    T4M
    T4M vẫn chưa có mặt trong diễn đàn
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Arrow ..:: W850i change new Flash IC ok ::..
    Máy W850i bị tình trạng trắng màn hình chớp liên tục.Sau khi REPAIR GDFS lúc xài được,lúc trắng màn hình nên mình quyết định thay New Flash.Kết quả rất ok.
    Thấy chưa ai post cách thay New Flash hoàn hỏa nên mình mạng phép post lên,để new member có thể tham khảo.
    ĐÂY LÀ SOLUTIONS:
    Code:
    Go to EmptyFill tab
    Select W850
    CID=49
    Press RECOVERY
    Load db2020gdfs_in_ssw_format_CID49_BROWN.ssw.cry and DB2020EROM_RED52_SIGNED_CID49_BROWN.ssw (both files at once)
    Fill IMEI number
    Press FLASH.
    Go to Sony Ericsson tab
    Load MAIN firmware and press FLASH
    Load W850_GDFS.bin in MISC field and press WRITE GDFS
    Go to Emptyfill tab
    Select CID49 and press RECOVERY
    Load DB2020EROM_RED52_SIGNED_CID49_BROWN.ssw and press FLASH
    Goto Sony Ericsson tab
    Load MAIN + FS + CUSTOM (OR COMPLETE PHONE OPTION) and press FLASH
    Test Phone. If works OK, then GoTo EmptyFill tab,seclect CID49 and press RECOVERY,load DB2020EROM_RED52_SIGNED_CID49_BROWN.ssw, fill IMEI, check OTP IMEI and press FLASH.
    LOGS LÀM THÀNH CÔNG
    Code:
    v0.91380096/UNI
    Card serial:00030462
    Loaded 51 flash descriptors
    RECOVERY MODE STARTED
    Open COM port OK
    REC:061220 1711 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3K
    Recovery succefull. Reflash phone now
    Elapsed:8 secs.
    Open COM port OK
    ChipID:9900,EMP protocol:0301
    Speed:921600
    OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 CERT:BROWN
    FLASH CID:49 COLOR:BROWN
    060721 1021 DB2020_SERVICE_LOADER
    Flash ID check:897E
    Flash props sent ok
    writing C:\Documents and Settings\THANHTAM\Desktop\SE380096\gdfs_in_ssw_format\db2020gdfs_in_ssw_format_CID49_BROWN.ssw.cry
    CURRENT FLASH FILE CID:49
    SSW uses complete hash, hash len is:640
    Will flash 32 blocks...
    SSW loading returns:0
    writing C:\Documents and Settings\THANHTAM\Desktop\SE380096\eroms\DB2020EROM_RED52_SIGNED_CID49_BROWN.ssw
    SSW uses complete hash, hash len is:40
    Will flash 2 blocks...
    Setting up GDFS...
    OTP WRITE NOT EXECUTED.
    Clearing total time...
    Writing simlocks...
    ALL UNLOCK/LOCK CODES SET TO "47514063"
    Signing...
    control keys complete.
    full sig complete.
    Elapsed:51 secs.
    Open COM port OK
    Speed:921600
    FLASH CID:52 COLOR:RED
    phone CID not supported in that mode
    Elapsed:1 secs.
    SERVER SUPPORT ENABLED.
    Open COM port OK
    Speed:921600
    OTP LOCKED:0 CID:15 PAF:1 IMEI:04857555048575 CERT:RED
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    Flash ID check:897E
    Flash props sent ok
    writing E:\SETOOL3\SONYERICSSON\THANHTAM\W850\CID52\R1KG001_1250204_CHINA_CY.ssw
    CURRENT FLASH FILE CID:52
    SSW uses complete hash, hash len is:9200
    Will flash 460 blocks...
    Elapsed:509 secs.
    POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK
    PHONEBOOK NOT DETECTED IN GDFS FILE
    Open COM port OK
    Speed:921600
    Elapsed:1 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CSloader version:
    070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009
    loader startup: executed
    loader GDFS startup: executed
    loader unlock: executed
    Will write GDFS now.
    will write 1306 variables
    cut length from 5950(02/0FA3)
    cut length from 2710(03/1389)
    cut length from 1637(03/138E)
    cut length from 1635(03/138F)
    cut length from 1635(03/1776)
    cut length from 1635(03/1777)
    cut length from 1635(04/1B5C)
    cut length from 4010(04/1B5F)
    cut length from 4760(04/1F44)
    done
    Phone detached
    Elapsed:58 secs.
    Open COM port OK
    Speed:921600
    Elapsed:1 secs.
    Open COM port OK
    Speed:921600
    Elapsed:7 secs.
