Kết quả 1 tới 10 của 10
    T4M
    T4M vẫn chưa có mặt trong diễn đàn
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Mặc định K810i (DB2020) CID53 REPAIR GDFS OK.
    Mặc dù biết cái vụ repair gdfs này có lâu rồi,nhưng mình muốn cho nó thêm phong phú về REPAIR nên post lên cho nó thực tế tí.
    Code:
    v0.915030/UNI
    CARD SERIAL: 00030462
    Loaded 51 flash descriptors
    Connecting to UFS...
    Found 2 FTDI device(s).
    UFS #101931 READY
    TESTPOINT REPAIR STAGE #1 STARTED
    ChipID:9900,EMP protocol:0301
    Speed:921600
    OTP: LOCKED:1 CID:51 PAF:1 IMEI:35315302476612 CERT:N/A
    FLASH CID:53 COLOR:RED
    LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
    PREPARING...
    ATTACH TP #1 AND PRESS "READY"
    RELEASE TP #1 AND PRESS "READY"
    TP #1 LOOKS OKAY
    DONE
    TESTPOINT REPAIR STAGE #2 STARTED
    ATTACH TP #2 AND PRESS "READY"
    Trying to launch embedded bootloader...
    TP #2 LOOKS OKAY
    RELEASE TP #2 AND PRESS "READY"
    INT LDR:DB2020_PRELOADER_FOR_SETOOL2
    WRITING EROM...
    DONE
    Elapsed: 200 secs.
    Speed:921600
    FLASH CID:49 COLOR:BROWN
    LDR:060721 1021 DB2020_SERVICE_LOADER
    Flash ID check:897E
    Flash props sent ok
    writing "C:\Documents and Settings\THANHTAM\Desktop\SE15030\gdfs_in_ssw_format\db2020\K810_GDFS_SSW.ssw"
    CURRENT FLASH FILE CID:49
    SSW uses full hash, hash len is:640
    Will flash 32 blocks...
    SSW loading returns:0
    Setting up GDFS...
    OTP WRITE NOT EXECUTED
    WRITING CLEAR SIMLOCK UNITS...
    ALL UNLOCK/LOCK CODES SET TO "25244470"
    SIGNING...
    Elapsed: 44 secs.
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    writing "C:\Documents and Settings\THANHTAM\Desktop\SE15030\eroms\db2020\DB2020EROM_CNV_RED53_BROWN_CID49_DB2020.ssw"
    SSW uses full hash, hash len is:40
    Will flash 2 blocks...
    Setting up GDFS...
    ALL UNLOCK/LOCK CODES SET TO "72357706"
    SIGNING...
    Elapsed: 12 secs.
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    Model:K810i
    Brand:Generic
    MAPP CXC article: R1KC001     prgCXC1250811_GENERIC_SM
    MAPP CXC version: R1KC001
    Language Package:EUROPE_4
    CDA article: CDA111111/DEV
    CDA version: R2A
    Default article: cxc1250813
    Default version: R1KC001
    PROVIDER: 000-00
    SIMLOCKS NOT DETECTED
    RESTORATION FILE NOT PRESENT
    "R1KC001_CXC1250811_GENERIC_SM"
    YOU MUST PERFORM FULL FLASHING
    WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
    BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
    Elapsed: 4 secs.
    Closing UFS at your request.
    SIGNED MODE (USING SERVER)
    PHONE STATE: "RETAIL"
    FLASH CID: 0053
    Speed:921600
    OTP: LOCKED:1 CID:51 PAF:1 IMEI:35315302476612 CERT:RED
    PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
    Flash ID check:897E
    Flash props sent ok
    writing "E:\SETOOL3\SONYERICSSON\THANHTAM\K810\CID53\R8BA024_1250904_CHINA_SM.ssw"
    CURRENT FLASH FILE CID:53
    SSW uses full hash, hash len is:9200
    Will flash 460 blocks...
    writing "E:\SETOOL3\SONYERICSSON\THANHTAM\K810\CID53\r8ba024_fs_apac_sm_red_cid53.ssw"
    SSW uses full hash, hash len is:4820
    Will flash 241 blocks...
    LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    resetting usercode..
