Device start-up failed . Contact the retailer
BUZZ!!!
hightlight verygood: chao
hightlight verygood: alo
susohoaban_computer: ok
hightlight verygood: Device start-up failed . Contact the retailer
hightlight verygood: gap pha nay chua ong oi
hightlight verygood: NG QD
susohoaban_computer: Ngate-QD chu gi
hightlight verygood: uh
susohoaban_computer: Ong lam the nao ma bi nhu the
hightlight verygood: dang dung thi bi thoi
susohoaban_computer: Format lai di xem the nao. Neu khong duoc thi flash lai.
susohoaban_computer: Toi cung da gap roi nhung lau roi khong gap
hightlight verygood: format roi
hightlight verygood: flash roi cung bo tay luon
susohoaban_computer: ong flash nhu the nao dong nay khong can than la bi ngay do
hightlight verygood: the a chi luon cho cai.
susohoaban_computer: Chi chay thoi dung thiet lap mac dinh cai gi ca. Chon MCU+PPM roi flash thoi dung tich dau gi ca
hightlight verygood: nhung lan truoc toi tich het roi.gio chay lai co duoc ko
susohoaban_computer: sau khi flash xong thi chon trong o ben canh UI setting lan luot la Norman sau do den local cho no chay xong chon format user area la oke thoi neu khong duoc nua nhan lai cho toi
hightlight verygood: con gi nua ko
hightlight verygood: chao ban
hightlight verygood: cho minh hoi chut nhe
Hippo Tiet:
hightlight verygood: minh co con NG -QD bat len bao
hightlight verygood: su ly mai ma ko duoc.. ban co cach nao mach dum voi
Hippo Tiet: da xu ly gi roi
hightlight verygood: minh format user roi
hightlight verygood: chay lai flash cung ko duoc
Hippo Tiet: cai nay neu nhe thi format user la se het
Hippo Tiet: xoa full flash roi nap lai thu
Hippo Tiet: hoac co griffin thi chay file erase vo ppm
hightlight verygood: minh xoa roi cung ko duoc luon
hightlight verygood: minh co uffs + hwwk
Hippo Tiet: con dung torndo thi luc boot no co hien dia chi con flash
Hippo Tiet: erase thi dia chi cua no
Hippo Tiet: roi flash lai
hightlight verygood: dia chi nao vay ban
Hippo Tiet: luc boot no co hien ra do
Hippo Tiet: 00000000 - 00700000 gi do
Hippo Tiet: minh hong nho
hightlight verygood: doi minh boot nhe
Hippo Tiet: ban bam flash luc no hien ra thi stop lai
Hippo Tiet: sau do erase theo dia chi do
Hippo Tiet: QD thi no co 2 dia chi
hightlight verygood: MCU Sw: V 04.10 09-09-2004 RH-29 (c)NMP
PPM Sw: V 04.10 09-09-2004 RH-29 (c)NMP.07
BT Det:
Prd.Cd: 0514248
Bpr.Cd: 0510311
Pro.Sn: SHB481944
HW : 0056
PCI :
UEM : 8
UPP : 4225
RFIC : 0300
DSP : Sl3.00_Cm2.41
LCD :
IMEI : 353360-00-326388-7
SLconf: 1ED-2D-9B99830E816
SLprof: 46B04B235DCA264-5
SLvar : 00553533600032638800
SLaux : 00050000
Provider: Not Found
#pw+ 732 090 756 042 402 +1#
#pw+ 907 242 623 574 753 +2#
#pw+ 248 555 162 657 762 +3#
#pw+ 818 441 633 636 650 +4#
#pw+ 445 437 165 316 246 +5#
#pw+ 984 152 302 233 566 +6#
#pw+ 187 934 005 521 640 +7#
Hippo Tiet: chon file bam vo flash
Hippo Tiet: luc no moi chay 1st boot gi do
Hippo Tiet: thi stop lai
hightlight verygood: roi sao nua
Hippo Tiet: no hien ra 2 doan dia chi thay chu
Hippo Tiet: thay chua ?
Hippo Tiet: gio bam vo erase , luc do no se cho minh nhap dia chi vo de xoa
hightlight verygood: day
hightlight verygood: minh thay nhu sau
hightlight verygood: 1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x00FFFFFF,0001007E,Amd 29BDS128J
Fl1: 0x02000000-0x027FFFFF,0001277E,Amd 29BDS064J
Algorithm: w3_amd.fia, w3_cbusb.fia, Ver: 4.52.0
** User Break **
hightlight verygood: xoa dia chi 1081 a ban
Hippo Tiet: doan flash thu nhat ne 0x00000000-0x00FFFFFF
Hippo Tiet: doan flash thu hai 0x02000000-0x027FFFFF
Hippo Tiet: luc xoa no se cho minh nhap 2 lan
Hippo Tiet: lan dau la day so phia truoc , lan 2 la day so phia sau
Hippo Tiet: ban xoa tung con flash
Hippo Tiet: xoa xong 2 con thi nap full lai
hightlight verygood: minh van chua hieu cach lap lull
hightlight verygood: lay file nao vay ban
Hippo Tiet: nap full la nap du 2 file do ma
hightlight verygood: a.
hightlight verygood: khi flash co can tich vao nhung o ben duoi ko ban
Hippo Tiet: ko can
Hippo Tiet: chay xong roi init simlock la duoc roi
Hippo Tiet: neu van khogn duoc thi format user lai lan nua
hightlight verygood: cam on ban nhe.
