máy 5200 rm 174 ver ban đầu 5.53 em chạy ct hạ ver xuống còn 5.51 mà unlocktestpoint báo thế này anh nào có kinh nghiệm chỉ em cảm ơn
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.51_05-09-07_RM-174_(c)_Nokia.
IMEI: 359816018444675
SP LOCK status:
Config Key: 2082000000000000
Block 1: CLOSED Type 5 Data: 20820F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-174_359816018444675_Locked_Keycnt_0_Fbuscnt_0__V_0 5.51_05-09-07_RM-174_(c)_Nokia..bin
already exist
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number (Keyboard): 2
Response byte: 08
Try number (Keyboard): 3
Response byte: 08
Unlock using keyboard codes fail.
Try unlocking using cable codes ...
Try number (Cable): 1
Response byte: 08
Try number (Cable): 2
Response byte: 08
Try number (Cable): 3
Response byte: 08
Try number (Cable): 4
Response byte: 08
Try number (Cable): 5
Response byte: 08
Try number (Cable): 6
Response byte: 08
Try number (Cable): 7
Response byte: 08
Try number (Cable): 8
Response byte: 08
Try number (Cable): 9
Response byte: 08
Try number (Cable): 10
Response byte: 08
Unlock using cable codes fail.
Reading again SP Locks ...
SP LOCK status:
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Unlock fail. Please try again.
mà tốt nhất là chạy lại ver 05.00 unlock ok
.6124225
