Kết quả 1 tới 2 của 2
    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định mobileEx Service Suite
    Features
    * DCT4 Flashing
    MXSS has custom flashing that will allows user to select function like Skip BT
    or BT Flash Only.
    * CDMA NFP Flashing
    no need to extract the NFP file, just Load the NFP and MXSS will do it for you.
    * FTD(Net Monitor) Enable
    Yes, This is your most usefull tool for DCT4 repair. MXSS allow to Enable this function.
    Just Flash phone on any version with FTD on checkbox checked.
    * DCT4 (Direct) IMEI and ESN patching
    Direct IMEI/ESN Changing without Changing UEM!
    Enter IMEI whatever digit u want
    As well as Warranty IMEI/ESN changed and Automaticly Direct Unlock after patch.
    Supported model and version for now (will be updated continously...):
    NEM-1 [Nokia 3300] v4.62 NHL-4 [Nokia 7210] v5.52 NHL-4J [Nokia 7250] v3.62 NHL-4JX[Nokia 7250i] v5.41 NHL-4U [Nokia 6610] v5.52 NHL-6 [Nokia 6800] v5.46 NHL-9 [Nokia 6820a] v5.30 NHM-4 [Nokia 8910] v4.03 NHM-7 [Nokia 8310] v6.20 NHM-8 [Nokia 3510] v5.02 NPE-4 [Nokia 6310] v5.01 NPL-1 [Nokia 6310i] v7.00 NPL-2 [Nokia 6100] v6.01 NPL-4 [Nokia 5140b] v3.17 NPL-5 [Nokia 5140] v3.17 NPM-6 [Nokia 5100] v5.20 NPM-9 [Nokia 6510] v4.21 RH-4 [Nokia 6108] v5.30 RH-9 [Nokia 3530] v5.35 RH-19 [Nokia 3100] v6.01 RH-20 [Nokia 6220] v6.34 RH-23 [Nokia 7200] v4.30 RH-30 [Nokia 3200] v5.34 RH-33 [Nokia 7200b] v4.30 RH-50 [Nokia 3100b] v5.01 RH-53 [Nokia 2650] v6.18 RM-37 [Nokia 6610i] v4.20 RH-17R/NA [Nokia 2280/i] vF175V0500.nep
    * PhoneSafe and IMEI Restore
    everytime MXSS scanning products, it will save 'secure' IMEI data by it self.
    and you will be save when something BAD happen after flashing and imei bcome ???????????????
    MXSS could RESTORE imei data from saved values or from phone secure block.
    Also It could Restore phone that has corrupted 'SIMLOCK DATA' for phone with imei ???????????????
    And phone not switched OFF after 32 s.
    This method could be tricky by IMEI patching too...
    So, If after FLASHING your phone imei corrupted, DO NOT TRY FLASH IT MORE, you can restore it
    by MXSS(Note: that after second and more flashing secure data couldnt be recovered anymore)
    This function also support ESN as well.
    * Direct Unlocking for ANY DCT4 Phone
    Supported ASIC Type 2,3,4,5,6,7,8
    Allow to LOCK to NET, AUTOLOCK to NET or IMSI.
    * Nokia Extended TEST tool
    This function contains AUDIO test,VIBRATE test, LIGHT test, BT MCM(new version) test,
    LCD test pattern.
    Also u could trace the ADC values form phone.
    And SELF TEST that most needed for CS repair.
    * Read Ask
    Able to read UEM IMEI/ESN and made correct ask files for CDMA and GSM to use with GTOnlineAccess.
    Also could read ask with default format for using with FREE B-phreaks PhoneRestore services.
    * Write RPL
    Directly Write RPL data to phone for all asic type support CDMA or GSM.
    * Backup RPL
    There is special function on MXSS.
    MXSS able read and backup RPL data for all nokia phone!
    It support 1100,2300,2600 and soon series for RPL backup.
    ALSO MXSS could backup RPL data for DEAD PHONE on all ASIC 2 phone and TIKU phone.
    * CDMA Tuning
    Yeah...
    MXSS will do phoenix jobs for you. It could Read TUN and PRL from phone and save to a files,
    WRITE DIRECTLY the TUN and PRL data as phoenix sw did. It support RUIM and NON RUIM phone.
    with MXSS, Tuning CDMA phone never been easier.
    * Read and Write PM easily
    Customable pmm manager, u can read Important Values Only or the Full Values.
    Also you can manage or edit is in single mode and see the changes on phone quickly.
    * Menu Editor/ Product Profile write
    * Phone Reset, Format User Area
    * And Some other great features...
    * Flashing
    A User friendly SIEMENS flasher
    SIEMENS EGOLD flasher as replacement of old freia_ufs.
    * Contrast Tool, EEprom Management
    * Format File System.
    Integrated Virtual COM Port(Support UFS,J.A.F and Martech Box II) is available for FREE those who have UFSxCOM Licence activation.
    This function is disabled by default.
    To enable this customer need to buy activation separately.
    SIEMENS flasher is available for FREE for COM port connection.
    TODO features:
    ADSP Flashing, More CDMA patched partials, CDMA pri writing.
    Good Tool
    http://www.mobileex.info
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
    Thành viên mới goloaqn's Avatar
    Jan 2006
    khi connect nó đòi code anh ui ;
    edited by taihv, reason: size is not allow!
  1. Trả lời: 0
    Bài viết cuối: 19-09-2012, 21:35
  2. Xin bản cài đặt mobileex 3.5.1.9
    By 2_LÚA in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 02-05-2012, 06:56
  3. Trả lời: 0
    Bài viết cuối: 26-02-2012, 10:18
  4. UFSPRO Service Suite v1.01
    By Tamansu in forum DCT4 - WD2
    Bài viết cuối: 31-12-2008, 13:22
