Kết quả 1 tới 10 của 12
    Thành viên chính thức rainbow's Avatar
    Apr 2008
    Unhappy chạy BB5 mà báo như vậy là sao dậy mấy anh
    Em chạy hộp JAF không cần Pkey +hộp JAF như mấy a chỉ mà chỉ chạy được DCT4 thôi
    còn chạy BB5 nó báo lỗi vậy là sao vậy anh
    JAF version 1.98.58
    Detected PKEY: 90007BF6
    Card life counter: 99.99%
    Detected version: 01.B0, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    Fast phone flashing selected.
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-174\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-174\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__05.53.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__05.53.ppm_s
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__05.53.image_s
    Languages in ppm: English,Chinese Trad ,Chinese Simpl,Malaysian
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__05.53.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__05.53.image_v
    Languages in ppm: English,Chinese Simpl,Chinese T,Vietnamese
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    Loader version: 01.0C.05 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Reading CMT NPC certificate...
    NPC crt not available...
    Reading CMT VARIANT certificate...
    VARIANT CRT not available...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _1250252.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\353081024399100_CRT_backu p_1250252.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 2390020209BA6F56290590F0E59FA174886EC349
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg
    CMT Boot Ready
    CMT Flash ID: 881C0020 <=> ST -> M39L0R807
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    CMT Loader Ready
    Sending CRT data...
    Error in RD cmd...
    Error preparing flashing...
    Đừng chê em không biết hay hoi?
    86 phan đình phùng quảng ngãi
    bạn chịu khó xem lại dây cáp kiếm cộng khác mà chạy.thêm 1 đều nữa jaf đã supor lên 1.98.62 bạn dowload về mà xài !
    Apr 2008
    hic chạy 5200 cũng không được .Nó báo y chan như vậy.em chạy usb thi không nhận máy .hic ai còn cách nào khác không anh
    Thành viên tích cực HưngMobile's Avatar
    Thốt Nốt_Cần Thơ
    cài nokia pc suit vào flash bằng usb lại xem sao
    Apr 2008
    hic cài PC suite vào chạy USB nó báo như vậy đây:
    JAF version 1.98.62
    Detected PKEY: 9000DA9A
    Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
    ADSP Flash file: NONE
    APE User Flash file: NONE
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__07.00.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__07.00.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-174\rm174__07.00.image_v
    Backing up CRT...
    Detected P-KEY: 9000DA9A
    Init usb communication...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\353081024399100_CRT_backu p_155123.pm
    Done!
    Backup CRT OK!
    Searching for phone...Found
    Reading SW version...06.02
    Reading battery value...3851 mV
    Init usb flashing...
    Reading flashid... 128k flash detected.
    CMT: 881C0020 <=> ST -> M39L0R807
    APE: 00000000 <=> Flash -> not detected
    Verifing ADL communication... Status byte 2
    Scanning selected flash files...
    Found CMT ULO server in flash file...
    ADL->Loader: Update Application Loader -> Single Chip
    Loader len: 253888, CHK: 0xED8F
    ADL -> Sending loader...
    Fail to send reboot command...
    V.I.P htv1810's Avatar
    Aug 2006
    LỖi driver,remove driver rồi setup lại bản này --> http://www.4shared.com/file/50826797...0_eng.html?s=1
    Nhận unlock,sữa chữa DTDĐ và đào tạo học viên.
    AzSoft Mobile Service
    6F' Nguyễn Thị Tần P2.Q8.TPHCM
    Phone08.6124225
    Mobile-Phone0909.510312
    Apr 2008
    hic vẫn chưa được nhưng cũng chân thành cảm ơn anh em nhiệt tình giúp đỡ và góp ý
    Thành viên mới haichau123456's Avatar
    Feb 2008
    DA LAT
    mình nghỉ do cable nhiều........bạn lấy đúng cáp 7pin hoặc đa năng là được! good luck
    Thành viên mới h&t(-_-)'s Avatar
    bạn xem lại đi ko nhận ra flash .
    máy mới đầu bị làm sao bạn nó rõ hơn để mọi người cùng giúp
    Apr 2008
    là như vậy đây mấy a em thay că.p flash của 3110c vào 5200 máy bấm lên nguồn nhưng bị loạn phím. cắm usb vào máy nhận là 3110c giờ em muốn chạy lại phần mềm lại để nó phù hợp với 5200
  1. Trả lời: 1
    Bài viết cuối: 02-06-2014, 11:07
