máy mất nguồn ,đã đóng nguyên cặp nhưng chưa lên,nạp fw báo thế này,các anh xem hộ
JAF version 1.98.61
Detected PKEY: 9000B179
Card life counter: 92.56%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 6.85.10.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-268\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-268\
Scanning ini files...
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-268\rm26830004.430.mcusw
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-268\rm2683004.43.ppm_r
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-268\rm26830004.43.image_r
Languages in ppm: English,Chinese Simpl.,Chinese TW
Backing up CRT...
Detected P-KEY: 9000B179
Init usb communication...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 02.31.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ................Loader Sent!
Stage 3 starting..........Phone prepared OK!
Waiting for the phone to boot...
Phone failed to boot in flash mode CMT...
xin anh em cho ý
kiến