Hippo Tiet: ok , goodluck
hightlight verygood: da ta
hightlight verygood: co gi minh nhan lai ket qua nhe.
Hippo Tiet: ok
hightlight verygood: ok
duchungmobile is currently not in your Messenger List.
Add to your Messenger List (Ctrl+Shift+A) Report as Spam (Alt+Shift+R)
duchungmobile ngô đưÌ?chuyen gi
duchungmobile ngô đưÌ?c huÌ€ng: Uisettinh dê
hightlight verygood: ko duoc
hightlight verygood: minh erase flash cung bo tay
duchungmobile ngô đưÌ?c huÌ€ng: * + 3 + call + PW
hightlight verygood: cai do thi ko can ban nua ban oi
hightlight verygood: minh flash lai roi cung ko duoc nua
duchungmobile ngô đưÌ?c huÌ€ng: cung ko dc à
hightlight verygood: ko duoc moi khoai chu
hightlight verygood: anh em trong nghe chi nhieu lam roi.
hightlight verygood: nhung theo minh thi bi phan cung roi
hightlight verygood: nhung khong biet la con nguon hay con flash
hightlight verygood: dang phan van duc con nao
duchungmobile ngô đưÌ?c huÌ€ng: để hỏi su phụ cái dã
hightlight verygood: hoi cho cai di
hightlight verygood: may con roi toan pai tra ve dia phuong
hightlight verygood: tuc that
duchungmobile ngô đưÌ?c huÌ€ng: loi ram
duchungmobile ngô đưÌ?c huÌ€ng: nhãy cái ram th?
hightlight verygood: lai ram a
duchungmobile ngô đưÌ?c huÌ€ng: su Phu bao la ram
duchungmobile ngô đưÌ?c huÌ€ng: làm vài lan roi
hightlight verygood: the a.
duchungmobile ngô đưÌ?c huÌ€ng: uh
hightlight verygood: con ram re chet ko ong
hightlight verygood: lieu kho nhe vao co di nguon ko.
hightlight verygood: toi so nhat la chet nguon. kho tra lai cho khach
duchungmobile ngô đưÌ?c huÌ€ng: làm dc ta chia dôi nha
hightlight verygood: ok so gi
duchungmobile ngô đưÌ?c huÌ€ng: the thì làm chân ram dê
hightlight verygood: ok chu . de mai toi thu.
duchungmobile ngô đưÌ?c huÌ€ng: ac
duchungmobile ngô đưÌ?c huÌ€ng: the mai chia tiên nha
duchungmobile ngô đưÌ?c huÌ€ng: gooluck
hightlight verygood: khiii chua chi da doi chia roi
hightlight verygood: hay toi de bac lam ca
hightlight verygood: do ton tien den khach
duchungmobile ngô đưÌ?c huÌ€ng: ko
duchungmobile ngô đưÌ?c huÌ€ng: lam ca ko hay
duchungmobile ngô đưÌ?c huÌ€ng: chia dôi thôi
hightlight verygood: toi tu nguyen ma
hightlight verygood: dao nay cong viec the nao ban
duchungmobile ngô đưÌ?c huÌ€ng: thôi
hightlight verygood: troi nang qua cung chan. chang thiet nua
duchungmobile ngô đưÌ?c huÌ€ng: di cái dã
hightlight verygood: accc
hightlight verygood: bo tay . the tu nay toi gio toan nin thoi a
hightlight verygood: lam phien roi. bey.
hightlight verygood: chuc *** ngon
hightlightverygood (6/7/2006 11:13:16 Chieu): cuu
hightlightverygood (6/7/2006 11:13:21 Chieu): cuu
traitimkhongloi_xd (6/7/2006 11:13:29 Chieu): ji
traitimkhongloi_xd (6/7/2006 11:13:48 Chieu): noi
hightlightverygood (6/7/2006 11:13:53 Chieu): NG QD bat len bao loi Device start-up failed . Contact the retailer
traitimkhongloi_xd (6/7/2006 11:14:42 Chieu): chua
traitimkhongloi_xd (6/7/2006 11:14:46 Chieu): chua gap
traitimkhongloi_xd (6/7/2006 11:14:58 Chieu): nhug chac la phan mem roi.
HUUUUUUUU
EM BIẾT LÀM SAO ĐÂY.
XIN CÁC BÁC ĐịNH ĐOẠT DÙM EM. ( xIN LỖI VỀ PHÔNG CHỮ KO ĐÁNH TIẾNG VIỆT EM MUỐN LỘI DUNG THẢO LUẬN ĐỰƠC GIỮ NGUYÊN. ) HIIIIIIII
