    Mặc định 1600 phần mềm
    nạp fần mềm 1600 báo
    etting MCU ID
    MCU ID: 0x2201
    FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
    First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Checking path: F:\Program Files\Nokia\Phoenix\Products\RH-64\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    FILES SET FOR FLASHING:
    MCU Flash file: F:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
    PPM Flash file: F:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02aa
    CNT Flash file: F:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02aa
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Languages in ppm: English,Dannish,Norwegian,Swedish
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: F:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
    Booting phone...
    MCU ID: 0x2201
    BOOT file: F:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x01000000
    Flash loader is F:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: a6
    Loader is ready...
    MSID: 8421707BE437777FBE8A7E1872
    MSID decoded: 3E4EBAE900471BCEA9000000
    FAID: 9B1553E79160B545A5936625
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Writing...
    Error cmd: 14!
    Addr: 01000000
    vậy là lỗi gì vậy
    V.I.P GSM Hải Phòng's Avatar
    Haiphonggsm.vn
    Khả năng lớn cpu lỏng chân
    Thành viên chính thức thanhanh822000's Avatar
    Mar 2008
    Trích Được post bởi CHHONGQUAN Xem bài viết
    Bạn kiểm tra lại con flash, hoặc tháo ra làm lại chân.rồi full flash xong quăng cái log lên nhé.Thân.
    Thành viên tích cực HAI_GSM™'s Avatar
    Dec 2008
    Phú Tân_An Giang
    làm lại cpu là ok.chúc bạn thành công
    Cho Là Nhận,Tặng Là Lấy
    Em đã thay cpu làm ok rồi thank mọi người
  1. 1600 chạy phần mềm mất nguồn
    By gaco_231 in forum DCT4 - WD2
    Bài viết cuối: 23-07-2011, 17:01
  2. xin phần mềm 1600
    By quocvuonganh in forum DCT4 - WD2
    Bài viết cuối: 28-01-2011, 16:47
  3. 1600 chạy phần mềm ko đc cần ae giúp
    By vantuan_4586 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 19-05-2010, 19:26
  4. 1600 lên tắt chạy phần mềm không được
    By nhotrung_bn in forum DCT4 - WD2
    Bài viết cuối: 05-01-2009, 23:18
  5. máy 1600 nạp phần mềm
    By CHHONGQUAN in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 07-08-2008, 08:54
