các anh ơi giúp em với em mới vào nghề nhận chạy tiếng việt con k750i lúc đầu thì dùng bình thường chạy bằng se tool thì nó báo như sau em ko biết bị bệnh gì mong cấc anh giúp đỡ
v0.914020/UNI
CARD SERIAL: 00054313
Loaded 51 flash descriptors
Open COM port OK
ChipID:8040,EMP protocol:0301
PHONE IS BROWN
FLASH CID detected:36
Speed:921600
Flash ID check:200D
Flash props sent ok
OTP LOCKED:1 CID:36 PAF:1 IMEI:35846300505056 CERT:BROWN
FLASH CID:36 COLOR:BROWN
Model:K750i
MAPP CXC article: R1CA021 prgCXC125956_TAIWAN_CL
MAPP CXC version: R1CA021
Language Package:HONG_KONG
CDA article: CDA102414/4
CDA version: R3A
Default article: cxc125953
Default version: R1CA021
Operator: 000-00
USERCODE:0000
Elapsed:4 secs.
Open COM port OK
PHONE IS BROWN
Speed:921600
LDR:041214 0816 LLECXC1326743_COMPACTPRODUCTION R2AB
Flash ID check:200D
Flash props sent ok
LDR:COMPACT_SEMC_FS_LOADER_SETOOL2_V23
loader startup: executed
loader GDFS startup: executed
Abort all operations.
wrong response, break.
loader fs startup failed, that is fatal
Elapsed:32 secs.
Open COM port OK
PHONE IS BROWN
Speed:921600
Flash ID check:200D
Flash props sent ok
writing D:\SONY ERICSON\setool\SE Flash\K750\r1db001\R1DB001_125954_CHINA_CL.ssw\R1D B001_125954_CHINA_CL.ssw.cry
CURRENT FLASH FILE CID:49
Matching CID according file...
SSW uses dynamic hash, dynamic hash len is:315
Will flash 315 blocks...
SSW loading returns:0
writing D:\SONY ERICSON\setool\SE Flash\K750\r1db001\R1DB001_APAC_1_fs.ssw\R1DB001_A PAC_1_fs.ssw.cry
CURRENT FLASH FILE CID:36
SSW uses dynamic hash, dynamic hash len is:153
Will flash 153 blocks...
Elapsed:716 secs.
Open COM port OK
PHONE IS BROWN
Speed:921600
Flash ID check:200D
Flash props sent ok
writing D:\SONY ERICSON\setool\SE Flash\K750\r1a008\k750_r1aa008_apac1_main.cry\k750 _r1aa008_apac1_main.cry
CURRENT FLASH FILE CID:254
SSW uses dynamic hash, dynamic hash len is:310
Will flash 310 blocks...
writing D:\SONY ERICSON\setool\SE Flash\K750\r1a008\k750_r1aa008_apac1_fs.cry\k750_r 1aa008_apac1_fs.cry
Elapsed:718 secs.
			 cứu em với k750i chạy tiếng việt
