    Vi phạm nội quy MOBILENOKIA's Avatar
    Mặc định các bác sem có sai sót gì kô mà máy kô nên nguôn anh ạ
    em chạy 1110i nhận hết mà not ok kô lên nguôn mới đau chứ bỏ tụ đường bsi dồi mà vẫn nót ok
    Getting MCU ID
    MCU ID: 0x2201
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    P-key nokia module version 01.01
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 7.02
    10-12-07
    RH-93
    (c) NMP
    HW version: 0526
    PCI version:
    UEM version: 1328
    UPP version: 8705
    RFIC version: 0500
    DSP version: P05w06.v34
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: V 7.02
    10-12-07
    RH-93
    (c) NMP
    MD
    ADSP SW version: V 7.02\n10-12-07\nRH-93\n(c) NMP\nmd
    Production serial number: IAI740625
    Product code: 0537102
    Module code: 0203169
    Basic production code: 0536354
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 358995014154370
    IMEI spare to net: 3A 85 99 05 41 51 34 07
    IMEI SV to net: 33 85 99 05 41 51 34 47 F5
    Master Code: 1412253554
    Phone type: RH-93, Software version: 7.02, Language Pack: MD
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
    Setting local mode...
    Reading product code...
    Product Code: 0537102
    No ini files found...
    Done!
    Backup IMEI zone...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Getting MCUID...
    MCU ID: 0x2201
    Reading flash chip detailes...
    MCU ID: 0x2201
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Languages in ppm: English,Filipino,Vietnamase
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    MSID: 846CB426EE9F6CA9CDE0B1694C
    MSID decoded: 3E4EBAE9000B27FBAA000000
    FAID: 474637170547EC66DA4D744F
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 40 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 17 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_07.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Operation took 0 minutes 16 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai7.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8496AA46E763F7FCC3C8022A9D
    MSID decoded: 3E4EBAE9000B27FBA8000000
    FAID: 31BAC649C83E39982036BAB8
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Writing...
    Operation took 0 minutes 2 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 43 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    IMEI: 358995014154370
    Product Code:
    Resetting PPC...
    Done!
    V.I.P GSM Hải Phòng's Avatar
    Haiphonggsm.vn
    check bis coi sao
    V.I.P HoangViet902's Avatar
    Núi Bà Đen
    @MOBILENOKIA nên edit lại cái tiêu đề cho rõ ràng , bạn đặt tiêu đề sai quy định"]
    cái log đẹp rồi , remove con r2205 , kiểm tra các điện trở bsi và thay là ok
  4. ( HoangViet902 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    MOBILENOKIA (25-11-2008)
    Trích Được post bởi HoangViet902 Xem bài viết
    phải công nhận mod hay cái quan trọng nhất là r2205 ma kô thấy nó là mấu chốt
    Trích Được post bởi khoianlao Xem bài viết
    check bis coi sao
    bsi em là đầu tiên mà nót ok thay tất cả tụ bsi remove r2205 not ok thế mới đau chứ
    văn yên_yên bái
    bạn hạ ver sem sao nếu không lên thì làm uem . chúc bác thành công
    cuối cùng vẫn phải choi uem mớ nên
  1. c1-01 lắp pin không nên nguồn?
    By NHC_2010 in forum BB5
    Bài viết cuối: 02-05-2015, 18:30
  2. Trả lời: 11
    Bài viết cuối: 20-09-2012, 09:40
  3. 1202 nên nguồn 1 lúc rồi sập nguồn ???????
    By g8andchip in forum DCT4 - WD2
    Bài viết cuối: 03-04-2012, 10:17
  4. v300_3 A 606 bât nguôn nên tat
    By NAMTIENmobil in forum Phần mềm và các mã lệnh
    Bài viết cuối: 23-04-2009, 13:41
  5. máy 6210 nên nguồn mà ko nên nguồn
    By chungxit8x in forum DCT3-DCTL
    Bài viết cuối: 14-11-2008, 11:06
