cây 1110i của em khởi động lên có sóng được 10s thì mất. Em đã thây 2 PA rồi cũng vẫn vậy. Write thì nó lỗi (em chỉ coppy 1 đoạn cuối)
Field: 198, Record: 21, Len: 302->OK
Field: 198, Record: 22, Len: 302->OK
Field: 198, Record: 23, Len: 302->OK
Field: 198, Record: 24, Len: 302->OK
Field: 198, Record: 25, Len: 302->OK
Field: 198, Record: 26, Len: 302->OK
Field: 198, Record: 27, Len: 302->OK
Field: 198, Record: 28, Len: 302->OK
Field: 198, Record: 29, Len: 302->OK
Field: 201, Record: 0, Len: 4->Error code: 5
Field: 201, Record: 1, Len: 32->Error code: 5
Field: 201, Record: 2, Len: 4->Error code: 5
Field: 209, Record: 0, Len: 4->OK
Field: 209, Record: 1, Len: 32->OK
Field: 209, Record: 2, Len: 4->OK
Field: 210, Record: 0, Len: 302->OK
Field: 210, Record: 1, Len: 302->OK
Field: 210, Record: 2, Len: 302->OK
Field: 210, Record: 3, Len: 302->OK
Field: 210, Record: 4, Len: 302->OK
Field: 210, Record: 5, Len: 302->OK
Field: 210, Record: 6, Len: 302->OK
Field: 210, Record: 7, Len: 302->OK
Field: 210, Record: 8, Len: 302->OK
Field: 210, Record: 9, Len: 302->OK
Field: 210, Record: 10, Len: 302->OK
Field: 210, Record: 11, Len: 302->OK
Field: 210, Record: 12, Len: 302->OK
Field: 210, Record: 13, Len: 302->OK
Field: 210, Record: 14, Len: 302->OK
Field: 210, Record: 15, Len: 302->OK
Field: 210, Record: 16, Len: 302->OK
Field: 210, Record: 17, Len: 302->OK
Field: 210, Record: 18, Len: 302->OK
Field: 210, Record: 19, Len: 302->OK
Field: 210, Record: 20, Len: 302->OK
Field: 210, Record: 21, Len: 302->OK
Field: 210, Record: 22, Len: 302->OK
Field: 210, Record: 23, Len: 302->OK
Field: 210, Record: 24, Len: 302->OK
Field: 210, Record: 25, Len: 302->OK
Field: 210, Record: 26, Len: 302->OK
Field: 210, Record: 27, Len: 302->OK
Field: 210, Record: 28, Len: 302->OK
Field: 210, Record: 29, Len: 302->OK
Field: 213, Record: 0, Len: 4->Error code: 5
Field: 213, Record: 1, Len: 32->Error code: 5
Field: 213, Record: 2, Len: 4->Error code: 5
Field: 214, Record: 0, Len: 120->Error code: 5
Field: 214, Record: 2, Len: 90->Error code: 5
Field: 214, Record: 4, Len: 110->Error code: 5
Field: 214, Record: 5, Len: 2->Error code: 5
Field: 214, Record: 6, Len: 90->Error code: 5
Field: 214, Record: 11, Len: 2->Error code: 5
Field: 214, Record: 12, Len: 2->Error code: 5
Field: 215, Record: 0, Len: 1->Error code: 5
Field: 215, Record: 1, Len: 30->Error code: 5
Field: 215, Record: 2, Len: 16->Error code: 5
Field: 216, Record: 0, Len: 4->Error code: 5
Field: 216, Record: 1, Len: 4->Error code: 5
Field: 216, Record: 2, Len: 4->Error code: 5
Field: 216, Record: 3, Len: 4->Error code: 5
Field: 216, Record: 4, Len: 1->Error code: 5
Field: 216, Record: 5, Len: 6->Error code: 5
Field: 216, Record: 6, Len: 4->Error code: 5
Field: 216, Record: 7, Len: 2->Error code: 5
Field: 216, Record: 8, Len: 1->Error code: 5
Field: 216, Record: 9, Len: 4->Error code: 5
