Trang 1 của 5 1 2 3 4 5 CuốiCuối
Kết quả 1 tới 10 của 50
    Thành viên chính thức DakLakGSM's Avatar
    Dec 2007
    Mặc định HWK_Setup_Suite_v02.08.000 Released
    HWK Release 14/09/2008 - Discussion
    Release Date: 14/09/2008
    The Official release is ready in our download area http://sarunasoftware.com.
    Please follow the instructions careful on the above page.
    The Update Client is launched after HWK Support Suite install, if you cancel without making the update, you can run the Update Client again, by selecting the shortcut on the Start Menu:-
    Programs\SarasSoft\UFS\Utilities\Update Client
    WARNING !!!
    If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
    UFS_DCTxBB5 v2.0.8.0
    1. New BB5 products:
    RM-207,RM-235,RM-236,RM-257,RM-270,RM-277,RM-325,RM-328,RM-342,
    RM-343,RM-345,RM-346,RM-352,RM-354,RM-355,RM-357,RM-358,RM-359,
    RM-367,RM-378,RM-379,RM-386,RM-387,RM-396,RM-397,RM-400,RM-407,
    RM-408,RM-409,RM-410,RM-411,RM-414,RM-416,RM-417,RM-418,RM-419,
    RM-420,RM-422,RM-425,RM-436,RM-462
    (6263,N78-1,N78-5,3555b,3555,3555c,6600f-1c6220c-1,N78-3,E66-1,E66-2,
    E71-1,3600s,7610s,7610sb,E71-2,5610d-2,5610d-2b,6210s-1,7310cb,7310c,
    6210s-5,6220c-5,6212c,6500c-5,6650d-1c,E71-3,6210s-1c,5320d-1,5220b,
    5220,6600s-1c,5320,5320d-1b,5320,6210s-1b,E66-3,6124c-1,6122c,7210c,E71-5)
    2. New DCT4 products:
    RH-116,RH-117,RH-118,RM-391,RM-392,RM-393,RM-394,RM-395
    (7070,7070b,1681c,2760h,2680s,2680s-2b,1680c-2,1680c-2b)
    3. New DCT4+ UNL versions support:
    1200 (RH-99 v5.51,v5.53), 1200b (RH-100 v5.32)
    1208 (RH-105 v5.51,v5.53), 1208b (RH-106 v4.00,v4.11,v5.23,v5.32)
    1650 (RM-305 v5.32,v5.51,v5.53)
    1680c-2,1680c-2b (RM-394,RM-395 v5.61,v5.63)
    2610,2610b (RH-86,RH-87 v6.73,v7.10)
    2630 (RM-298 v5.61)
    2760 (RM-258 v4.20,v5.61), 2760b (RM-259 v4.20,v5.61)
    2760h (RM-391 v5.45)
    4. Fixed minor bugs.
    5. New Flash Update Pack 8.36.2.35145
    Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone.
    LG_GSM V 2.0.8.0
    v 2.0.8.0 (HWK Required)
    1. Added "FSct0" (Force Sector 0 Overwrite) Checkbox in
    Infineon platform.
    Use it for Frozen or blinking phones (KE800,..)
    2. KP130, KP210, KP215, KP260, KP265 support added.
    SAMs V 2.0.8.0
    TRIDENT
    S730i (DUNL,IM,FL)added.
    B200,B300 DUNL and IM fixed.
    Reserved Regions values revised and fixed.
    MSL Repair enhanced, and added for following products:
    C17x,C26x,C520,E84x,E90x,E95x,F21x,M300,M60x,P520, U10x,U30x,X82x
    "Erase NOR" activated.
    Enhanced 4CC protocol handler (fixed error on PC busy)
    TRIDENT VISION
    E21x,J60x fixed (INF,DUNL,IM)
    M310 added (FL,CUNL)
    OM(SYSOL)
    A117,C288,M130L added (DUNL,IM,FL,SECT)
    E746 bug fixed.
