    Thành viên chính thức Trinh Tieu Phong's Avatar
    Mặc định Flash N70 báo lỗi, nhờ AE giúp đỡ!!!
    Em nhận của khách 1 cây N70 bị trắng màn hình. hình như bị treo máy, em đưa vào JAF định flash lại thử thì nó báo lỗi. Em post cái log lên cho mọi người xem thử.
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v47
    30-01-07
    RM-84
    (c) Nokia.
    HW version: 7005
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: CEI764688
    Product code: 0539276
    Module code:
    Basic production code: 0536420
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356294019183465
    IMEI spare to net: 3A 65 92 04 91 81 43 06
    IMEI SV to net: 33 65 92 04 91 81 43 16 F0
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V10
    CNT Flash file: NONE
    APE Variant file: NONE
    Done!
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    Loader version: 01.21.01 -> Revision: 0000
    Getting CMT Public Keys...
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35629401918346_CRT_backup _1047198.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356294019183465_CRT_backu p_1047198.pm
    Done!
    Backup LCK OK!
    Reading SW version...05wk07v47
    Booting phone...
    APE Boot Data:
    Asic ID: 17100701
    Asic Mode ID: 00
    Asic Public ID: 2D7E38A1FDA2BC86CDEF5F3C4371948C7B42A542
    HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0730011243B75D51B0EEDAD18C29B9A19189CB6F
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    CMT Boot Ready
    CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    CMT Loader Ready
    APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg
    Loader version: 01.23.00 -> Revision: 0000
    Patching APE boot step2...
    APE Boot Ready
    Error in cmd read id...
    Error in ape get id...
    Anh em nào biết lỗi này thì giúp em với, cảm ơn nhiều!!!
    V.I.P GSM Hải Phòng's Avatar
    Haiphonggsm.vn
    kicks vào AMPE mà chạy con này thiếu áp rồi
  3. ( GSM Hải Phòng ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Trinh Tieu Phong (19-08-2008)
    V.I.P nhatkha's Avatar
    Feb 2006
    Trung Tâm Kha Oanh .
    Gở bỏ 2 con regu cấp áp cho OMAP ra và câu dây
  5. ( nhatkha ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Dec 2006
    347 Lê Văn Lương TP Hưng Yên
    yes . như a kha nói đó. nó đây
    Web :http://gsmhungyen.com/
  7. ( Gsm Hưng yên ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #5
    Thành viên chính thức cuahanganhdao's Avatar
    Aug 2008
    miền đất hứa
    của bạn nửa đây
  9. ( cuahanganhdao ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  10. #6
    Cảm ơn AE, để em thử rồi cho anh em biết kết quả!
  11. #7
    Trích Được post bởi khoianlao Xem bài viết
    check vào APE phải ko a? em check vào chạy qua hết nhưng vẫn bị trắng màn hình. Hình như nó không xoa flash được.
  12. #8
    Talking
    Trích Được post bởi cuahanganhdao Xem bài viết
    của bạn nửa đây
    Em làm đuợc rùi, cảm ơn anh em nhiều lắm, hahahah
  13. #9
    Haiphonggsm.vn
    Trích Được post bởi Trinh Tieu Phong Xem bài viết
    cái đó chỉ là để chạy vượt qua erro Ape thôi .hì lên thì trắng màn là đúng rồi
  1. VolcanoBox2.7.6 Beta SPD Android Read Flash & Write Flash Much More Improved
    Bài viết cuối: 28-07-2014, 09:14
  2. Trả lời: 7
    Bài viết cuối: 18-10-2013, 09:52
  3. Trả lời: 2
    Bài viết cuối: 06-01-2010, 23:17
  4. Trả lời: 3
    Bài viết cuối: 22-06-2009, 17:00
  5. xin files 5310 chip 6225 flash FLASH TOSHIBA TV00578002DABD
    By tuthanwwww in forum Phần mềm và các mã lệnh
    Bài viết cuối: 16-04-2009, 09:46
