 Được post bởi
trungthanh1022
				Getting MCU ID
MCU ID: 0x2292
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RH-99\rh99_05.800
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-99\rh99_05.80mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RH-99\rh990_nai5.80mr
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\products\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 843DF6CEAF0A258384B8BB46CB
MSID decoded: 3E4EBAE9000A060DA9000000
FAID: 21F8A97D6A28D2E3D96DFAEB
Erasing...
Found 5 interval(s) to erase
Error erasing area: 013B0000 - 013CFFFF
em đóng lại hết cpu và flat rồi vẫn vậy cáp thì ok rồi đã chạy thử nhiều con rồi xin cao kiến có phải lỗi cpu không vậy mấy huynh..thank..
