    Super Moderator namnhatrang's Avatar
    Jan 2007
    Mặc định IPHONE box update
    • Fixed Bugs in previous Ver 3.5
    • Add New Flash Support
    THGBX2T0BBJLA03
    H2JTEG8VD1CMS
    Jan 2007
    1. Can update your iphone harddisk ( ex : 8g update to 128gb )
    2. Can read\write\fix base spi flash ic.
    .--Helpfull to solve update and restore errors ( ex: Itunes 1,16...39,54 error and more)
    3. Can repair harddisk error ( ex: Itunes 9,14,20 errors and more)
    .--repair almost hdd error on iphone 5s
    4. 2in1 = 32bit and 64bit ipad iphone nand flash HDD error repair supported.
    5. Backup\write harddisk data ( support full flash read\write\erase... )
    6. Change the iphone\ipad info ( sn\wifi mac\bt mac\local\modem... )
    7. Backup\write iphone 6\6plus\6s\6s plus\5se fingerprint eeprom
    8. Adjust erase full flash with high speed and support the recognition function on HDD.
    9. Coming Next More...
    Jan 2007
    Click Download V3.7 New Update
    iP Box V2 Software Version 3.7 New Update(2016-9-13)
    Jan 2007
    1:Add Advanced Option for repair Boot,You can press F2 for run it
    2:Support Double Boot Auto Distinguish
    3:Read SPI Flash auto show you imei
    4:WIFI/BT add auto creat。
    5:New update Change SN only function ,auto Creat Wifi and BT add,Support all the model
    6:if SN has Illegal character, the Tips you for fix it
    7:Add new flash support SDMBLBCF4_064G。
    8:adjust iPhone5s,now all the 5s change disk,Fingerprint function available
    Click Download Last Update Ver 3.9c
    Let's talk about ver 3.9C over here iscussed - IP Box 2 Version 3.9c Released
    Jan 2007
    IP BOX V3 <Iphone 4~7Plus\Ipad 3~Ipad 2018> Support
    Support Iphone NAND and E3NAND Write SN\WIFI\BT\.....
    Support EEPROM Flash
    Support SPI Flash
    This Update also working with IP-BOX V2!!!
    tip: with ip boxV3 you can repair the IPHONE 6s 6sPlus 7 7Plus!!!
    software download link:click here download
