Kết quả 1 tới 10 của 10
    Thành viên chính thức ducchien's Avatar
    Mặc định Nokia 3120 rh-19 IMEI????????? xin giúp đỡ
    em nhạn con máy n3120 rh-19 của khách. Mở nguồn lên nó báo đã hạn chế điện thoại, em cho vào hộp JAF info lên thì nó như này:
    MCU ID: 0x1120
    FLASH ID0: 7E270100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05.91
    22-10-04
    RH-19
    (c) Nokia.
    HW version: 3020
    PCI version:
    UEM version: 8
    UPP version: 4384
    RFIC version: 03122
    DSP version: N4.11
    LCD version: X4
    PPM version: V 05.91
    22-10-04
    RH-19
    (c) Nok
    S
    Production serial number: M7B970320
    Product code: 0516543
    Module code: 0202449
    Basic production code: 0518626
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: m?????????????????????????????????????????????????
    Default SN type: m?????????????????????????????????????????????????
    IMEI plain: ???????????????
    IMEI spare to net: FA FF FF FF FF FF FF 0F
    IMEI SV to net: F3 FF FF FF FF FF FF 0F F8
    PDC: 4E 54 54 4A 50 12 34 56
    Master Code: 5013663745
    Phone type: RH-19, Software version: 05.91 , Language Pack: S
    User code: 12345
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-19.ini
    Setting local mode...
    Reading product code...
    Product Code: 0516543
    No ini files found...
    Done!
    Repairing BT...
    Done!
    Repairing BT...
    Done!
    Reading...
    22-10-04
    RH-19
    (c) Nokia.
    HW version: 3020
    PCI version:
    UEM version: 8
    UPP version: 4384
    RFIC version: 0300
    DSP version: N4.11
    LCD version: X4
    22-10-04
    RH-19
    (c) Nok
    S
    Flash code:
    Order number:
    Long production SN:
    User code: 12345
    Done!
    Em mới vào nghề nên không biết bắt đầu từ đâu, xin các Bác giúp đỡ!
    Thành viên mới bibiluan's Avatar
    Jan 2008
    ban chem lai imel di la duoc thoi
    lưu ý : không trích dẫn bài viết quá dài , post bài tiếng việt có dấu rõ ràng
    V.I.P HoangViet902's Avatar
    Núi Bà Đen
    imei banh xác rồi , send file đồng bộ lại imei thôi
    86 phan đình phùng quảng ngãi
    banh imei rồi bạn thay con last khác tốn 30000 đồng một lốc ok
    Núi Bà Đen
    Trích Được post bởi gia nguyen Xem bài viết
    banh imei thì send ask lấy rpl đồng bộ lại imei , hoặc uem sắp dead thì thay uem khác , chứ thay flash khác làm gì trời
  6. ( HoangViet902 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ducchien (22-11-2008)
    Thành viên chính thức hoimo's Avatar
    cái này phải mua log ma gởi file thôi bạn
    chúc thành công ,Thấn
    Giang Hồ Đẩm Máu Anh Không Sợ
    Chỉ Sợ Ngày Về Vắng Bóng Em
    Thành viên mới hoangthieugia's Avatar
    Dec 2008
    mất imei mà thya fl thì có tác dụng gì đâu hả
  9. #8
    Thành viên tích cực tiepmobile's Avatar
    Trích Được post bởi hoangthieugia Xem bài viết
    con máy đó bạn reads ask rùi gửi lấy rpl theo link free này xem sao nha
    http://nfader.z-host.ru/Decoder/
    ps:đôi khi nhầm một tý anh em phải thông cảm cho nhau.
    HUYỀNNGÂN MOBILE:249 trần thành ngọ- kiến an- hải phòng
    yahoo:huyennganmobile sdt:0989666966
  10. #9
    V.I.P GSM Hải Phòng's Avatar
    Haiphonggsm.vn
    Chú ý : bài post đã lâu .Anh em nên để ý ngày tháng post bài nha
  11. #10
    Trích Được post bởi GSM Hải Phòng Xem bài viết
    sorry mod nha.hiiiiiiiiiiiiiiiiiiii
  1. 3120 bị banh imei xin giúp log
    By madao in forum DCT4 - WD2
    Bài viết cuối: 02-09-2010, 01:14
  2. 3120 imei ???????
    By giaphu_dn in forum DCT4 - WD2
    Bài viết cuối: 17-04-2009, 17:05
  3. 3120 imei ???????
    Bài viết cuối: 16-04-2009, 13:43
  4. 3120 imei ?????????
    By sybenlove in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 12-11-2007, 09:08
  5. 3120 Bị Mất Imei
    By nguyen in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 09-11-2007, 15:15
