em cos con 1110i chay phan mem` song bi contacsevis em lam lai u thi` gio` chay lai bang jaf bao' the nay` bi sao moi anh giup' em voi' .may em chua ca
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: D7 C2 F1 42 20 4E B9 33 2C 62 0C E5 90 DA A5 AF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: D:\PHAI ChAY NOKIA\phai chay nokia\1110i\rh93\rh93_06.400
Phone Type:
PPM Flash file: D:\PHAI ChAY NOKIA\phai chay nokia\1110i\rh93\rh93_06.40md
Phone Type:
CNT Flash file: D:\PHAI ChAY NOKIA\phai chay nokia\1110i\rh93\rh930_nai6.40md
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\PHAI ChAY NOKIA\phai chay nokia\1110i\rh93\rh93_06.400
Booting phone...
Phone didn't answer with TX line high after UEM reset!
Causes:
1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
2.UEM damaged -> replace UEM.
MCU ID: 0xCCCC
This MCU ID is not supported in chosen flash file...
Error booting phone...
Failed! Aborting!
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
First 16 bytes: 00 02 00 02 00 45 3F BF 00 77 08 C0 10 08 01 04
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: bb
Loader is ready...
MSID: 84BDBB892FB9A41A4CC518C6DB
MSID decoded: 3E4EBAE900171F86A9000000
FAID: 03B4F3C17E46D2FD8A9DC005
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 34 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: D:\PHAI ChAY NOKIA\phai chay nokia\1110i\rh93\rh93_06.40md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
First 16 bytes: 37 02 00 02 00 04 00 00 00 00 08 C0 10 08 01 BF
Loader is ready...
MSID: 84EE4570997F73E61EB26FAEA7
MSID decoded: 3E4EBAE900171F86A8000000
FAID: 6456B81E7F08D3A83B8E4A31
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Writing...
Restarting MCU...
CNT: D:\PHAI ChAY NOKIA\phai chay nokia\1110i\rh93\rh930_nai6.40md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 26 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
i` viet cay mong moi mod thong cam hj
			 1110i hep me
 1110i hep me
			 Được post bởi xuanmobile
