Đây log unlock Sumo1200 ok
JAF version 1.98.61
Detected PKEY: xxxxxx
Card life counter: 94.40%
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
USB Cable Driver version: 6.85.10.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Reading...
MCU SW version: V 5.71
12-09-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.71
12-09-08
RH-99
(c) NMP
MR
ADSP SW version: V 5.71\n12-09-08\nRH-99\n(c) NMP\nmr
Production serial number: IGR186568
Product code: 0574499
Module code: 0203402
Basic production code: 0571402
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356845027663259
IMEI spare to net: 3A 65 48 05 72 66 23 05
IMEI SV to net: 33 65 48 05 72 66 23 65 F7
Master Code: 2201427151
Phone type: RH-99, Software version: 5.71, Language Pack: MR
User code: ÿ#
Block 1:
Lock 1: CLOSED -> Lock Data: 45204F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0574499
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.710
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.71aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.71aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Done!
Unlocking...
IMEI: 356845027663259
ASIC: b
SW version: 5.71
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.710
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Erasing area: 011E0000 - 011FFFFF...
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Failed! Aborting!
Reading...
Failed! Aborting! IMEI
Failed! Aborting!
Failed! Aborting!
Reading...
12-09-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.71
12-09-08
RH-99
(c) NMP
MR
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Done!
Unlocking...
ASIC: b
SW version: 5.71
Decrypting flash...
Encrypting....
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Failed! Aborting!
Changing mode...Done!
Failed! Aborting!
Reading...
12-09-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.71
12-09-08
RH-99
(c) NMP
MR
Flash code:
Order number:
Long production SN:
ATO:
Failed! Aborting!
Reading...
12-09-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.71
12-09-08
RH-99
(c) NMP
MR
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Done!
Unlocking...
ASIC: b
SW version: 5.71
Decrypting flash...
Encrypting....
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 0
			 Unlock Sumo1200 ok
 Unlock Sumo1200 ok