    Open COM port OK
    Elapsed:16 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    Setting up GDFS...
    Writing simlocks...
    ALL UNLOCK/LOCK CODES SET TO "06224762"
    Signing...
    full sig complete.
    Elapsed:12 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    writing E:\SETOOL3\SONYERICSSON\THANHTAM\W850\CID52\R1KG001_FS_APAC_CY_RED_CID52.ssw
    SSW uses complete hash, hash len is:5140
    Will flash 257 blocks...
    CSloader version:
    loader filesystem startup: executed
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed:825 secs.
    Open COM port OK
    Speed:921600
    Elapsed:4 secs.
    Open COM port OK
    Speed:921600
    Elapsed:6 secs.
    Open COM port OK
    Abort all operations.
    phone pre-boot failed,possible RECOVERY needed.
    Elapsed:5 secs.
    Open COM port OK
    Speed:921600
    Elapsed:9 secs.
    Open COM port OK
    Elapsed:11 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    Setting up GDFS...
    Writing IMEI:xxxxxxxxxxxxxxxxxx
    write OTP complete.
    Writing simlocks...
    ALL UNLOCK/LOCK CODES SET TO "70416128"
    Signing...
    full sig complete.
    Elapsed:15 secs.
    Anh em sau này gặp dòng DB2020 này thì làm nhiệt tình vào nhé,keo rất mềm và board rất good.Thiếu đồ chơi thì pm mình tiếp.
    How to change Old Flash?
    How to change New CPU?
    How to change Old CPU?
    Mình sẽ post cách làm ok những chủ đề này sau.
    TRUNG TÂM SỬA CHỮA & BẢO HÀNH ĐTDĐ T4M
    SỬA CHỮA CHUYÊN NGHIỆP-UNLOCK,CHUYỂN HỆ,SỬA LỖI PHẦN MỀM
    40b,NGUYỄN THÁI BÌNH,P.4,Q.TB ÐT: (08)62966082-(08)73000234 YH&SKY: t4_mobile
  2. ( T4M ) đã được 7 thành viên cám ơn vì bài viết hữu ích!
    anpha72000 (20-12-2008), chithanh (06-12-2008), HoangViet902 (10-12-2008), nhanmobile (07-01-2009), triviet8xx (07-01-2009), tuanmb (07-01-2009), zumazi (20-09-2009)
    Thành viên chính thức xauxilx2005's Avatar
    Jul 2007
    thay New Flash là bạn thay flash mới hay lấy cũ thay qua giải thích cho mình nhé
    IMEI:04857555048575 là sao ngộ vậy ta????????
    T4M
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Trích Được post bởi xauxilx2005 Xem bài viết
    Thay Flash mới chứ củ đâu bạn.
    Để số Imei này xài bình thường,khỏi write Imei cũng được.Có thể Flash này sử dụng qua máy khác.
    Nhưng khách yêu cầu Imei thì làm Imei.Chỉ write vùng OTP này 1 lần.
  5. ( T4M ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    xauxilx2005 (07-01-2009)
    Jul 2007
    Trích Được post bởi t4_mobile Xem bài viết
    bạn có thể chỉ khi mình thay new flash viết vào vùng OTP imei thì cách làm ra sao .Có thể viết giống 15 số imei cũ trên sườn lại k nhé
    PS: mình k biết nên hỏi ah nghe chứ k có ý gì khác thank you
    T4M
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Go to EmptyFill tab
    Select W850
    CID=49
    Press RECOVERY
    Fill IMEI number
    Press FLASH.
    Go to Emptyfill tab
    Test Phone
    Màu Xanh là các bứoc chúng ta phỉa làm khi thay Flash mới.
    Màu Đỏ là viết Imei nhưng không viết cũng xài bình thường.Quan trọng hơn nửa là ta có thể tận dụng IC Flash này mãi mãi cho nhưng máy khác.
  8. ( T4M ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    họcsinh (23-01-2009)
  1. ORT JTAG - HTC One Max Full Supported , Repair Boot , IMEI Change , SN , CID Change ,
    Bài viết cuối: 13-04-2016, 09:18
  2. ORT JTAG - HTC One Mini (HTC M4) Unlock , Repair , IMEI Change , CID Change and more
    Bài viết cuối: 26-11-2014, 17:40
  3. ORT JTAG -HTC 8S A620E / HTC RIO Repair Boot , Change SN , Change IMEI Full Support
    Bài viết cuối: 19-05-2014, 14:01
  4. ORT JTAG - HTC Ruby-Amaze 4G [PH851000] Repair Boot,Unlock,IMEI Change,SN Change,CID
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 23-10-2012, 13:44
  5. flash W850i
    By luutac in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 23-03-2009, 23:42
