Em vừa nhận của khách con 6230i chạy TV ma chạy chỉ được đến chổ này xin các huynh dúp em,nếu chỉ chạy mỗi fai MCU thì cho chạy hết nhưng chạy thêm fai ngôn ngữ là báo như vậy các cao tăng có kinh nghiệm xin chỉ bảo em.Xin cảm ơn nhiều
MCU ID: 0x2051
FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-72\rm72_73_11003.800
MCU: C:\Program Files\Nokia\Phoenix\Products\rm-72\rm72_73_11003.800
Booting phone...
MCU ID: 0x2051
BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
Boot size is 0x2398
Boot is ready...
Flash ID is 0x22E800EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
Loader size is 0x84A0; Loader chk: 4c
Loader is ready...
MSID: 84EBC16582669755A18AA863E2
MSID decoded: FE4CBAE900249BA4A8000000
FAID: 93A87893C09CDD78FCC9AF18
Operation took 0 minutes 19 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 009FFFFF...
Erasing area: 00A00000 - 00B3FFFF...
Erasing area: 00B60000 - 00FAFFFF...
Operation took 2 minutes 17 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 55 seconds...
Restarting MCU...
NAND Format OK!
Flashing Done!
Operation took 3 minutes 47 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-72, Software version: 03.80
IMEI: 353233016533143
Product Code:
Resetting PPC...
Done!
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-72\rm72_73_110E_03.80v
Languages in ppm: English,Vietnamese,Chinese S,Chinese T
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rm-72\rm72_73_110M_03.80.ucp_v
Booting phone...
MCU ID: 0x2051
Boot size is 0x2398
Boot is ready...
Loader is ready...
Erasing...
Writing...
Restarting MCU...
NAND Format OK!
CNT: C:\Program Files\Nokia\Phoenix\Products\rm-72\rm72_73_110M_03.80.ucp_v
Booting phone...
MCU ID: 0x2051
Boot size is 0x2398
Boot is ready...
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia
Loader size is 0x5648; Loader chk: 7b
Loader is ready...
Operation took 0 minutes 16 seconds...
Erasing Content Pack...
Mass Memory Device Detected...
MM Bus Configured...
Formating MM...Format OK
Mass Memory Opened...
Mass Memory Erased...
Writing...
Operation took 0 minutes 27 seconds...
Restarting MCU...
Extracting Content Pack...
Running: (c) Nokia File Server
CP Extract Failed!
PPM: C:\Program Files\Nokia\Phoenix\Products\rm-72\rm72_73_110E_03.80v
Booting phone...
MCU ID: 0x2051
Boot size is 0x2398
Boot is ready...
Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia
Loader size is 0x9858; Loader chk: b3
Loader is ready...
Operation took 0 minutes 18 seconds...
Erasing PPM...
Error MM Open!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.80A
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.80.ucp_A
Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.80.ucp_A
Booting phone...
MCU ID: 0x2051
Boot size is 0x2398
Boot is ready...
Loader is ready...
Formating MM...Format failed!
