Now saving is ok, also saved firmware info must be ok.
    On security backup will be saved also phone scatter now.
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    __________________
    BR
    NCK Team
    Jan 2007
    Avengers Box Android MTK Module v0.2.9 Update Released - 18/05/2016
    [​IMG]
    Models added:
    Avvio L630- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    Azumi A45s- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    Symphony v70- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    Symphony w68- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    Walton Primo Rm2- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    OPPO R827- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    TCL D45- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    JTY D101- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    Verykool Sl4050- Boot Info/Unlock/Flashing/IMEI Repair (change)/Format/Read User Lock/Privacy/FRP etc..
    Addedchecking preloader signuntil saving.
    ImprovedMT6XXXNand phones format.
    Improved boot info on some CPU, now it will show extra detials.
    Improved saving phone firmware for supportedMT67XXcpu.
    Improved unlock for SIMLOCK 1 & SIMLOCK 2 forMT6735 and MT6735Mcpu.
    Stay tuned for next hot update this week...[​IMG]
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    QMobile Noir I9 Hang On Logo Recover Done With Avengers Box
    Samsung Galaxy J5 Duos SM-J500H Remove Pattern Just One Click Done By Avengers Box
    Q Mobile Noir X25 Camera Open Gallery Error Recovery Success Done By Avengers Box
    Samsung Galsy S4 I9515 4G Unlock Done Without Root Avengers Box
    HTC One XXX Virus Remove Done
    Samsung G531H ORG FRP Reset Done
    __________________
    BR
    NCK Team
    NCK Dongle - NCK Box - Cellular Codes - Avengers Box - UMT Box
    Jan 2007
    Avengers Box Android MTK Module v0.3.0 World's First Update - [04/06/2016]
    [​IMG]
    AddedRepair IMEI in AP Mode. AKA SP METAWorld's First & Exclusive From NCK Team(Copy Pasters Welcome)[​IMG]
    Need to useSPMETAconnection from exe.
    This Method support all supported MTK CPU by our Android MTK Module, including MT6735M and other 64 bits CPU.
    This Method will Reconstruct formatted NVRAM as well.
    Repair IMEI is permanent, not gone after format or wipe.
    OTP phones (Alcatel) is not supported for IMEI Repair.
    Added repair IMEI forMT6735Mand other supportedMT67XXphones[FLASH Mode].
    For using this mode phone must have valid NVRAM.
    ForMT67XXphones not necessary to perform wipe to finish procedure.
    For both methods NO ROOT NO ADB needed.
    Models added
    Avvio 781*(MT6572) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Azumi A45T*(MT6572) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    TECNO P5 PLUS*(MT6572) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    TECNO Y3*(MT6572) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Verykool SL5550*(MT6735) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Verykool SL4502 Fusion II*(MT6735) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    BMobile i5i *MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    BMobile Z12 MT6735* - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Lava Iris 353 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Lava Iris 356 MTK6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Lava Iris 504Q MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Lava Iris X5 MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Lava Iris i310s MT6571 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Lava Iris 458Q MT6589 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile Magnus X2i 3G* - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Qmobile Qtab Q400 MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile I9 MTK6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile S1 MTK6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile X11 MTK6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile S3 MTK6580 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile S2 MTK6580 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile A10 MTK6589 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    QMobile Z6 MTK6592 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Mobicell SAMBA mt6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Mobicell METRO 2 MTK6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Mobicell ONYX MTK6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Mobicell Retro NO GPS MTK6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Mobicell Retro Simple MTK6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    MICROMAX Q372 MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    MICROMAX A068 MT6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    MICROMAX A107 MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    AG CHACER MT6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    AG RAGE MT6572* - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    XOX MaximPro*(MT6572) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    BSNL PENTA WS704D MT6572* - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    NEXA VEGA N1 Mt6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Xtreme Voice Mobile V15 MT6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    CALLBAR MT6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Intex Cloud Y17 Plus MT6572 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Connect Veritab MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Voice v65 MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Innjoo Note MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Q-Smart QS550T*(MT6582) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Intex Aqua i5 HD*(MT6582) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Nyx maxx*(MT6582) - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    KARBONN MACHONE S310 MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    AZPEN A739 TAB MT6582 - Boot Info/Unlock/Read Codes/IMEI Repair AP Mode,Flash Mode,Meta,ADB/Flashing/Format/etc..
    Fixed bug forMT6592, MT6580format.
    Added forcing preloader detect, usefull for some phones what inititialise preloader with timeout.
    Remade savingNVRAM in META Mode.
    Now will save single zip file.
    For restoring need also to use this zip file, not need to extract anymore.
    Improved saving phone firmware.
    Avengers Box
    Download Link:
    DOWNLOAD LINK HERE
    Samsung Clone J5 Touch Problem Solved With Avengers Box
    Q mobile x30 hang on logo recover done
    World First Qmobile Z10 MT6735 EMMC FRP Reset Done
    AvengersBox Mtk Beta Ver 3.0.0 is Started More Features More Stability Is Upcoming
    __________________
    BR
    NCK Team
