Dùng Smartclip.
W156, W160, W175, W180, W230
For unlock purposes the models W156, W160, W175, W180, W230 require to be connected to PC USB port.
1. Connect S-Card and Mini USB data cable to PC USB port and launch SmartMoto.
2. Select "Computer COM ports" in Phone connection area.
3. Log to the tab "Compal models"
4. Choose an appropriate model from the list.
5. Press Unlock button.
6. SmartMoto will inform "Connect phone to computer USB port before proceeding".
7. Connect data cable to the powered OFF phone with inserted battery.
8. The SmartMoto will automatically (no user intervention is required during the installation) install "Locosto flash interface" driver and display the following message: "reconnect phone and try again".
9. Disconnect data cable form the phone, remove and insert the battery back to the phone.
10. Connect data cable and press Unlock again.
11. The unlock process continues.
12. Message "Unlock ok" informs that process is finished and the phone can be disconnected.
NOTE
For unlock purposes the only driver that is required is the "Locosto flash interface" driver. No need to install the phone W156, W160, W175, W180, W230 model driver.
Nếu hay thì ấn.......T..................
