Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-93\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.910
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.91qa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai6.91qa
Languages in ppm: English,Chinese S,Chinese T
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_06.910
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: bb
Loader is ready...
MSID: 847A0B7EB1021998BA13E20DDC
MSID decoded: 3E4EBAE900926C72A9000000
FAID: 52085394DD5CB8D48552C30B
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 34 seconds...
Writing...
Error cmd: 14!
Addr: 01000000
đóng hết lại thay cpu+nguồn +flash chạy vẫn báo vậy là sao các bác