    USERCODE RESET TO "0000"
    writing "tpa/preset/custom/C3_PCA_G3v2.cer"
    writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm"
    writing "tpa/preset/custom/customize.xml"
    writing "tpa/preset/custom/DESKTOP_HOOK_2.itm"
    writing "tpa/preset/custom/Entrust.net Root Certificate.cer"
    writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt"
    writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm"
    writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm"
    writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm"
    writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm"
    writing "tpa/preset/custom/GAMES_HOOK_3.itm"
    writing "tpa/preset/custom/GTE_CyberTrust_Root.cer"
    writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt"
    writing "tpa/preset/custom/Root.cer"
    writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt"
    writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm"
    writing "tpa/preset/custom/ThawtePremium.der"
    writing "tpa/preset/custom/ThawteServerCA.cer"
    writing "tpa/preset/custom/Utiroot.cer"
    writing "tpa/preset/custom/VeriSignClass3Root.cer"
    writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt"
    Phone detached
    Elapsed: 417 secs.
    TRUNG TÂM SỬA CHỮA & BẢO HÀNH ĐTDĐ T4M
    SỬA CHỮA CHUYÊN NGHIỆP-UNLOCK,CHUYỂN HỆ,SỬA LỖI PHẦN MỀM
    40b,NGUYỄN THÁI BÌNH,P.4,Q.TB ÐT: (08)62966082-(08)73000234 YH&SKY: t4_mobile
    Thành viên chính thức phu hue's Avatar
    Aug 2008
    huế
    đang ôm 2 con tâm ơi.ngày mai cap ra mới chích được nè
    Thành viên chính thức thanhhieuqb's Avatar
    Đống Máy Xác
    Trích Được post bởi phu hue Xem bài viết
    có cáp cũng không chích được đâu nè phú . hầu hết là phải mở flash !
    302 TRẦN HƯNG ĐẠO - ĐỒNG HỚI - QUẢNG BÌNH !
    V.I.P NguyênChương-XM's Avatar
    103.PHT.TP.VŨNG TÀU
    Trích Được post bởi thanhhieuqb Xem bài viết
    Chế cho nó cái công tắc là chích vô tư chứ gì
    CÂY THẲNG LÊN NHỜ UỐN , NGƯỜI KHÔN LÊN NHỜ NGƯỜI
    Đống Máy Xác
    2/24/2009 9:46:44 AM FLASH CID:52 COLOR:RED
    2/24/2009 9:46:46 AM PROCEDURE WAS STOPPED BY USER
    2/24/2009 9:46:46 AM setGDFS_params failed
    2/24/2009 9:46:46 AM failed to setup GDFS
    2/24/2009 9:46:46 AM Elapsed: 6 secs.
    2/24/2009 9:46:55 AM TESTPOINT REPAIR STAGE #1 STARTED
    2/24/2009 9:46:55 AM Open COM port OK
    2/24/2009 9:47:03 AM ChipID:9900,EMP protocol:0301
    2/24/2009 9:47:03 AM Speed:921600
    2/24/2009 9:47:04 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35988501947719 CERT:N/A
    2/24/2009 9:47:04 AM FLASH CID:52 COLOR:RED
    2/24/2009 9:47:05 AM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    2/24/2009 9:47:05 AM PREPARING...
    2/24/2009 9:47:12 AM ATTACH TP #1 AND PRESS "READY"
    2/24/2009 9:47:29 AM RELEASE TP #1 AND PRESS "READY"
    2/24/2009 9:47:30 AM TP #1 LOOKS OKAY
    2/24/2009 9:47:38 AM DONE
    2/24/2009 9:47:38 AM TESTPOINT REPAIR STAGE #2 STARTED
    2/24/2009 9:47:39 AM Open COM port OK
    2/24/2009 9:47:40 AM ATTACH TP #2 AND PRESS "READY"
    2/24/2009 9:48:03 AM Trying to launch embedded bootloader...
    2/24/2009 9:48:03 AM TP #2 LOOKS OKAY
    2/24/2009 9:48:03 AM RELEASE TP #2 AND PRESS "READY"
    2/24/2009 9:48:06 AM INT LDRB2020_PRELOADER_FOR_SETOOL2
    2/24/2009 9:48:10 AM WRITING EROM...
    2/24/2009 9:48:13 AM DONE
    2/24/2009 9:48:14 AM Elapsed: 79 secs.
    2/24/2009 9:50:44 AM Open COM port OK
    2/24/2009 9:50:44 AM ChipID:9900,EMP protocol:0301
    2/24/2009 9:50:44 AM Speed:921600
    2/24/2009 9:50:45 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35988501947719 CERT:N/A
    2/24/2009 9:50:45 AM FLASH CID:49 COLOR:BROWN
    2/24/2009 9:50:47 AM LDR:060721 1021 DB2020_SERVICE_LOADER
    2/24/2009 9:50:47 AM Flash ID check:897E
    2/24/2009 9:50:47 AM Flash props sent ok
    2/24/2009 9:50:47 AM writing "C:\setool2g\gdfs_in_ssw_format\db2020\s500_gdfs_S SW.ssw"
    2/24/2009 9:50:48 AM CURRENT FLASH FILE CID:49
    2/24/2009 9:50:48 AM SSW uses full hash, hash len is:640
    2/24/2009 9:50:48 AM Will flash 32 blocks...
