    Thành viên chính thức thuykhanh's Avatar
    Mặc định N72 lỗi phần mềm
    jaf[/B]version 1.98.62
    Detected PKEY: 900144EF
    Card life counter: 80.10%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v47
    30-01-07
    RM-180
    (c) Nokia.
    HW version: 7001
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_espresso_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: DQD358292
    Product code: 0531541
    Module code:
    Basic production code: 0530940
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356966019125881
    IMEI spare to net: 3A 65 69 06 91 21 85 08
    IMEI SV to net: 33 65 69 06 91 21 85 08 F6
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\\
    No ini files found...
    Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101012200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 02200108416C63518AE8FE1F4EBEBF7C8A957EB7
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RM-180\RM180_50819401.C0
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RM-180\RM180_50819401.V11
    Languages in ppm: English,Simpl Chinese
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35696601912588_CRT_backup _1052263.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356966019125881_CRT_backu p_1052263.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    Mình chạy chương trình thì nó báo như trên . Nhờ các bạn tư vấn giùm mình nhé
    V.I.P DinhKha™'s Avatar
    Kiên Giang
    bạn câu áp theo hình của mình sau đó flash lại là ok.
  3. ( DinhKha™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thuykhanh (26-03-2009)
    Cám ơn bạn , mình nhìn hình khó hiểu quá , nhờ bạn chỉ rõ hơn cho mình được không . Xin cám ơn nhiều
    Thành viên tích cực xuancombam's Avatar
    Trà Vinh
    Trích Được post bởi thuykhanh Xem bài viết
    Bác đem qua HWK múc con này đi,Thằng JAF chạy con này lỗi APE suót.....Thanksssssss
    Cty TNHH TM DV Tin Hoc & VT TÚ HẠNH-Trà Vinh
    ĐT:0743.740 740- DĐ:0907299967
    Kiên Giang
    * Vấn đề là máy thiếu áp cấp OMAP.
    * Bạn gở bỏ 2 con cấp áp và câu tắt mượn áp cho nó theo hình trên.
    V.I.P ThienKim GSM™'s Avatar
    Thành phố Dệt
    Giải thích thế này nhé
    Số 1>>>>thay 2 con IC đó đi
    Số 2>>>>>>>>nối tắt
    Số 3>>>>nối tắt
  8. ( ThienKim GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #7
    V.I.P phatdat_dtdd's Avatar
    Mar 2007
    Mặc định đây
  10. ( phatdat_dtdd ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    gsnmientrung (27-03-2009), thuykhanh (26-03-2009)
  1. Trả lời: 1
    Bài viết cuối: 26-09-2015, 19:16
  2. Trả lời: 0
    Bài viết cuối: 23-06-2015, 16:53
  3. Trả lời: 0
    Bài viết cuối: 10-05-2014, 11:32
  4. Trả lời: 51
    Bài viết cuối: 06-10-2013, 15:14
  5. Trả lời: 0
    Bài viết cuối: 26-02-2012, 13:32