Field: 216, Record: 10, Len: 31->Error code: 5
Field: 216, Record: 11, Len: 2->Error code: 5
Field: 216, Record: 12, Len: 1->Error code: 5
Field: 216, Record: 13, Len: 1->Error code: 5
Field: 216, Record: 14, Len: 1->Error code: 5
Field: 216, Record: 15, Len: 1->Error code: 5
Field: 216, Record: 16, Len: 8->Error code: 5
Field: 216, Record: 17, Len: 1->Error code: 5
Field: 216, Record: 18, Len: 1->Error code: 5
Field: 216, Record: 19, Len: 4->Error code: 5
Field: 216, Record: 20, Len: 2->Error code: 5
Field: 216, Record: 21, Len: 2->Error code: 5
Field: 216, Record: 22, Len: 1->Error code: 5
Field: 216, Record: 23, Len: 8->Error code: 5
Field: 216, Record: 24, Len: 1->Error code: 5
Field: 216, Record: 25, Len: 2->Error code: 5
Field: 216, Record: 26, Len: 2->Error code: 5
Field: 216, Record: 27, Len: 2->Error code: 5
Field: 216, Record: 28, Len: 2->Error code: 5
Field: 216, Record: 29, Len: 2->Error code: 5
Field: 216, Record: 30, Len: 4->Error code: 5
Field: 216, Record: 31, Len: 4->Error code: 5
Field: 216, Record: 32, Len: 4->Error code: 5
Field: 216, Record: 33, Len: 4->Error code: 5
Field: 216, Record: 34, Len: 4->Error code: 5
Field: 216, Record: 35, Len: 4->Error code: 5
Field: 216, Record: 36, Len: 16->Error code: 5
Field: 216, Record: 37, Len: 4->Error code: 5
Field: 216, Record: 38, Len: 2->Error code: 5
Field: 216, Record: 39, Len: 4->Error code: 5
Field: 216, Record: 40, Len: 2->Error code: 5
Field: 216, Record: 41, Len: 2->Error code: 5
Field: 216, Record: 42, Len: 1->Error code: 5
Field: 216, Record: 43, Len: 1->Error code: 5
Field: 216, Record: 44, Len: 4->Error code: 5
Field: 216, Record: 45, Len: 4->Error code: 5
Field: 216, Record: 46, Len: 4->Error code: 5
Field: 216, Record: 47, Len: 4->Error code: 5
Field: 216, Record: 48, Len: 4->Error code: 5
Field: 216, Record: 49, Len: 4->Error code: 5
Field: 216, Record: 50, Len: 4->Error code: 5
Field: 216, Record: 51, Len: 4->Error code: 5
Field: 216, Record: 52, Len: 4->Error code: 5
Field: 216, Record: 53, Len: 4->Error code: 5
Field: 216, Record: 54, Len: 4->Error code: 5
Field: 216, Record: 55, Len: 4->Error code: 5
Field: 216, Record: 56, Len: 4->Error code: 5
Field: 216, Record: 57, Len: 4->Error code: 5
Field: 216, Record: 58, Len: 4->Error code: 5
Field: 216, Record: 59, Len: 4->Error code: 5
Field: 216, Record: 60, Len: 4->Error code: 5
Field: 216, Record: 61, Len: 4->Error code: 5
Field: 216, Record: 62, Len: 4->Error code: 5
Field: 216, Record: 63, Len: 4->Error code: 5
Field: 216, Record: 64, Len: 4->Error code: 5
Field: 216, Record: 65, Len: 4->Error code: 5
Field: 216, Record: 66, Len: 4->Error code: 5
Field: 216, Record: 67, Len: 4->Error code: 5
Field: 216, Record: 68, Len: 4->Error code: 5
Field: 216, Record: 69, Len: 4->Error code: 5
Field: 216, Record: 70, Len: 4->Error code: 5
Field: 216, Record: 71, Len: 4->Error code: 5