    SWIFT
    D780,D788(Duos2),D828E,E251,E251C,E258D,F110,G808E ,J210,L310,
    P180,P200,P260,P850,P858,T309,T509,U908E,X700N (DUNL,FL,SECT)
    F488E,J150 (FL,CUNL) Use 'Unlock E2P' to see Codes.
    E35x,E37x,T809 DUNL, SECT and IM fixed.
    E480,E488 bug in DUNL,SECT fixed.
    D880-Duos flashing bug in 2.0.7.2 fixed.
    X700 SECT fixed.
    SWIFT-AEROFONE
    B130 introduced(FL,CUNL) Use 'Unlock E2P' to see Codes.
    QUALCOMM
    A411,A412,A701,A706,A707,A711,A717,A727,A736,A737, A801,A817,
    F330,F338,F400,F408,F480,F488,F490,F510,F550,F700, G400,G800,
    G800B,G800L,G808,J200,J200L,J208,J630,J638,L170,L7 60,L760G,
    L768,L810,L811,P910,P920,P940,P950,P960,T639,T819, U700,U700B,
    U708,U800,U800F,U900,U900U,U908,V705,V706,V707,V70 8,Z150,Z170,
    Z230,Z238,Z240,Z240E,Z248,Z310,Z360,Z368,Z400,Z540 ,Z548,Z560,
    Z570,Z720,Z728,Z740,ZV40,ZV50,ZV60 introduced (FL,INF,REUL)
    COMMON
    Product Langpacks description added (Info and MCU-Open)
    Note, real menu languages can differ from listed here,
    for different models, firmware versions. Languages in
    brackets is not mandatory for current Region.
    SeDBx v2.0.8.0
    DB2010
    1. Added Support for: 36Brown, 49Brown
    DB2012
    1. Added Support for: 50Brown, 51Brown, 51Red, 53Red.
    2. Added CID Upgrade.
    DB2020
    1. Added Support for: 49Brown.
    2. Loaders Updated.
    PNX5230
    1. Added Support for: 49Brown, 52Brown.
    2. Loaders Updated.
    USB Drivers are installed to X:\Program Files\SarasSoft\UFS\UFS_DBX\USBFlashDriver
    SeDBx Quick Guide has been updated.
    Many thanks to all those who have supported us!!!
    LINK DOWNLOAD :
    HWK-SUPPORT-SUITE-SETUP-V02.08.000
    HWK-SETUP-SUITE-V02.08.000
    1. Uninstall HWK_Support_Suite_Setup_v02.07
    Uninstall HWK_Suite_Setup_v02.07
    2. Install HWK_Support_Suite_Setup_v02.08.000.exe, Update Box
    Instal HWK_Setup_Suite_v02.08.000.exe
  2. ( DakLakGSM ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    nguyennam (16-12-2009), trananhmobi (15-09-2009)
    Thành viên mới Mobileconector's Avatar
    Hên quá Up 1 lần được luôn ,cảm ơn nhiều công nhận Sarassoft lâu lâu Update 1 phát nhìn cũng đã ghê, nhìn Tool Samsung Support QualComm kìa , tính mua UST-Pro , hehehe nhưng nhìn phải suy nghĩ lại.
  4. ( Mobileconector ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  5. #3
    Thành viên chính thức DONG DUONG MOBILE's Avatar
    Apr 2008
    sao em ko dowla đc vậy a ơi!
  6. ( DONG DUONG MOBILE ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  7. #4
    Super Moderator tuanwawezx's Avatar
    Feb 2006
    Chùa Thiếu Lâm
  8. ( tuanwawezx ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
    simson (21-09-2008), trananhmobi (15-09-2009), tranquyetchien85 (05-10-2008)
  9. #5
    Thành viên chính thức vantammobile's Avatar
    các anh em cho hỏi tại sao mình updat kg được nè giúp mình nhé
  10. #6
    V.I.P TânĐạiDương's Avatar
    Jan 2007
    59A QL 13-HBP-Thủ Đức-TP.HCM
    Wink hướng dẫn và cài đặt HWK V2.08
    Trích Được post bởi DONG DUONG MOBILE Xem bài viết
    Để download file từ support HWK về . thì máy tính bạn cần fải cài fần mềm duyệt wed (Mozilla Firefox) và fần mềm hổ trợ download dành cho support HWK là (uTorrent) mới có thể lấy file từ support của HWK về đc .
