Kết quả 1 tới 10 của 12
    Thành viên chính thức rainbow's Avatar
    Apr 2008
    Post 6085 chay phâ`n mềm báo như vậy là sao mấy anh
    em thay con Rap GSM voi Flash khác cho 6085 ,nó lên nguồn rồi mà chạy phần mềm nó báo như vậy là sao
    JAF version 1.98.62
    Detected PKEY: 9000DFC2
    Card life counter: 99.99%
    Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Fast phone flashing selected.
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.mcusw.bin
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.ppm_e
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.image_lmt_lv
    Languages in ppm: English,German,Lithuanian,Latvian,Russian,Estonian ,Bulgarian,Romanian,Ukrainian
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.ppm_t
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.image_opv_smart
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000352
    Asic Public ID: 2390020209BA6F56290590F0E59FA174886EC349
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 881C0020 <=> ST -> M39L0R807
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    NPC crt not available...
    Reading CMT VARIANT certificate...
    VARIANT CRT not available...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Failed to backup CRT...
    Backing up SIMLOCK data...
    Setting local mode...
    Failed! Aborting!
    Failed to backup LCK...
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Operation took 0 minutes 6 seconds...
    No convertion block detected or file already converted.
    Erasing...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT PUB KEYS...
    Sending CMT HASH for DSP0
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Sending CMT HASH for PASUBTOC
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for MCUSW
    Operation took 1 minutes 39 seconds...
    Reseting phone...
    PPM: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.ppm_t
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Writing...
    Stage 1
    Operation took 0 minutes 28 seconds...
    Reseting phone...
    CNT: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__06.00.image_opv_smart
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Erasing...
    Writing...
    Writing converted flash to 128k page
    Operation took 0 minutes 31 seconds...
    Reseting phone...
    Done!
    Total time: 3 Minutes, 29 Seconds
    DCT4/BB5 counter: 1
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Đừng chê em không biết hay hoi?
    Thành viên tích cực xuancombam's Avatar
    Trà Vinh
    chạy ok mà bác.........tình trạng máy bác giờ sao ?
    Cty TNHH TM DV Tin Hoc & VT TÚ HẠNH-Trà Vinh
    ĐT:0743.740 740- DĐ:0907299967
    Thành viên tích cực BIBI&KUTE's Avatar
    Jul 2007
    Old Trafford
    bạn chạy lại bỏ chọn CRT308 và CRT BKP mình cũng vậy cây 6300 ok , bạn thử xem.
    TRUNG TÂM PHÁ MÁY TỪ XA
    Jul 2007
    Old Trafford
    Trích Được post bởi xuancombam Xem bài viết
    Failed! Aborting! thía mà ok gì bác????
    Thành viên tích cực Phúc_Cần Thơ's Avatar
    Dec 2008
    Miền GạoTrắng,Nước Trong.
    Trích Được post bởi BIBI&KUTE Xem bài viết
    Failed! Aborting!
    Vẫn lên nguồn bình thường à nha!hic
    Pro check lại cáp, bỏ CRT 308 chạy ok liền, chúc thành công!
    Sữa Chữa_Unlock_Tiếng Việt => Nạp Phần Mềm All Mobile
    Trà Vinh
    Vấn đề là máy nó vẫn lên nguồn ok bác ơi......ko biết máy bác kia bị gì mà kêu coi cái log kìa........cái đó là do sợi cáp kìa bác...
    Jul 2007
    Old Trafford
    lên nguồn bình thường bị lỗi gì mà chỵa lại thía bạn?
    Apr 2008
    đóng cặp RAP GSM với Flash của 3110c nó lên nguồn nhưng không đúng chương trình bị loạn phím nên chạy lại máy vẫn lên nguồn nhưng loạn phím để thử lại xem
    Aug 2008
    Trích Được post bởi rainbow Xem bài viết
    hehehe đóng cặp RAP & flash của 3110c vào cây này mà dùng được tui hàn mặc tử liền
    yahoo : hoangtu_bongdem_1986
    phone : 0935 10 1986
    Jul 2007
    Old Trafford
    sao mà được bạn. 1 là chết rap thay rap đúng của 6085, 2 là chết flash thay con khác giông id là được, hoặc phải thay cả bộ của 6085 mới ok bạn ah.trường hợp 1 và 2 phải gửi file .nếu kô backup được RPL, [308] field .
  1. 6085 chay phan mềm ko dược
    By minhkhoa_iphone in forum BB5
    Trả lời: 20
    Bài viết cuối: 17-01-2011, 08:09
  2. 6085 chay lại pm liên tục
    By thanhtungmobiok in forum BB5
    Bài viết cuối: 06-08-2009, 17:05
  3. 6085 chay file mat nguon
    By sgvn99 in forum BB5
    Bài viết cuối: 13-07-2009, 00:05
  4. 6085 thay cpu.chay pm ma trang man hinh
    By tungbinhduong in forum BB5
    Bài viết cuối: 14-12-2008, 17:04