Field: 216, Record: 72, Len: 4->Error code: 5
Field: 216, Record: 73, Len: 4->Error code: 5
Field: 216, Record: 74, Len: 4->Error code: 5
Field: 216, Record: 75, Len: 4->Error code: 5
Field: 216, Record: 76, Len: 4->Error code: 5
Field: 216, Record: 77, Len: 4->Error code: 5
Field: 216, Record: 78, Len: 4->Error code: 5
Field: 216, Record: 79, Len: 4->Error code: 5
Field: 216, Record: 80, Len: 4->Error code: 5
Field: 216, Record: 81, Len: 4->Error code: 5
Field: 216, Record: 82, Len: 2->Error code: 5
Field: 216, Record: 83, Len: 4->Error code: 5
Field: 216, Record: 84, Len: 2->Error code: 5
Field: 216, Record: 85, Len: 1->Error code: 5
Field: 216, Record: 86, Len: 16->Error code: 5
Field: 216, Record: 87, Len: 88->Error code: 5
Field: 216, Record: 88, Len: 2->Error code: 5
Field: 216, Record: 89, Len: 4->Error code: 5
Field: 216, Record: 90, Len: 2->Error code: 5
Field: 216, Record: 91, Len: 2->Error code: 5
Field: 216, Record: 92, Len: 2->Error code: 5
Field: 216, Record: 93, Len: 2->Error code: 5
Field: 216, Record: 94, Len: 2->Error code: 5
Field: 216, Record: 95, Len: 2->Error code: 5
Field: 216, Record: 96, Len: 2->Error code: 5
Field: 216, Record: 97, Len: 2->Error code: 5
Field: 216, Record: 98, Len: 2->Error code: 5
Field: 216, Record: 99, Len: 2->Error code: 5
Field: 216, Record: 100, Len: 2->Error code: 5
Field: 216, Record: 101, Len: 2->Error code: 5
Field: 216, Record: 102, Len: 2->Error code: 5
Field: 216, Record: 103, Len: 2->Error code: 5
Field: 216, Record: 104, Len: 2->Error code: 5
Field: 216, Record: 105, Len: 2->Error code: 5
Field: 216, Record: 106, Len: 2->Error code: 5
Field: 216, Record: 107, Len: 2->Error code: 5
Field: 216, Record: 108, Len: 2->Error code: 5
Field: 216, Record: 109, Len: 2->Error code: 5
Field: 216, Record: 110, Len: 2->Error code: 5
Field: 216, Record: 111, Len: 2->Error code: 5
Field: 216, Record: 112, Len: 2->Error code: 5
Field: 216, Record: 113, Len: 2->Error code: 5
Field: 216, Record: 114, Len: 2->Error code: 5
Field: 221, Record: 0, Len: 4->OK
Field: 221, Record: 1, Len: 32->OK
Field: 221, Record: 2, Len: 4->OK
Field: 222, Record: 0, Len: 302->OK
Field: 222, Record: 1, Len: 302->Error code: 5
Field: 222, Record: 2, Len: 302->Error code: 5
Field: 222, Record: 3, Len: 302->Error code: 5
Field: 222, Record: 4, Len: 302->Error code: 5
Field: 222, Record: 5, Len: 302->Error code: 5
Field: 222, Record: 6, Len: 302->Error code: 5
Field: 222, Record: 7, Len: 302->Error code: 5
Field: 222, Record: 8, Len: 302->Error code: 5
Field: 222, Record: 9, Len: 302->Error code: 5
Field: 222, Record: 10, Len: 302->Error code: 5
Field: 222, Record: 11, Len: 302->Error code: 5
Field: 222, Record: 12, Len: 302->Error code: 5
Field: 222, Record: 13, Len: 302->Error code: 5
Field: 222, Record: 14, Len: 302->Error code: 5
Field: 222, Record: 15, Len: 302->Error code: 5
