    Super Moderator namnhatrang's Avatar
    Jan 2007
    Mặc định ios 12.3 final download
    Update your iPhone, iPad, or iPod touch
    New Release iOS 12.3 Download IPSW Direct Links
    How to Update your device wirelessly
    1. Plug your device into power and connect to the Internet with Wi-Fi.
    2. Tap Settings > General > Software Update.
    3. Tap Download and Install.
    4. To update now, tap Install.
    5. If asked, enter your passcode.
    Update automatically
    With iOS 12.3, you can have your iOS device update automatically. To turn on automatic updates, go to Settings > General > Software Update > Automatic Updates. Your iOS device will automatically update to the latest version of iOS. Some updates might need to be installed manually.
    Update your device using iTunes
    If you can’t update wirelessly on your iOS device, you can update manually using iTunes on a computer that you trust. If your computer is using Personal Hotspot on the iOS device that you’re updating, connect your computer to a different Wi-Fi or Ethernet network before you update.
    1. Install the latest version of iTunes on your computer.
    2. Connect your device to your computer.
    3. Open iTunes and select your device.
    4. Click Summary, then click Check for Update.
    1. Click Download and Update.
    2. If asked, enter your passcode. If you don't know your passcode, learn what to do.
    Don't forget press Thanks button
  2. ( namnhatrang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hung va anh (14-05-2019)
