Em có cây K310i chạy báo lỗi thế này ạ.:
v0.915034/UNI
CARD SERIAL: 000XXXX
Loaded 51 flash descriptors
Open COM port OK
ChipID:8040,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35331501442778 CERT:RED
FLASH CID:49 COLOR:RED
Model (from GDFS):K310i
Brand:Generic
MAPP CXC article: R4DA044 prgCXC1250467_CHINA_DO
MAPP CXC version: R4DA044
Language Package:APAC
CDA article: CDA12345678/123
CDA version: R2A
Default article: cxc1250474
Default version: R4DA044
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
USERCODE:0000
RESTORATION FILE NOT PRESENT
"R4DA044_CXC1250467_CHINA_DO"
YOU MUST PERFORM FULL FLASHING
WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
Elapsed: 4 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Open COM port OK
Trying to launch embedded bootloader...
INT LDRB2010_RESPIN_ID_LOADER_SETOOL2
LDRB2010_RESPIN_PRODLOADER_SETOOL2
Flash ID check:897E
Flash props sent ok
FOUND VERSION "R4DA044_CXC1250467_CHINA_DO"
can't open file "E:\SETOOL\rest\R4DA044_CXC1250467_CHINA_DO"
writing "E:\FLAS FILE SONY\Setool\FLAS FILES\K310\r4da044_chinese_fs.ssw.cry"
CURRENT FLASH FILE CID:49
SSW uses dynamic hash, dynamic hash len is:105
Will flash 105 blocks...
SSW loading returns:0
writing "E:\FLAS FILE SONY\Setool\FLAS FILES\K310\r4da044_apac_fs.ssw.cry"
SSW uses dynamic hash, dynamic hash len is:113
Will flash 113 blocks...
Elapsed: 402 secs.
SIGNED MODE (USING SERVER)
Open COM port OK
FLASH CID: 0049
Speed:460800
FAILED TO SETUP PHONE
Elapsed: 4 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
LDR:070524 1030 AN2CXC1327364_COMPACT_SEMC_CS_LOADER__R3A010
loader startup: executed
wrong response, break.
loader GDFS startup failed, that is fatal
Elapsed: 559 secs.
POSSIBLE GDFS FILE DETECTED, EXTRACTING PHONEBOOK
PHONEBOOK NOT DETECTED IN GDFS FILE
Will write GDFS now.
Open COM port OK
FLASH CID: 0049
Speed:460800
Elapsed: 9 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
Elapsed: 202 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
Brand:Generic
CDA version: R2A
PROVIDER: 000-00
USERCODE:0000
Elapsed: 6 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
THEN PRESS "READY"
Open COM port OK
Flash ID check:897E
Flash props sent ok
Setting up GDFS...
setGDFS_params failed
failed to setup GDFS
Elapsed: 109 secs.
PRELOADER SECURITY BYPASS ENABLED.
Open COM port OK
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
Elapsed: 559 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
err: 0 (0)
Elapsed: 5 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
Elapsed: 560 secs.
file "" can't be found or opened
Elapsed: 0 secs.
RECOVERY MODE STARTED
Open COM port OK
err: 0 (0)
Open COM port OK
REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A
Fetching phone data from OTP
THAT WILL KILL YOUR PHONE, ABORTED
Elapsed: 6 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
THEN PRESS "READY"
Open COM port OK
Flash ID check:897E
Flash props sent ok
Setting up GDFS...
Elapsed: 142 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
THEN PRESS "READY"
Open COM port OK
Flash ID check:897E
Flash props sent ok
Setting up GDFS...
Unlock FAILED
Elapsed: 91 secs.
TESTPOINT REPAIR STAGE #1 STARTED
Open COM port OK
FLASH CID: 0049
skipping empty loader...
Elapsed: 5 secs.
Open COM port OK
FLASH CID: 0049
Speed:460800
Flash ID check:897E
Flash props sent ok
Elapsed: 562 secs.
Em làm đủ mọi cách rồi mà vẫn không được ạ.Có phải là banh GDFS không ạ.Em đã write GDFS rồi cũng ko hết.Con này phải cắt Tétpoint đúng không ạ.Các anh cho em hỏi là cắt Tétpoint cho dòng Sony này thế nào ạ.Cho em cả sơ đồ luôn nha.Thanks all
			 Các cao thủ Sony giúp em với