Field: 222, Record: 16, Len: 302->Error code: 5
Field: 222, Record: 17, Len: 302->Error code: 5
Field: 222, Record: 18, Len: 302->Error code: 5
Field: 222, Record: 19, Len: 302->Error code: 5
Field: 222, Record: 20, Len: 302->Error code: 5
Field: 222, Record: 21, Len: 302->Error code: 5
Field: 222, Record: 22, Len: 302->Error code: 5
Field: 222, Record: 23, Len: 302->Error code: 5
Field: 222, Record: 24, Len: 302->Error code: 5
Field: 222, Record: 25, Len: 302->Error code: 5
Field: 222, Record: 26, Len: 302->Error code: 5
Field: 222, Record: 27, Len: 302->Error code: 5
Field: 222, Record: 28, Len: 302->Error code: 5
Field: 222, Record: 29, Len: 302->Error code: 5
Field: 225, Record: 0, Len: 4->Error code: 5
Field: 225, Record: 1, Len: 32->Error code: 5
Field: 225, Record: 2, Len: 4->Error code: 5
Field: 226, Record: 0, Len: 120->Error code: 5
Field: 226, Record: 2, Len: 90->Error code: 5
Field: 226, Record: 4, Len: 110->Error code: 5
Field: 226, Record: 5, Len: 2->Error code: 5
Field: 226, Record: 6, Len: 90->Error code: 5
Field: 226, Record: 11, Len: 2->Error code: 5
Field: 226, Record: 12, Len: 2->Error code: 5
Field: 227, Record: 0, Len: 17->Error code: 5
Field: 228, Record: 0, Len: 4->Error code: 5
Field: 228, Record: 1, Len: 32->Error code: 5
Field: 228, Record: 2, Len: 4->Error code: 5
Field: 233, Record: 0, Len: 4->OK
Field: 233, Record: 1, Len: 32->OK
Field: 233, Record: 2, Len: 4->OK
Field: 234, Record: 0, Len: 302->OK
Field: 234, Record: 1, Len: 302->Error code: 5
Field: 234, Record: 2, Len: 302->Error code: 5
Field: 234, Record: 3, Len: 302->Error code: 5
Field: 234, Record: 4, Len: 302->Error code: 5
Field: 234, Record: 5, Len: 302->Error code: 5
Field: 234, Record: 6, Len: 302->Error code: 5
Field: 234, Record: 7, Len: 302->Error code: 5
Field: 234, Record: 8, Len: 302->Error code: 5
Field: 234, Record: 9, Len: 302->Error code: 5
Field: 234, Record: 10, Len: 302->Error code: 5
Field: 234, Record: 11, Len: 302->Error code: 5
Field: 234, Record: 12, Len: 302->Error code: 5
Field: 234, Record: 13, Len: 302->Error code: 5
Field: 234, Record: 14, Len: 302->Error code: 5
Field: 234, Record: 15, Len: 302->Error code: 5
Field: 234, Record: 16, Len: 302->Error code: 5
Field: 234, Record: 17, Len: 302->Error code: 5
Field: 234, Record: 18, Len: 302->Error code: 5
Field: 234, Record: 19, Len: 302->Error code: 5
Field: 234, Record: 20, Len: 302->Error code: 5
Field: 234, Record: 21, Len: 302->Error code: 5
Field: 234, Record: 22, Len: 302->Error code: 5
Field: 234, Record: 23, Len: 302->Error code: 5
Field: 234, Record: 24, Len: 302->Error code: 5
Field: 234, Record: 25, Len: 302->Error code: 5
Field: 234, Record: 26, Len: 302->Error code: 5
Field: 234, Record: 27, Len: 302->Error code: 5
Field: 234, Record: 28, Len: 302->Error code: 5
Field: 234, Record: 29, Len: 302->Error code: 5
