Kết quả 1 tới 4 của 4
    V.I.P HongDiep's Avatar
    Jan 2008
    Củ Chi-HCM
    Mặc định HWK Release 14/01/2009
    Release Date: 14/01/2009
    The Official release is ready in our download area http://sarunasoftware.com.
    WARNING !!!
    If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
    UFS_DCTxBB5 v2.0.8.0a
    1. Flash Fix added to installer
    Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone.
    SAMs V 2.0.8.1
    TRIDENT
    CC01,P258,U600G added (DUNL,IM,FL)
    TRIDENT VISION
    B220,B310,B320,B518,B520,B528,J600G,J610,J618,M318 ,M620,M628
    added (CUNL,FL)
    L320 added (DUNL,IM,FL)
    (Use [Reset MMI] if phone ask for password)
    OM(SYSOL)
    B110 added (DUNL,IM,FL,SECT)
    SWIFT
    D618,D980,E2510,F250L,F268,F278,G600G,G618,J770,J8 08E,L258,M150,
    M200,M3200,M3510,S3600,T429,U708E,U808E added(DUNL,IM,FL,SECT)
    D780,D788,D880,D888,D980 SLAVE support added (DUNL,IM,SECT)
    J150 fixed (DUNL,IM,SECT)
    IM Rebuild added and RAW TFS Read fixed for these models:
    D618,D780,D788,D880,D888,D900i,D908i,D980,E200,E20 8,E250,
    E250D,E250V,E256,E258,E258D,E251,E251C,E480,E488,E 590,E598,
    E740,E747,E830,E838,E2510,F110,F250,F250L,F258,F26 8,F278,G600,
    G608,G808E,G618,J150,J210,J700,J708,J770,J808E,L25 8,L310,L600,
    L608,M150,M200,M610,M618,M3200,M3510,P180,P260,S36 00,T429,U708E,
    U808E,U908E (Need power up phone with battery after IM done !)
    SWIFT-AEROFONE
    B130,B130S,B130T added (DUNL,IM,FL,SECT)
    SWIFT-3G
    B2700,J800,L700,L708 introduced (DUNL,FL,SECT,BT)
    SKYWORKS
    C100 - 'Not Released Yet' bug fixed.
    QUALCOMM
    F480G,F480H,M7500,M8800,S7330,U900F,U900G,U900K added(FL,INF,REUL)
    Added QualComm mode support:
    (*#QUAUSB# to enter QualComm mode, QC Debug Interface on USB)
    (*#SAMUSB# to enter Samsung mode, QC Debug Interface on RJ45)
    QCDI Info, NVM Read, RAM Read added.
    UNLOCK and UNFREEZE introduced for these models:
    F480x,L760x,U900x,Z240 (Use [QCDI Info] button to readout keys)
    COMMON
    Stop button added.
    User interface localisation.
    Update Client V 2.0.8.1
    Fixed Exception errors on req-fbi process
    !!!THERE IS NO NEED TO UPDATE YOUR HWK SINCE 2080 RELEASE IF ITS WORKING OK !!!
    We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future.
    Conditions:-
    1. Only 1 contributer per language.
    2. You must know how to use the software and what each function does.
    3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required.
    Many thanks to all those who have supported us!!!
    Nhận Tính Code SL3 Cho AE 150k từ 1 đến 12h all model YH: hongdiep1980- Tel:0908535999
  2. ( HongDiep ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    haithong (14-01-2009), quangdanh (14-01-2009)
    Thành viên chính thức quangdanh's Avatar
    Trích Được post bởi HongDiep Xem bài viết
    WARNING !!!
    SAMs V 2.0.8.1
    TRIDENT
    TRIDENT VISION
    added (CUNL,FL)
    OM(SYSOL)
    SWIFT
    SWIFT-AEROFONE
    SWIFT-3G
    SKYWORKS
    QUALCOMM
    COMMON
    Stop button added.
    Conditions:-
    Bản nầy dow về bung ra bị lổi nầy[Install cannot continue,aborting] xin giúp cám ơn nhiều.
    Thành viên tích cực hehe6922's Avatar
    Dec 2008
    Vào nó báo bản v02.08.000, thì hình như có lâu rồi mà, hay đây là bản mới. Mình kô biết nhiều lắm, mong anh em chỉ bảo giùm.
    HOT LINE O9O6.855.899
    http://sieuthitrungtam79.mov.mn/
    Thành viên chính thức HP Mobile's Avatar
    Dec 2008
    My Home
    Wink
    Trích Được post bởi hehe6922 Xem bài viết
    HWK_Support_Suite_Setup_v02.07.000 là bản cài cũ, HWK_Support_Suite_Setup_v02.08.000 là bản cài chính mới 14/09/2008, Suite_Setup_v02.08.001 là bản 14/01/2009 update thêm một số dòng máy cho bản cũ v02.08.000. Các bản cài này chỉ dùng cho hộp UFS end N-Box có gắn HWK zin của nhà cung cấp.
    Ở đời có 5 cái ng u:
    Làm mai - lãnh nợ - gác cu - cầm chầu - cái ng u cuối cùng là ngồi câu cá.
  6. ( HP Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hehe6922 (15-01-2009)
  1. HWK Release 21/03/2009
    By maidung_mobile in forum Saras Boxes - HWK
    Bài viết cuối: 23-11-2009, 16:20
  2. HWK Release 18/08/2009
    By hungphongmobile™ in forum Saras Boxes - HWK
    Trả lời: 25
    Bài viết cuối: 21-08-2009, 22:05
  3. HWK Release 18/08/2009
    By TUYHOAGSM™ in forum HWK
    Bài viết cuối: 19-08-2009, 08:29
  4. HWK Release 06/04/2009
    Bài viết cuối: 06-04-2009, 17:47
