Kết quả 1 tới 10 của 10
    V.I.P GSM Hải Phòng's Avatar
    Haiphonggsm.vn
    Mặc định 1650 khởi động lại
    em có cây 1650 bị khởi động lại thay cpu 1200 check flash qua jaf báo lỗi
    MCU ID: 0x2292
    FLASH ID0: 88740089 <=> INTEL -> 28F640W18TE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    No ini files found...
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-305\rm305_04.110
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-305\rm305_04.11md
    Languages in ppm: English,Filipino,Vietnamase
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-305\rm3050_nai4.11md
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rm-305\rm305_04.110
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x74888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: df
    Loader is ready...
    MSID: 84A75197F6CC59393F64638625
    MSID decoded: 3E4EBAE9001BDAF4A8000000
    FAID: 2CC503FB8DE184A14ECB797D
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0179FFFF...
    Erasing area: 017A0000 - 017EFFFF...
    Erasing area: 01F00000 - 01FDFFFF...
    Operation took 1 minutes 8 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 20 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rm-305\rm305_04.11md
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0125FFFF...
    Erasing area: 01260000 - 0175FFFF...
    Operation took 0 minutes 44 seconds...
    Writing...
    Operation took 0 minutes 26 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rm-305\rm3050_nai4.11md
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8430D2180DA0E9A3B95B745D26
    MSID decoded: 3E4EBAE9001BDAF4AA000000
    FAID: 230D3077F47C8B8EA59D5C80
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01760000 - 0179FFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 48 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    xóa full nạp ver 3 loại ver từ thấp đến cao rồi vẫn thế
    đây là log MT
    ASIC ID: 2292
    DCT4
    u3_2nd.fia
    u3_amd.fia
    84B06CB1F76A8F19D1D980093939
    Configuration Info (9F):
    Number of Flashes: 2
    01000000: Amd, 0001 327E 0043 7221, 11
    02000000: NotUsed, 0000 0001 0000 0000, 0
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Erase[5.12 MB]...
    erasing region [01240000 to 0125FFFF]
    erasing region [01260000 to 0175FFFF]
    in 26.22s
    Flash[2.75 MB]...in 18.50s
    * * Processed file in 58.03 seconds
    * * * Phone flashing done in 2: 9 minutes
    Post Flash serial tunning of phone....
    Pooling mode for full factory set...
    Phone not responding, try to set manually!
    thay 2 con cpu 1200 vẫn thế không hiểu tại sao hay cpu già yếu rồi không đồng bộ được
    Thành viên chính thức TH Mobile's Avatar
    Jul 2007
    đóng chuẩn ko, nếu chuẩn thay con flash khác ,ko được đo xem có đức mạch in từ cpu qua fláh thử xem .
    log như vầy chỉ có cpu ,flash ,đức mạch in thôi.
    Thiên tài gồm 1% là năng khiếu, còn 99% là mồ hôi
    V.I.P chithanh's Avatar
    May 2007
    Thanh Thảo mobile Vĩnh long
    con 1650 này chép nhạc vào cũng bị pan này,trước khi mổ o thử flash nó lại,giờ lấy con cpu cũ của nó đóng lại xem sao,chủ yếu làm lại chỗ đã làm và kiểm tra mạch chỗ làm kỹ lại.đừng làm tùm lum mà thêm bệnh,thân!
    V.I.P DinhKha™'s Avatar
    Kiên Giang
    làm chân cpu thật đẹp đóng lại thôi bạn àh.
    Haiphonggsm.vn
    chắc em đóng không chuẩn rồi pro
    SỬA LẠI CÁI CHỬ KÝ CHO LỊCH SỰ 1 CHÚC ĐI BẠN .
    Haiphonggsm.vn
    cpu cũ nó khò cái có bầu luôn rồi anh ơi
    Haiphonggsm.vn
    nhưng liệu cpu của 1200 có thể vào cho 1650 không . Ai đã tes và thành công rồi không
    T4M
    T4M vẫn chưa có mặt trong diễn đàn
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Trích Được post bởi khoianlao Xem bài viết
    Cpu 1200 xai chung voi 1650.
    Đúng là bệnh restart thay cpu se ok.
    khi thay xong nhớ unlock cái nha,nếu không sẽ bị contactservice đó.
    Nếu cần cpu thì buzz nha.
    V.I.P duclam882003's Avatar
    Jan 2007
    HoaLư_Ninh Bình
    Chính xác là bạn phải thay luôn cả UEM rồi mất 1log la ok .../.
    TRUNG TÂM SỬA CHỮA & DẠY NGHỀ CHUYÊN NGHIỆP DUCHIEP MOBILE
    ĐT:0303.624.999*091.583.9989.Số TK:3308205007879-AGB NINH BINH
    V.I.P phungtien's Avatar
    cà mau
    uh. mấy cái bệnh restart thì đúng là cpu rồi nhưng trước hết nên nạp mềm nó lại+ làm chân cpu cho chuẩn=> cuối cùng hãy tính tới thay cpu
  1. MobiMB v3.5.3.9 Reloaded (Unofficial) for Nokia 1200, 1202/03, 1650, 1650, 1661
    By TUYHOAGSM™ in forum Chương trình cài hình nhạc cho các lọai ĐTDĐ
    Bài viết cuối: 27-10-2010, 09:37
  2. 1650 loi pm
    By tin ht in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 25-12-2009, 15:01
  3. cau cưu 1650
    By tran thanh hung in forum DCT4 - WD2
    Bài viết cuối: 16-05-2009, 20:43
