Checking for local SX card...
Local SX card detected, checking superdongle applet...OK
Connecting to phone...
Failed! Make sure you have corect imei in phone
Jaf báo lỗi như vậy là sao? các anh chỉ em với,thank, sx4 cho N72
 Sx4?
 Sx4?
				TRUNG TÂM SỬA CHỮA DTDD TUẤN HOÀNG - GIA TÂN 1-THỐNG-NHẤT-ĐỒNG NAI-QL-20
Chuyên SW & HW all Mobile -LH_ ĐT:0613778888-3867722-0902442220-0966907790
Bank-plus Cua VT:9990110214707_Vũ Tiến Hoàng : NH Agribank số TK:5915205023902
				máy gửi file ban à.
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 09E0000FBCEA5851A0AED13F01B7C33E429F69AC
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: E:\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 00020001 <=> SPANSION -> Type not in database
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: E:\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
APE Boot: E:\JAF\Flash\helen3_2nd.fg
Loader version: 01.23.00 -> Revision: 0000
Patching APE boot step2...
APE Boot Ready
APE Flash ID: 003600EC <=> SAMSUNG (SEC) -> K5E1212ACM
APE Flash Data: 00020000000600000000000000000000
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.2
04-10-07
RM-180
(c) Nokia.
HW version: 5001
PCI version:
RFIC version: 150a160f
DSP version: rolf_espresso_05wk07v29p1
Retu version: 32
Tahvo version: 52
Production serial number: CTB238010
Product code: 0531540
Module code:
Basic production code: 0530940
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354533018947079
IMEI spare to net: 3A 45 35 03 81 49 07 07
IMEI SV to net: 33 45 35 03 81 49 07 07 F9
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file E:\JAF\JAF_RM-180.ini
Setting local mode...
Reading product code...
Product Code: 0531540
No ini files found...
Done!
				anh tuanhoang có cao kiến gì ko
				Nhìn cái log ok mà ,theo mình thì có 2 vấn đề ,thứ nhất = bạn nên đem qua 1 cái PC khác mà sx4 thử xem có khả quan hơn kg (vì lúc trước mình từng sx4 1 cái PC thì OK ,cái kia thì kg ok )
2 là chờ lúc mạng good thao tác thử lại ,sory vì mấy bữa lu bu vào forum nhưng thiếu quan sát !
				CONFIG KEY không vấn đề gì
Log đã ok
Vấn đề còn lại là SX4 ko ok là do mạng thui bạn vì jaf sx4 free mà.
Chịu khó xếp lốt đi sx4 sẽ ok mừ.
Hãy kích thank để cám ơn người giúp mình.
không nên spam"thank".
PROVIDER KEY: 2440700000000000 con này giông bị repair
				nhìn cái provider là biết 308 dỏm rồi , làm sao mà sx4 cho được bạn.
