MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.06
12-01-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: P06w45.v45
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.06
12-01-08
RH-99
(c) NMP
MR
ADSP SW version: V 5.06\n12-01-08\nRH-99\n(c) NMP\nmr
Production serial number: IEK827569
Product code: 0546885
Module code: 0203402
Basic production code: 0544418
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353108028082471
IMEI spare to net: 3A 35 01 08 82 80 42 07
IMEI SV to net: 33 35 01 08 82 80 42 47 F8
Master Code: 6143461376
Phone type: RH-99, Software version: 5.06, Language Pack: MR
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0546885
Checking path: \Products\RH-99\
No ini files found...
Done!
Phone Type:
MCU Flash file: D:\file nokia\RH-99\rh99_04.000
Phone Type:
PPM Flash file: D:\file nokia\RH-99\rh99_04.00ia
Languages in ppm: English,Arabic,Farsi,French,Urdu
Phone Type:
CNT Flash file: D:\file nokia\RH-99\rh990_nai4.00ia
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: D:\file nokia\RH-99\rh99_04.000
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 845AC960BE32AF61E984B5693F
MSID decoded: 3E4EBAE90044B079AA000000
FAID: 6125C495AC39277B6F4F2C50
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 2 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: D:\file nokia\RH-99\rh99_04.00ia
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 20 seconds...
Writing...
Operation took 0 minutes 6 seconds...
Restarting MCU...
CNT: D:\file nokia\RH-99\rh990_nai4.00ia
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 26 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 4.00
IMEI: 353108028082471
Resetting PPC...
Done!
dây là lốc của 1200 no' chập trờn lúc lên nguồn lúc ko len .co' lên thj` bị đơ may' luon
