Hi !
Whats new !?
[x] Added ~100 new firmwares that cover KC910, KE990, CU920, KF390 reported as unsupported.
[x] Fixed some bugs introduced in previous update
[x] Added support for : SkypePhone 1, SkypePhone 2, SkypePhone 3, MOMODESIGN MD-1
NOTE: For any UNSUPPORTED FIRMWARE VERSION use DUMP ME option of the software.
DONGLE REQUIRES UPDATE !!!!!!!!
QCOM SMART TOOL MODULE SERVICING SOFTWARE
AMOI SUPPORTED MODELS:
SkypePhone 1 (WP-S1)
SkypePhone 2 (WP-S2)
SkypePhone 3 (INQ)
MOMODESIGN MD-1
LG SUPPORTED MODELS:
CU Series:
CU515, CU575, CU720, CU915, CU920
CB Series:
CB630 Invision (Go ‚Settings/Connection/USB Connection Mode’ and set it as ‚Data Service’
HB Series:
HB620
KB Series:
KB620
KC Series:
KC910, KC910Q, KC910Qa, KC910QAT
KE Series:
KE990
KF Series:
KF310, KF311, KF390, KF700
KT Series (Symbian OS):
KT610, KT615 (Go ‚Connectivity’ and set it as ‚Internet Services’)
KU Series:
KU250, KU380, KU385, KU970, KU990, KU990GO, KU990MF, KU990R
MU Series:
MU515
TU Series:
TU515, TU575, TU720, TU915
U Series:
U250, U300, U310, U370, U450, U880, U890, U900, U960, U970, U990
NOTE: All mentioned models are legally owned by us and were used for developement and testing of our solution.
GETTING STARTED
1. INSTALL DRIVERS CONTAINED BY ‚LGUSBModemDriver_WHQL_ML_Ver_4.7.zip’
2. BE SURE THAT ON ‚PHONE SETTINGS’ AT ‚CONNECTIVITY’ , ‚USB CONNECTION MODE’ IS SET AS ‚DATA SERVICE’
3. CONNECT PHONE TO ORIGINAL USB CABLE
4. ONCE YOU START SOFTWARE PRESS ‚SCAN PORTS’ FOR PHONE DETECTION
SUPPORTED FEATURES
1. SECURITY RESTORE (RESTORE SIMLOCK AND IDENTIFICATION AREA IN CASE PHONE GOT DAMAGED SOMEHOW WHILE OPERATING OUR SW OR IN CASE CUSTOMER CHANGED MIND ABOUT UNLCOKING IT FOR EXAMPLE)
2. RAM READ (YOU WILL NEVER NEED UNLESS WE ASK IT)
3. NAND READ (YOU WILL NEVER NEED UNLESS WE ASK IT)
4. OTP-IMEI-BTAD REPAIR (REPAIRS FAULTS SUCH AS ‚UNAVAILABLE OTP BLOCK’, AND/OR HELPS YOU REPAIR IMEI AND BLUETOOTH ADDRESS ON PHONES. PLEASE NOTE THAT SOME MODELS LIKE U250, U960 DEPENDING HW RELEASE MIGHT NOT ALLOW IMEI/BLUETOOTH OPERATIONS)
5. UNLOCK (SAFELY REMOVE OPERATOR RESTRICTIONS FROM PHONE)
6. DUMP ME (WHEN YOU GET UNSUPPORTED VERSION USE THIS FEATURE TO DUMP PHONE AND SEND US THE RAM_DUMP.bin FILE CREATED)
SPECIAL NOTES FOR U300, U310, U450, U880, U890, U900 MODELS
1. NOT ALL FIRMWARES SEE ALL KINDS OF SIMS. TO KNOW WHICH SUPPORT WHAT CHECK WITH US
2. REFLASHING PHONE WILL RELOCK IT. ISN'T OUR FAULT BUT THAT HAPPEN EVEN IF YOU UNLOCK BY CODE
3. WHEN DURING UNLOCK PROCESS SW DISPLAY THE MESSAGE BOX PLEASE READ WHAT IT SAY AND DO IT FAST ELSE
PROCESS COULD FAIL SOME CASES
DOWNLOAD LINK: download
			 21/02/2009 QCOM SMART TOOL v1.0.0.1206 RELEASED !
