Kết quả 1 tới 3 của 3
    Thành viên chính thức tatdad's Avatar
    Dec 2007
    Mặc định help 6230
    MCU ID: 0x1052
    FLASH ID0: 00000000 <=> Flash -> not detected Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 0
    FLASH ID1: FFFEFFFE <=> Flash ID not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    FLASH ID2: 00000000 <=> Flash -> not detected Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00000000 <=> Flash -> not detected Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 9E E5 9E E5 9E E5 9E E5 9E E5 9E E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11003.140
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11003.14v
    Languages in ppm: English,Vietnamese,Chinese S,Chinese T
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-12\rh12_28_11003.140
    Booting phone...
    MCU ID: 0x1052
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x00000000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: ca
    Loader is ready...
    P-key nokia module version 01.01
    MSID: 84722F10E0DB6EAC56F6EB0661
    MSID decoded: CAB3BAE90053E1BDA9000000
    FAID: 195A1747DC160543B8CBB41C
    Operation took 0 minutes 19 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 007FFFFF...
    Erasing area: 00800000 - 008FFFFF...
    Erasing area: 00B20000 - 00FEFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Permanent Data Restore FAILED!
    Operation took 44 minutes 59 seconds...
    Restarting MCU...
    Failed! Aborting!
    lu0n lu0n lAng ngh3...lAu lAu m0i hi3u
    Dec 2006
    347 Lê Văn Lương TP Hưng Yên
    bỏ file cnt đi rùi chạy lại coi sao
    Web :http://gsmhungyen.com/
    Dec 2007
    em ko chạy file CNT mà
  1. Trả lời: 21
    Bài viết cuối: 24-10-2008, 09:38
  2. 6230 của em mất míc...
    By vaodoi in forum DCT4 - WD2
    Bài viết cuối: 14-09-2008, 08:10
  3. 6230 cua e la k cac bac ne!
    By dungnv86 in forum DCT4 - WD2
    Bài viết cuối: 30-08-2008, 10:35
  4. 6230 mất mic
    By thekien in forum DCT4 - WD2
    Bài viết cuối: 31-12-2007, 23:54
  5. 6230 bệnh của 6230
    By GSMBT in forum DCT4 - WD2
    Bài viết cuối: 21-12-2007, 09:09