    * Fần Mềm Duyệt Wed Mozilla Firefox setup ver mới nhất Download ở Link đây : http://kyoto-mz-dl.sinet.ad.jp/pub/m...up%203.0.1.exe
    * Fần mềm hổ trở Down cho HWK uTorrent setup download ở link đây : http://support.sarunasoftware.com/start/uTorrent.msi
    sau khi setup hết các fần mềm trên bạn bấm vào link này : http://sarunasoftware.com/system/sof...v02.08.000.exe để load support update chíp HWK
    Bước 1 : gở bỏ bản HWK_setup_Suite và HWK_support củ bạn đang sài
    Bước 2 : cài đặt HWK_Support_Suite_Setup_v02.08.000.exe và update chíp HWK của bạn .
    Bước 3 : sau khi update chíp hwk của bạn thành công, thì vào support HWK download HWK_setup_Suite_V2.08.000.exe về và cài đặt lên bình thường .và sau đó thưởng thức với giao diện mới của Sarassoft và + thêm nhìu model mới support. fải nói là wá tuyệt vời
    Chúc bạn cài đặt và update V2.08 Thành công !
  11. ( TânĐạiDương ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Logo (12-11-2008)
  12. #7
    V.I.P lechicuong's Avatar
    Feb 2007
    nếu máy em ko có HWK thì có thể xài đc bản này ko bro?
  13. #8
    Jan 2007
    Wink
    Trích Được post bởi lechicuong Xem bài viết
    Nếu bạn chưa có HWK xịn, thì chỉ sài đc bản HWK 2.01 Crack thôi . không sài Được HWK Ver 2.08 đâu, vì ver này chưa Crack được .
  14. #9
    Thành viên mới ntphat_gsm's Avatar
    Aug 2008
    Trích Được post bởi Hu_Mobile Xem bài viết
    WARNING !!!
    2630 (RM-298 v5.61)
    LG_GSM V 2.0.8.0
    Infineon platform.
    SAMs V 2.0.8.0
    TRIDENT
    TRIDENT VISION
    OM(SYSOL)
    E746 bug fixed.
    SWIFT
    X700 SECT fixed.
    SWIFT-AEROFONE
    QUALCOMM
    COMMON
    SeDBx v2.0.8.0
    DB2010
    DB2012
    DB2020
    2. Loaders Updated.
    PNX5230
    2. Loaders Updated.
    LINK DOWNLOAD :
    e dang dung UFS-6 vay chay v02.08 dc kg a
  15. ( ntphat_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  16. #10
    Dec 2007
    Trích Được post bởi ntphat_gsm Xem bài viết
    Box của bạn chỉ cần nâng cấp HWK original (Zin)là dùng Okie
Hiện có 4 người đang xem bài này . Bao gồm : 0 thành viên và 4 khách
  1. NCK Box Released Android MTK Module Ver 1.8.5.9 Update Released - [09.09/2015]
    Bài viết cuối: 09-09-2015, 10:18
  2. Infinity-Box Nokia [BEST] v1.88 released: MTKx Unlock released
    By hoangdaika in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 17-04-2014, 12:43
  3. NSS pro v 0.31 released
    By toilatoi142001 in forum Các thiết bị khác
    Bài viết cuối: 09-02-2012, 08:38
  4. 22 Feb 2010: "Shell" v1.34 released, DongleManager v1.32 released
    By HoangThong_hotrokythuat4 in forum Infinity Box
    Bài viết cuối: 23-02-2010, 10:25
  5. UST Pro v9.4.00 Released
    By hungphongmobile™ in forum UST Pro II
    Bài viết cuối: 13-04-2009, 21:02