Field: 237, Record: 0, Len: 4->Error code: 5
Field: 237, Record: 1, Len: 32->Error code: 5
Field: 237, Record: 2, Len: 4->Error code: 5
Field: 238, Record: 0, Len: 120->Error code: 5
Field: 238, Record: 2, Len: 90->Error code: 5
Field: 238, Record: 4, Len: 110->Error code: 5
Field: 238, Record: 5, Len: 2->Error code: 5
Field: 238, Record: 6, Len: 90->Error code: 5
Field: 238, Record: 11, Len: 2->Error code: 5
Field: 238, Record: 12, Len: 2->Error code: 5
Field: 240, Record: 0, Len: 4->Error code: 5
Field: 240, Record: 1, Len: 32->Error code: 5
Field: 240, Record: 2, Len: 4->Error code: 5
Field: 245, Record: 0, Len: 4->OK
Field: 245, Record: 1, Len: 32->OK
Field: 245, Record: 2, Len: 4->OK
Field: 246, Record: 0, Len: 302->OK
Field: 246, Record: 1, Len: 302->Error code: 5
Field: 246, Record: 2, Len: 302->Error code: 5
Field: 246, Record: 3, Len: 302->Error code: 5
Field: 246, Record: 4, Len: 302->Error code: 5
Field: 246, Record: 5, Len: 302->Error code: 5
Field: 246, Record: 6, Len: 302->Error code: 5
Field: 246, Record: 7, Len: 302->Error code: 5
Field: 246, Record: 8, Len: 302->Error code: 5
Field: 246, Record: 9, Len: 302->Error code: 5
Field: 246, Record: 10, Len: 302->Error code: 5
Field: 246, Record: 11, Len: 302->Error code: 5
Field: 246, Record: 12, Len: 302->Error code: 5
Field: 246, Record: 13, Len: 302->Error code: 5
Field: 246, Record: 14, Len: 302->Error code: 5
Field: 246, Record: 15, Len: 302->Error code: 5
Field: 246, Record: 16, Len: 302->Error code: 5
Field: 246, Record: 17, Len: 302->Error code: 5
Field: 246, Record: 18, Len: 302->Error code: 5
Field: 246, Record: 19, Len: 302->Error code: 5
Field: 246, Record: 20, Len: 302->Error code: 5
Field: 246, Record: 21, Len: 302->Error code: 5
Field: 246, Record: 22, Len: 302->Error code: 5
Field: 246, Record: 23, Len: 302->Error code: 5
Field: 246, Record: 24, Len: 302->Error code: 5
Field: 246, Record: 25, Len: 302->Error code: 5
Field: 246, Record: 26, Len: 302->Error code: 5
Field: 246, Record: 27, Len: 302->Error code: 5
Field: 246, Record: 28, Len: 302->Error code: 5
Field: 246, Record: 29, Len: 302->Error code: 5
Field: 249, Record: 0, Len: 4->Error code: 5
Field: 249, Record: 1, Len: 32->Error code: 5
Field: 249, Record: 2, Len: 4->Error code: 5
Field: 250, Record: 0, Len: 120->Error code: 5
Field: 250, Record: 2, Len: 90->Error code: 5
Field: 250, Record: 4, Len: 110->Error code: 5
Field: 250, Record: 5, Len: 2->Error code: 5
Field: 250, Record: 6, Len: 90->Error code: 5
Field: 250, Record: 11, Len: 2->Error code: 5
Field: 250, Record: 12, Len: 2->Error code: 5
Field: 252, Record: 0, Len: 4->Error code: 5
Field: 252, Record: 1, Len: 32->Error code: 5
Field: 252, Record: 2, Len: 4->Error code: 5
Done!
Em cũng đã write mấy cái PM rồi cũng vẫn vậy. Con chiêu còn nữa không mấy huynh
			 1110i sóng 10s
 1110i sóng 10s
