Kết quả 1 tới 3 của 3
    Executive Administrator taihv™'s Avatar
    Nov 2006
    Hà Nội
    Mặc định FREE Blackberry unlock solution for NsDongle and NsPro customers!
    ns-Blackberry logger released!!!
    Each NsDongle and NsPro box ID was credited with 2 free BlackBerry logs.
    To use Blackberry logger, go to support area and you will see user/pass for logger and link to download logger software.
    User/pass are different for each box ID.
    Supported Blackberry* Phones:
    BlackBerry 71xx Series : 7100g, 7100g, 7100i, 7100r, 7100t, 7100v, 7105t, 7130e
    BlackBerry 72xx Series : 7230, 7250, 7280, 7290,
    BlackBerry 75xx Series : 7520,
    BlackBerry 77xx Series : 7730, 7750, 7780,
    BlackBerry 8700 Series : not supported
    Unlock BlackBerry 5xxx, 6xxx, 7Xxx
    Using standard blackberry USB cable (as supplied with phone)
    Phones not supported: X700, 7510 (iden), 5810, H700
    * Blackberry firmware must be 4.x and up, No password protected!
    Instructions:
    1. Please install the driver first before connecting your blackberry
    2. if you have blackberry connected before, it usually use standard driver so please replace with our Jungo driver.
    you can do this from control panel>system>device manager
    3. start the ns-blackberry.exe
    4. enter your id and password
    5. we recommend you test the server connection first
    6. click unlock the phone and the unlock code will be shown
    7. for those who dont know the procedure to enter the code back to the phone, please read the instrucion below
    Make sure phone is upgraded to latest 4.x firmware. You can check this by going to options>about settings
    If not, please visit www.blackberry.com to download latest version for your phone model.
    Please remove/disable password from the phone. If password is forgotten, enter the password wrong 10 times will reformat the phone. ALL DATA IS LOST!
    Please check if the phone has security policy, usually this is because the phone is setup up to operate with Blackberry Enterprise server. Please remove the security policy
    Now you are ready to unlock the phone
    Connect the phone to the pc and click read the code and it will show you the code.
    Entering unlocking codes:
    1 - Using the menu go to Settings Menu -> SIM card press select.
    2 - While holding the SHIFT key, type “MEPD” or incase of 7100 “MEPDD”
    3 - You should now see the five locking categories listed.
    4 - While holding the ALT KEY, type “MEP2” or incase of 7100 “MEPP2”
    5 - Release the alt key.
    6 - You are now prompted to enter the Network MEP code (will also state how many attempts left)
    7 - Enter the code
    8 - Enter Return/Enter
    9 - The device should then be unlocked
    PS.
    This is only the first promotion. Many other promotions will be available in the feature.
    Stay close
    B.R.
  2. ( taihv™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thvn12 (15-06-2008)
    Thành viên kỳ cựu cotaomobile's Avatar
    Sep 2005
    anh test Ok chưa anh ?
    sẳn anh mở thêm một Mục NSPRO_NSDONGLE luôn đi em thấy Room thiếu fần support cho nó đó
    thân chào
    y/m : Cotaomobile_kg
    077.350.0099___091808.3663
    Thành viên chính thức sam_vina's Avatar
    Oct 2005
    VI
    www.suachuadtdd.com
    unlock iphone - Repair board GSM - NO WIFI
  1. Trả lời: 3
    Bài viết cuối: 09-12-2010, 21:01
  2. Solution to unlock S5600 with NsPro
    By nhatkha in forum NS Dongle
    Bài viết cuối: 27-08-2010, 23:33
  3. 05/03/2008 Free Unlock For Lgs Included For Customers !!!
    By Hoang Thong Mobile in forum FuriouS Team Products
    Bài viết cuối: 07-03-2008, 08:29
  4. Trả lời: 2
    Bài viết cuối: 21-11-2007, 13:38
  5. Trả lời: 1
    Bài viết cuối: 06-10-2007, 17:22