    2/24/2009 9:51:24 AM SSW loading returns:0
    2/24/2009 9:51:25 AM Setting up GDFS...
    2/24/2009 9:51:25 AM OTP WRITE NOT EXECUTED
    2/24/2009 9:51:25 AM WRITING CLEAR SIMLOCK UNITS...
    2/24/2009 9:51:25 AM ALL UNLOCK/LOCK CODES SET TO "36242532"
    2/24/2009 9:51:27 AM SIGNING...
    2/24/2009 9:51:29 AM Elapsed: 45 secs.
    2/24/2009 9:51:57 AM Open COM port OK
    2/24/2009 9:51:58 AM ChipID:9900,EMP protocol:0301
    2/24/2009 9:51:58 AM Speed:921600
    2/24/2009 9:51:58 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35988501947719 CERT:N/A
    2/24/2009 9:51:58 AM FLASH CID:49 COLOR:BROWN
    2/24/2009 9:52:00 AM LDR:060721 1021 DB2020_SERVICE_LOADER
    2/24/2009 9:52:00 AM Flash ID check:897E
    2/24/2009 9:52:00 AM Flash props sent ok
    2/24/2009 9:52:00 AM writing "C:\setool2g\eroms\db2020\DB2020EROM_CNV_RED52_BRO WN_CID49_DB2020.ssw"
    2/24/2009 9:52:02 AM CURRENT FLASH FILE CID:49
    2/24/2009 9:52:02 AM SSW uses full hash, hash len is:40
    2/24/2009 9:52:02 AM Will flash 2 blocks...
    2/24/2009 9:52:04 AM SSW loading returns:0
    2/24/2009 9:52:05 AM Setting up GDFS...
    2/24/2009 9:52:05 AM OTP WRITE NOT EXECUTED
    2/24/2009 9:52:05 AM WRITING CLEAR SIMLOCK UNITS...
    2/24/2009 9:52:05 AM ALL UNLOCK/LOCK CODES SET TO "12438872"
    2/24/2009 9:52:07 AM SIGNING...
    2/24/2009 9:52:09 AM Elapsed: 13 secs.
    cũng có 1 em đang nóng hổ nè , mới chơi xong !
    Thành viên tích cực tiepmobile's Avatar
    em cũng đang có một con.anh cho em xin cái hình chế công tắc với.hiiiiiiiiiii
    HUYỀNNGÂN MOBILE:249 trần thành ngọ- kiến an- hải phòng
    yahoo:huyennganmobile sdt:0989666966
    Thành viên mới chimobile's Avatar
    các anh cho em sơ đồ cau mic k800i voi các anh ơi
    Moderator nhotrung_bn's Avatar
    266-Phố Mới Thị TRấn Hồ-Thuận Thành-Bắc Ninh
    cái bọn SE mà repair lại GDFS thì 10 chỉ có 2-->3 con là được còn đâu hết
    NHOTRUNG_BN ADD: 266 Phố Mới-TTH-TT-BN
    Nhận unlock-Bẻ Khóa-Nạp Phần mềm
    Repair boot-unbrick all sam sung-sony-LG-HTC...
    T4M
    V.I.P T4M's Avatar
    Jun 2007
    Lò mổ IC
    Trích Được post bởi nhotrung_bn Xem bài viết
    Anh này chắc pro Sony nè,cho em trả giá chút xíu 10 ăn 5.
    Thành viên tích cực thuongthuong's Avatar
    May 2007
    các bác có hình k810i testpoint up cho mình với thanks
    [SIGPIC][/SIGPIC]
  1. [Unlock]SE w580i - DB2020/CID53
    By r3dhat in forum SETOOL
    Bài viết cuối: 22-12-2008, 12:21
  2. Trả lời: 0
    Bài viết cuối: 07-05-2008, 08:18
  3. Trả lời: 0
    Bài viết cuối: 24-04-2008, 10:53
  4. Trả lời: 0
    Bài viết cuối: 28-03-2008, 23:33
  5. Trả lời: 0
    Bài viết cuối: 28-03-2008, 18:56
