    Thành viên chính thức nguyenvanhuy803's Avatar
    Dec 2008
    Mặc định 1600 chay =jaf can jup
    JAF version 1.98.61
    Detected PKEY: 9000DDD2
    Card life counter: 35.31%
    Detected version: 01.B0, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.0.2.0
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-64\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_04.030
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_04.03aa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai4.03aa
    Languages in ppm: English,Dannish,Norwegian,Swedish
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_04.030
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x6822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 21
    Loader is ready...
    MSID: 84C9BEE4E3DB7BB9C781AB850C
    MSID decoded: 3E4EBAE900D83BF7AA000000
    FAID: EAA56E8ADB038CBD7E0B141B
    Operation took 0 minutes 16 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 30 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_04.03aa
    Booting phone...
    MCU ID: 0x0000
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    vay là sao ? mong anh em chỉ jups
    Thành viên chính thức tien_hamhoc's Avatar
    coi lại con flash đi bạn
    ngày mai măc kệ ngày mai
    vì ta đã sống hôm nay đủ rồi
    Thành viên chính thức minhdvhn's Avatar
    Jan 2008
    nếu cáp tốt thì bạn coi con cpu làm chân đóng lại ko được thay con khác vì cpu ko nhận flast chúc bạn thành công
    Đến từ Hà Nam _DD:0982.855.880
    Thành viên chính thức namkhanh2828's Avatar
    Bạn đóng lại chân Flash nhé
    Trăm năm bia đá cũng mòn , bia chai cũng bể , chỉ còn bia ... ôm.
    Vi phạm nội quy Hai_GSM_Pro's Avatar
    Hà Nội & Sài Gòn
    Trích Được post bởi namkhanh2828 Xem bài viết
    bạn ko coi log hả đó là sau khi xoá flash thì nó như vậy đó
    con này làm lại hoặc thay cpu
    Aug 2008
    Trích Được post bởi nguyenvanhuy803 Xem bài viết
    JAF version 1.98.61
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x0000
    đưa qua ufs flash lại cho em nó phát nếu không được thì thay cpu
    yahoo : hoangtu_bongdem_1986
    phone : 0935 10 1986
    Thành viên chính thức vansang's Avatar
    các anh ơi em không hiểu đoạn này là sao ?
    kg có file trong ổ c chứ gì
  1. 1600 chay phần mềm không lên nguồn xin giúp
    By duongvanmanh in forum CÁC LOẠI ĐIỆN THOẠI KHÁC
    Bài viết cuối: 22-02-2011, 08:38
  2. Trả lời: 4
    Bài viết cuối: 10-07-2010, 22:19
  3. Trả lời: 10
    Bài viết cuối: 14-05-2009, 10:48
  4. 1600 chay phan mem can giúp
    By nguyenvanhuy803 in forum DCT4 - WD2
    Bài viết cuối: 04-04-2009, 20:10
