Kết quả 1 tới 4 của 4
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định Unlock Code Instructions for LG Cell Phones for All Networks
    In this guide I will show you how to enter unlock codes .
    Below are instructions that work for most network providers.
    How to Unlock LG (most models):
    1:Insert not-allowed SIM card
    2: Power on the handset- phone will display "phone restricted"
    3:Select "Cancel" - phone will display "phone restriction code"
    4:Enter the SIM unlock code
    5:Select "OK" - the handset is now successfully unlocked
    How to Unlock LG KG245 (Vodafone Australia)
    1:Insert a Vodafone Australia working SIM card.
    2: Ensure the phone is charged and then switch the phone on.
    3: Optional Step: If the SIM card has a PIN, enter your PIN number
    4:Wait for the phone to power up then enter 2945#*7101#
    5:Select Menu , then go to Settings > Security > SIM Lock > Network
    6:Select Deactivate and enter the 8-digit unlocking code provide for your handset.
    7:The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
    How to Unlock LG KG800 or TG800 Chocolate:
    1:With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
    2:Go to: Settings>Security>SimLock>Network
    3:Select deactivate. Enter the unlock code,
    How to Unlock LG C2000:
    Insert non-Cingular SIM card
    1: Power on the handset - phone will display "phone restricted"
    2: Select "Cancel" - phone will display "phone restriction code"
    3: Enter the SIM Unlock code
    4: Select "OK" - the handset is now successfully unlocked
    How to Enter Unlock Codes on LG F2250:
    1:With allowed sim card in the start menu type: 2945#*3311#.
    2: Handset shows saved, then return to startup screen
    3: Press Menu key, choose Settings > Security > Sim Lock> Network eactivate, handset will now show 'Enter NCK'
    4:Enter your unlock code and OK.
    How to Enter Unlock Codes on LG U8150:
    1: Switch ON your phone with a not allowed SIM card.
    2: Compose: 277634#*#.
    3: Go to menu "SIM Lock".
    4:Enter the unlock code, which you can buy any online store .
    How to Enter Unlock Codes on LG U8110:
    1:With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
    2:Select 'Sim Unlock' menu #
    3:Enter NCK code then validate
    Your phone is now unlocked.
    How to Enter Unlock Codes on LG U8210:
    1:With a not allowed sim card enter Pin code then validate, type: 277634#*#
    2:Shows test menu
    3:Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
    4:Handset shows 'Enter NCK'
    5:Enter code, then hit OK.
    How to Enter Unlock Codes on LG U81xx:
    1:To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
    2:Enter the code
    In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
    How to Enter Unlock Codes on Cingular AT&T LG CU500:
    1: Insert non-Cingular SIM card.
    2: Power on the handset. Phone will display "Invalid SmartChip"
    3IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
    4:In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
    5:Enter the 8 digit SIM unlock code, which you can buy any Oline phones.
    6:Select "OK". The handset is now successfully unlocked
    How to Enter Unlock Codes on all other LG cell phones:
    Switch ON your phone with an allowed SIM card
    Then compose:
    2945#*5101# - (if you have a LG 510w)
    1945#*5101# - (if you have a LG 1200 & B1200)
    2945#*5221# - (if you have a LG 5200 & 52200)
    2945#*5301# - (if you have a LG 5300)
    2945#*5401# - (if you have a LG 5400)
    2945#*70001# - (if you have a LG 7020)
    2945#*7101# - (if you have a LG 7100)
    2945#*1201# or 2945#*70001# - (if you have a LG 1100)
    2945#*70001# - (if you have a LG7250T)
    2945#*2201# - (if you have a LG C2200)
    2945#*5301# - (if you have a LG T5100)
    2945#*3311# - (if you have a LG C3310)
    Go to "Menu" and then to "Settings"
    Then select "Security"
    To finish select "Network Provider" and select "Deactivate"
    Enter the unlock code, which you can buy Online store unlock-cell-phones.
    If your cell phone is not listed, please follow instructions for LG C2000 above
    How to Enter Unlock Codes on all other LG U400 Shine (2 codes needed):
    1:Insert the network SIM in the handset which works with the phone (from the locked carrier).
    2:Enter 2945#*88110#.
    3:The phone will then prompt 'Unlock sim'. Press OK.
    4:The phone will then prompt 'Network Unlock'. Press OK.
    5:The phone will then prompt- 'Input Network Control Key'. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
    6:It should give you the message: Success.
    7:Come back to the main screen and Enter 2945#*88110#.
    8:The phone will then prompt unlock sim. Press OK.
    9:The phone will then prompt Network Unlock/ Lock but if you scroll down
    10 :you will see a message Enter SP Lock. Enter SP Code.
    Then press OK.
    How to Enter Unlock Codes on all other LG KE970 Shine:
    1: Switch ON your phone with an allowed SIM card
    2: Then compose: 2945#*9701#
    3: Press CALL.
    4:I t should you ask you for the code.
    How to Enter Unlock Codes on all other LG TU720 Shine:
    1: Put in a non-allowed SIM, phone says invalid SIM card
    2: Now enter *#865625# then enter your 16 digits code.
    How to Unlock LG KG800 Chocolate Without a Code (not reliable):
    1: Insert SIM from the network that it is locked to.
    2: Turn on phone.
    3: On home Screen, slide up phone.
    4:Type 2945#*#
    5:ENG. Mode menu should appear.
    6:Go Down to Factory Reset. Select it. May take a few minutes to reset!
    7:This will reset the phone back to before the phone was locked to a network.
    8:The phone will automatically restart (the network logo at start up will not change).
    9:Now insert any SIM card and the phone should turn on normally
    10:The phone is now unlocked and you can customize the setting as you like
    BR,
    Hoang Thong Mobile
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
    Thành viên mới venkat20's Avatar
    Mặc định Sử dụng này
    Thanks For the Post about the Unlocking Details.U can ué the site for the Mobile Unlocking Íntructions Mobile Unlock Guide : Get unlocking instructions for your mobile phone
    Thành viên mới shalimar's Avatar
    thanks for the info
    Thành viên mới duongsm's Avatar
    May 2015
    thanks for the info
  1. Hua box ver 2.4.0 released add read bl code qualcomm and direct unlock hisi phones
    Bài viết cuối: 18-10-2016, 09:14
  2. List of Supported Cell Phones
    By HoangThong_hotrokythuat5 in forum SigmaKey
    Bài viết cuối: 23-02-2012, 08:58
  3. SmartMoto v4.28. Fixed issues with cell phones based on NOR flash
    By livemobi in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 28-11-2011, 22:18
  4. Unlock Code Instructions for LG Cell Phones for All Networks
    By HoangThong_hotrokythuat4 in forum LG 3G
    Bài viết cuối: 30-05-2011, 14:09
  5. Sharp GX1, GX10, GX10i, GX20, GX21, GX22 cell phones pinout
    By huynhkiet in forum CÁC LOẠI ĐIỆN THOẠI KHÁC
    Bài viết cuối: 04-01-2008, 06:48
