MTB_NK 1.21 Released.
New in this version:
-Revised algorithm for flashing BB5 phones with ( rap3 + ape processors).
-Flashing time is significantly improved.
-All BB5 phones currently on market are fully supported ( with latest FIA 6.14.010).
-Changed post flash procedure so FullFactory Set is executed faster on phones like 6270/6280.
-Added information for erase while flashing BB5 phones.
-Added Recognition whether VPP pin is connected correctly to phone. ( see note 1, for more information. )
Notes:
VPP pin recognition: You need to do a small modification on your 8to10 pin converter.
See 'VPP_PIN_RECOGN.pdf' for details on the modification.
After that when using 8pin cables MTBox will be able to measure the voltage on VPP pin. So when you press 'Phone Info' and the phone is connected through the converter MTBox will measure and try to detect if VPP is connected to correct pin. If it's not, WARNING text will be displayed and VPP will be automatically disabled. Vpp is also measured while flashing. To see current reading of VPP pin use ( boot information button ).
Download MTB_NK_setup121.exe from GT torrent server.
BR GT
			 ** MT-box NK updates history** - 18-05-2006 - MTB_NK_v1.21.exe Setup
